Installation problems
Old   March 15, 2007, 14:21
Default Very weird. Are you sure O
  #21
Eugene de Villiers
eugene is on a distinguished road
Very weird.
Are you sure OpenFOAM-1.3.linuxAMD64Gcc4DPOpt.gtgz downloaded correctly?
eugene is offline   Reply With Quote
Old   March 15, 2007, 14:22
Default Hrv, In the OpenFOAM direct
  #22
Toni Toney
tonitoney is on a distinguished road
Hrv,
In the OpenFOAM directory (/home/toni/OpenFOAM), I installed OpenFOAM-1.3.General.gtgz and OpenFOAM-1.3.linuxAMD64GccDPOpt.gtgz using the tar -zxvf command. Then I created a subdirectory called /home/toni/OpenFOAM/linuxAMD64. The instructions said to create a subdirectory with your operating system name and to extract the binaries there. This is where I installed gcc-4.1.0.linuxAMD64.tar first, secondly paraview-2.4.2.linuxAMD64.tar, and last j2sdk1.4.2_05.linuxAMD64.tar.
tonitoney is offline   Reply With Quote
Old   March 15, 2007, 14:24
Default Eugene, I questioned the down
  #23
Toni Toney
Eugene,
I questioned the download, too, so I did it again late yesterday. Should I try again?
Old   March 15, 2007, 14:29
Default So far I cannot see anything y
  #24
Hrvoje Jasak
So far I cannot see anything you did wrong. Check OpenFOAM-1.3.linuxAMD64Gcc4DPOpt.gtgz using tar tvzf and see if it contains the icoFoam file and why it would not be where you expect it.
Hrv
Hrvoje Jasak
Old   March 15, 2007, 14:45
Default Hrv, This is part of the ou
  #25
Toni Toney
Hrv,
This is part of the output from tar tzvf command I used. It looks like the files should be in that directory. I hated to include all this in this post, but I'm desperate.
Thanks.
drwxr-x--- henry/foam 0 2006-03-28 16:30:39 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/
-rwxr-x--- henry/foam 399293 2006-03-28 16:19:51 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/Q
-rwxr-x--- henry/foam 400573 2006-03-28 16:22:33 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/R
-rwxr-x--- henry/foam 274740 2006-03-28 16:21:35 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/Co
-rwxr-x--- henry/foam 385140 2006-03-28 16:21:56 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/Pe
-rwxr-x--- henry/foam 584785 2006-03-28 15:41:38 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/rhoSimpleFoam
-rwxr-x--- henry/foam 5276055 2006-03-28 16:10:23 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/PatchToolServer
-rwxr-x--- henry/foam 330560 2006-03-28 16:19:34 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/Mach
-rwxr-x--- henry/foam 284608 2006-03-28 16:20:14 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/divU
-rwxr-x--- henry/foam 286336 2006-03-28 16:20:52 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/magU
-rwxr-x--- henry/foam 173664 2006-03-28 16:12:35 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/combinePatchFaces
-rwxr-x--- henry/foam 309071 2006-03-28 16:26:09 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/ptot
-rwxr-x--- henry/foam 210048 2006-03-28 16:25:57 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/wdot
-rwxr-x--- henry/foam 120134 2006-03-28 16:13:17 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceFind
-rwxr-x--- henry/foam 310010 2006-03-28 15:35:55 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/laplacianFoam
-rwxr-x--- henry/foam 575838 2006-03-28 15:52:28 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/coodles
-rwxr-x--- henry/foam 1160538 2006-03-28 16:14:55 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/decomposePar
-rwxr-x--- henry/foam 216288 2006-03-28 16:23:34 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/wallGradU
-rwxr-x--- henry/foam 137312 2006-03-28 16:11:15 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/cfxToFoam
-rwxr-x--- henry/foam 502654 2006-03-28 15:42:44 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/rhoSonicFoam
-rwxr-x--- henry/foam 583514 2006-03-28 16:16:50 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/foamToEnsight
-rwxr-x--- henry/foam 372649 2006-03-28 16:29:04 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/FoamXCaseServer
-rwxr-x--- henry/foam 93235 2006-03-28 16:08:58 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/moveDynamicMesh
