Setup OpenFOAM to run one two computers steps
Old   July 28, 2006, 11:28
Default Hi, Is there any step descr
Pei-Ying Hsieh
hsieh is on a distinguished road
Is there any step describing how to setup parallel runs on two computers?
1. do I need to install OpenFOAM on each computer?
2. how to setup so that these two computers can communicate with each other.
I have been running parallel jobs on computer with dual CPUs and/or dual cores.
Thanks!
Pei
hsieh is offline   Reply With Quote
Old   July 28, 2006, 14:03
Default 1. do I need to install OpenFO
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Not necessarily. If you can nfs export your filesystem that should mirror computer A on computer B quite nicely.
I have not done this myself, but I would assume that you need to sey up some kind of password-less rsh/ssh connection between the two.
Maybe someone else can quickly explain the details.
msrinath80 is offline   Reply With Quote
Old   July 28, 2006, 22:05
Default Hi, Thanks for the reply.
Pei-Ying Hsieh
I did set this up successfully through passwordless ssh when I was using OpenFOAM-1.1 (more than one year ago). At that time, I did not get very good results when running parallel on two computers (those were old AMD 1GHz CPUs). So, I abandoned those setup and totally forgot what I did then.
Now that OpenFOAM-1.3 is out, I would like to try running a job on multiple computers again (6 computers, each computer with dual Intel Xeon 3.2 GHz CPUs). I am hoping that some OpenFOAM experts here have done something like this and is willing to share the steps for setting this up.
Is it correct to say that what I have is not a cluster? Each computer already has OpenFOAM-1.3 installed, and some runs SuSE 64 10.0 OS, some runs SuSE 64 10.1 OS.
pei
Old   July 29, 2006, 15:03
Default That should not be too much of
That should not be too much of a problem. Why don't you give it a shot now and post any error messages?
Old   August 2, 2006, 17:17
Default As pUl| notes, you only need t
irc
Ian Cowan
irc is on a distinguished road
As pUl| notes, you only need to install OF on one disk on one machine, then mount this disk via NFS on all the other machines. Moreover, it's better this way since when updates occur, you only have to change one installation.
As for communications - passwordless ssh (or even rsh, if your system will allow it - we're assuming that your "cluster" is secure behind it's own firewall) is necessary to allow LAM to start up the OF processes on the remote machines. Also, make sure you have accounts set up on each of the machines!
Check out the OF User Guide (chapter 3.4) for instructions on the domain decomposition and on how to initiate the run.
Should be as simple as that. Try it out and post your speed-up results (i.e. run times for running an identical application on 1, 2, 6 nodes) - I'd be interested in those.
Good luck!
irc is offline   Reply With Quote
Old   August 23, 2006, 10:59
Default Hi, Now that I have 6 works
Pei-Ying Hsieh
Now that I have 6 workstations each with dual Xeon CPUs connected to a gigabit switch, I tried to
1. turn on NSF server service on the main computer,
2.turned on NSF client service on the rest 5 workstation,
3. ping all the workstations and got reply
4. issue "ssh -l workstation_name
NO response. So, ssh is not working I think.
.. stay tune
Old   August 23, 2006, 18:10
Default What is an NFS client service?
What is an NFS client service? If I remember correctly, all you should be doing is using the mount command with the filesystem type specified to nfs or some such?
Also, are all the workstations on the same subnet?
Old   September 9, 2006, 09:21
Default Hi, I finally got this to w
Pei-Ying Hsieh
I finally got this to work. The main problem was firewall.
I will post the steps I used later.
I only have OpenFOAM installed on the server. All clients mount to /home/user/OpenFOAM. Is this a good idea? When running in parallel, the clients gets OpenFOAM from the server. Will it be faster if each client also has OpenFOAM install and only mount the NFS server to say, /home/user/OpenFOAM/run_project?
Here are two articles about setting up NFS and passwordless ssh. I could not get passwordless ssh to work using what described in the first article. The second article has the correct steps.
http://www.linux.com/print.pl?sid=06/03/29/1857227
http://www.linuxhomenetworking.com/wiki/index.php/Quick_HOWTO_:_Ch17_:_Secure_Re mote_Logins_and_File_Copying
pei
Old   September 13, 2006, 13:13
Default Hi, These are the steps I u
Pei-Ying Hsieh
These are the steps I used to setup a cluster:
Preparation:
1. because this is a close network, I disabled firewall.
