Installation of OpenFoam 15 Compilation paraview |
October 22, 2008, 06:38 |
Hi evreybody,
I encounter s
#41 |
Pattyn Eric
Rep Power: 17 |
Hi evreybody,
I encounter some problems trying to compile Paraview. I have the following error (see below). I don't know what's it is talking about: "Cannot determine repository type. Please set UPDATE_TYPE to 'cvs' or 'svn'. CTest update will not work". Some data about me: [root@wobwslx2 qt-x11-opensource-src-4.3.1]# uname -a Linux wobwslx2 2.6.9-42.0.8.ELsmp #1 SMP Tue Jan 23 12:49:51 EST 2007 x86_64 x86_64 x86_64 GNU/Linux ep4@wobwslx2:~/OpenFOAM/ThirdParty$ qmake --version QMake version 2.01a Using Qt version 4.3.1 in /usr/local/Trolltech/Qt-4.3.1/lib For information, i have also a version 4.4.3 of Qt. Trying to using it following the indications of other posts, i have the same error. Thank you for your help. Eric ep4@wobwslx2:~/OpenFOAM/ThirdParty$ buildParaView3.3-cvs Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc -- Check for working C compiler: /ric_home/ep4/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- Check for working C compiler: /ric_home/ep4/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- works -- Check size of void* -- Check size of void* - done -- Check for working CXX compiler: /ric_home/ep4/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/c++ -- Check for working CXX compiler: /ric_home/ep4/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/c++ -- works -- Looking for Q_WS_X11 -- Looking for Q_WS_X11 - found -- Looking for Q_WS_MAC -- Looking for Q_WS_MAC - not found. -- Looking for Q_WS_WIN -- Looking for Q_WS_WIN - not found. -- Found Qt-Version 4.3.1 -- Cannot determine repository type. Please set UPDATE_TYPE to 'cvs' or 'svn'. CTest update will not work. CMake Error: Error in cmake code at /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/CMake/ParaViewCommon.cmake:52: INCLUDE Could not find include file: /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/CMake/vtkDependentOption.c make Current CMake stack: /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/CMakeLists.txt;/ric_home/ep4/O penFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/share/cmake-2.4/Modules/CMakeCI nformation.cmake;/ric_home/ep4/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64 /share/cmake-2.4/Modules/CMakeCXXInformation.cmake;/ric_home/ep4/OpenFOAM/ThirdP arty/ParaView3.3-cvs/CMake/ParaViewCommon.cmake;/ric_home/ep4/OpenFOAM/ThirdPart y/ParaView3.3-cvs/VTK/CMake/vtkDependentOption.cmake CMake Error: Error in cmake code at /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/CMake/ParaViewCommon.cmake:60: INCLUDE Could not find include file: /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/CMake/vtkUseX.cmake Current CMake stack: /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/CMakeLists.txt;/ric_home/ep4/O penFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/share/cmake-2.4/Modules/CMakeCI nformation.cmake;/ric_home/ep4/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64 /share/cmake-2.4/Modules/CMakeCXXInformation.cmake;/ric_home/ep4/OpenFOAM/ThirdP arty/ParaView3.3-cvs/CMake/ParaViewCommon.cmake;/ric_home/ep4/OpenFOAM/ThirdPart y/ParaView3.3-cvs/VTK/CMake/vtkDependentOption.cmake;/ric_home/ep4/OpenFOAM/Thir dParty/ParaView3.3-cvs/VTK/CMake/vtkUseX.cmake CMake Error: Error in cmake code at /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/CMake/ParaViewCommon.cmake:66: INCLUDE Could not find include file: /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/CMake/vtkSelectSharedLibra ries.cmake Current CMake stack: /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/CMakeLists.txt;/ric_home/ep4/O penFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/share/cmake-2.4/Modules/CMakeCI nformation.cmake;/ric_home/ep4/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64 /share/cmake-2.4/Modules/CMakeCXXInformation.cmake;/ric_home/ep4/OpenFOAM/ThirdP arty/ParaView3.3-cvs/CMake/ParaViewCommon.cmake;/ric_home/ep4/OpenFOAM/ThirdPart y/ParaView3.3-cvs/VTK/CMake/vtkDependentOption.cmake;/ric_home/ep4/OpenFOAM/Thir dParty/ParaView3.3-cvs/VTK/CMake/vtkUseX.cmake;/ric_home/ep4/OpenFOAM/ThirdParty /ParaView3.3-cvs/VTK/CMake/vtkSelectSharedLibraries.cmake CMake Error: Error in cmake code at /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/CMake/ParaViewCommon.cmake:207 : INCLUDE Could not find include file: /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/CMake/vtkSelectStreamsLibr ary.cmake Current CMake stack: /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/CMakeLists.txt;/ric_home/ep4/O penFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/share/cmake-2.4/Modules/CMakeCI nformation.cmake;/ric_home/ep4/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64 /share/cmake-2.4/Modules/CMakeCXXInformation.cmake;/ric_home/ep4/OpenFOAM/ThirdP arty/ParaView3.3-cvs/CMake/ParaViewCommon.cmake;/ric_home/ep4/OpenFOAM/ThirdPart y/ParaView3.3-cvs/VTK/CMake/vtkDependentOption.cmake;/ric_home/ep4/OpenFOAM/Thir dParty/ParaView3.3-cvs/VTK/CMake/vtkUseX.cmake;/ric_home/ep4/OpenFOAM/ThirdParty /ParaView3.3-cvs/VTK/CMake/vtkSelectSharedLibraries.cmake;/ric_home/ep4/OpenFOAM /ThirdParty/ParaView3.3-cvs/VTK/CMake/vtkSelectStreamsLibrary.cmake CMake Error: Error in cmake code at /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/CMake/ParaViewCommon.cmake:208 : Unknown CMake command "VTK_SELECT_STREAMS_LIBRARY". -- Configuring done make: *** Keine Targets angegeben und keine ğmakeĞ-Steuerdatei gefunden. Schluss. done |
October 22, 2008, 12:30 |
Hi again,
after some manipu
#42 |
Pattyn Eric
Rep Power: 17 |
Hi again,
after some manipulations, Paraview begin now to compile withoout the problem mentioned in my previous post. Nevertheless, the compilation stops after a while with the following error: Building CXX object VTK/Common/CMakeFiles/vtkCommon.dir/vtkTypeUInt8Array.o [ 12%] Building CXX object VTK/Common/CMakeFiles/vtkCommon.dir/vtkTypeUInt32Array.o [ 12%] Building CXX object VTK/Common/CMakeFiles/vtkCommon.dir/vtkTypeUInt64Array.o [ 12%] Building CXX object VTK/Common/CMakeFiles/vtkCommon.dir/vtkTypeFloat32Array.o [ 12%] Building CXX object VTK/Common/CMakeFiles/vtkCommon.dir/vtkTypeFloat64Array.o [ 12%] Building CXX object VTK/Common/CMakeFiles/vtkCommon.dir/vtkCommonInstantiator.o Linking CXX shared library ../../bin/libvtkCommon.so [ 12%] Built target vtkCommon make: *** [all] Fehler 2 done What's the problem with libvtkCommon.so ? Where can i find such a file ? Thank you Eric |
October 23, 2008, 04:24 |
Good morning,
I still have
#43 |
Pattyn Eric
Rep Power: 17 |
Good morning,
I still have the same error... I have found the file libvtkCommon.so in /OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/bin with other files like H5detect, libQtTesting.so, libvtktiff.so, ... which are mentioned in my terminal like libvtkCommon.so but without leading to an error. I don't know if this information can be usefull for someone to help me. Eric |
December 18, 2008, 11:04 |
hi Aram,
got same problem h
#44 |
Ikariya
hi Aram,
got same problem here with .OpenFOAM files, how did you bypassed it ? thanx for your help ! |
December 19, 2008, 05:10 |
hi Ikariya,
as i remember t
#45 |
Aram Amouzandeh
Rep Power: 17 |
hi Ikariya,
as i remember the main problem i got with paraview and the .OpenFOAM file, was due to the fact that qmake pointed to the older version of qt which was installed beside 4.3.5 on my computer. aram |
January 12, 2009, 07:39 |
all the errors mentioned above
#46 |
Zairja
Rep Power: 17 |
all the errors mentioned above w.r.t buildParaview-cvs are coz of QT not being 4.3.5
As per the README it can be 4.3.x however, i could only get it to work with 4.3.5. Try installing the same and then set the paths for QT to be correct so that it is picked rather than the old one! Then build Paraview and all will be ok. |
[OpenFOAM] Paraview installation problem | mcjicpm2 | ParaView | 0 | March 9, 2009 08:15 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
Compilation error with paraview | quartzian | OpenFOAM Installation | 0 | September 21, 2008 09:32 |
Error building DICOMAppHelper during ParaView compilation | geoffjay | OpenFOAM Installation | 1 | May 7, 2008 14:07 |
Paraview installation problem please help | bender | OpenFOAM Installation | 2 | February 27, 2006 06:00 |