2. Only the server has OpenFOAM installed
3. I used SuSE 10.1 64 bit OS.
4. you need root password.
5. Make sure that in /etc/hosts you have all the computers name with their IP addresses entered. Use Ping to check.
6. All computer should have the same user account.
7. On all client computers, create OpenFOAM directory.
1. Setup NFS sever:
1.1 start YaST. Select Network Service. Click "NFS Server"
1.2 Click "start" under NFS Server. Click Next.
1.3 Add Directory: /home/user/OpenFOAM
1.4 Add Host: enter the host name (or IP). enter
rw,sync under options.
1.5 click Finish to start NFS server.
2. Setup NFS Client
2.1 start YaST. Select Network Service. Click "NFS Client".
2.2 Click "Add".
2.3 enter NFS Server name.
2.4 enter Remote File System: /home/user/OpenFOAM.
2.5 enter Mount Point: /home/user/OpenFOAM
3. Setup passwordless SSH
3.1 Client Side (This actually would be the NFS server, because the NFS server needs to log onto the clients)
3.1.1 Type "ssh-keygen -t dsa"
3.1.2 hit return twice when prompts for passphrase
3.1.3 type "cd ~/.ssh"
3.1.4 type "ls", you should get 3 files: id_dsa id_dsa.pub known_hosts
3.1.5 scp id_dsa.pub user@NFS_client:public-key.tmp
3.2 Server side (this will be NFS client):
3.2.1 type "ls"
3.2.2 type "mkdir .ssh"
3.2.3 type "chmod 700 .ssh"
3.2.4 type "cd .ssh"
3.2.5 type "cat ~/public-key.tmp >> authorized_keys"
3.2.6 type "rm ~/public-key.tmp"
Note: from the NFS sever side, type "ssh -l userID NFS_client" to see if you can log in without a password.
if it prompts for a password, then, enter the password. Logout, and repeat Steps 3. For some
unknown reason, sometimes, I have to steps 3 a couple of times.
4. Lamboot: LAM uses RSH by default, on the NFS server, type "export LAMRSH="ssh -x" to change to SSH.
Please let me know if there is any mistake.
Pei
Old   January 29, 2009, 20:58
Default Dear Pei Ying, Thanks so mu
Su Xiaohui
sxhdhi is on a distinguished road
Send a message via Skype™ to sxhdhi
Dear Pei Ying,
Thanks so much for sharing your work.
I am going to build up a PC cluster soon for OpenFOAM running in parallel computation. Your information is no doubt quite helpful for me to work.
If possible could you please give me some suggestion about how to build up a beowulf? What is your configuration and budget?
I am not familiar to do that. Thanks a lot in advance. Now I am thinking to setup simplest one: one head node plus one node. if these work well I then consider adding other two nodes.
Regards
XH
sxhdhi is offline   Reply With Quote
Old   January 29, 2009, 21:18
Default Hi, XH, At home, I have two
  #11
Pei-Ying Hsieh
Hi, XH,
At home, I have two computers each has a dual core CPU, hence, total of 4 CPU cores. They are connected by gigabit switch.
Just follow the steps, then follow the tutorial in OpenFOAM. You should be fine.
Speed up of a parallel run depends on the case you have.
Have fun.
Pei
Old   August 2, 2009, 23:39
Su Xiaohui
Dear Pei Ying,
I am sorry it has been long time I did not response. Have to work on other projects. Now I am back to setup the cluster.
I follow your suggestion to setup the cluster. I got problem at step 3. Although I have tried many times for step 3. It still needs password to log into client pc. It seems ssh passwordless does not work.
If there is another way to solve the problem now?
Best regards
XH
Old   February 12, 2011, 05:44
maysmech's Avatar
maysmech is on a distinguished road
Is it any easier and newer way to use OF parallel with multiple PCs?
I have Ubuntu 10.10 and OF 1.7.0.
Thanks in advance
maysmech is offline   Reply With Quote
Fluent 6.3.26 with NUMA computers Thierry FLUENT 2 February 13, 2008 07:42
Hep: Computers for large scale simulation sarah_ron2002 FLUENT 3 December 23, 2007 06:05
Help: Computers for large scale simulation sarah_ron2002 Main CFD Forum 9 December 20, 2007 10:17
Install Openfoam in Suse 100 setup environment h34gk1 OpenFOAM Installation 1 September 26, 2006 21:08
How to write CCL 2 computers Kemi CFX 1 May 3, 2004 19:09