-rwxr-x--- henry/foam 226418 2006-03-28 16:12:17 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/polyDualMesh
-rwxr-x--- henry/foam 329039 2006-03-28 16:17:57 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/foamToGMV
-rwxr-x--- henry/foam 699606 2006-03-28 16:17:27 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/foamToVTK
-rwxr-x--- henry/foam 682282 2006-03-28 15:51:20 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/dieselEngineFoam
-rwxr-x--- henry/foam 849517 2006-03-28 15:59:20 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/twoLiquidMixingFoam
-rwxr-x--- henry/foam 227406 2006-03-28 16:10:55 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/starToFoam
-rwxr-x--- henry/foam 493623 2006-03-28 16:23:12 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/stressComponents
-rwxr-x--- henry/foam 103734 2006-03-28 16:13:26 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfacePointMerge
-rwxr-x--- henry/foam 290940 2006-03-28 16:22:45 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/Rcomponents
-rwxr-x--- henry/foam 403045 2006-03-28 16:08:53 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/renumberMesh
-rwxr-x--- henry/foam 396344 2006-03-28 16:24:12 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/wallHeatFlux
-rwxr-x--- henry/foam 144189 2006-03-28 16:12:26 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/refineWallLayer
-rwxr-x--- henry/foam 650315 2006-03-28 15:53:40 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/dnsFoam
-rwxr-x--- henry/foam 371169 2006-03-28 16:24:28 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/yPlusLES
-rwxr-x--- henry/foam 860717 2006-03-28 16:25:32 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/sampleSurface
-rwxr-x--- henry/foam 766567 2006-03-28 16:03:27 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/stressedFoam
-rwxr-x--- henry/foam 574185 2006-03-28 15:45:29 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/sonicTurbFoam
-rwxr-x--- henry/foam 107143 2006-03-28 16:09:03 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/splitMeshRegions
-rwxr-x--- henry/foam 174799 2006-03-28 16:09:36 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/refineMesh
-rwxr-x--- henry/foam 97512 2006-03-28 16:08:55 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/tetDecomposition
-rwxr-x--- henry/foam 874367 2006-03-28 15:55:40 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/lesInterFoam
-rwxr-x--- henry/foam 116470 2006-03-28 16:09:47 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/faceSet
-rwxr-x--- henry/foam 116472 2006-03-28 16:09:50 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/pointSet
-rwxr-x--- henry/foam 103705 2006-03-28 16:11:56 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/mshToFoam
-rwxr-x--- henry/foam 291773 2006-03-28 16:20:40 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/magGradU
-rwxr-x--- henry/foam 268968 2006-03-28 16:07:54 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/deformedGeom
-rwxr-x--- henry/foam 672447 2006-03-28 15:44:30 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/sonicFoamAutoMotion
-rwxr-x--- henry/foam 810671 2006-03-28 15:46:27 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/XiFoam
-rwxr-x--- henry/foam 146924 2006-03-28 16:13:09 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceCheck
-rwxr-x--- henry/foam 156249 2006-03-28 16:13:53 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceClean
-rwxr-x--- henry/foam 531956 2006-03-28 15:38:02 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/nonNewtonianIcoFoam
-rwxr-x--- henry/foam 374821 2006-03-28 16:07:28 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/rotateMesh
-rwxr-x--- henry/foam 165632 2006-03-28 16:12:31 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/selectCells
-rwxr-x--- henry/foam 642521 2006-03-28 16:05:58 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/momentScalarError
-rwxr-x--- henry/foam 97310 2006-03-28 16:09:01 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/moveEngineMesh
-rwxr-x--- henry/foam 684289 2006-03-28 16:06:33 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/icoMomentError
-rwxr-x--- henry/foam 202198 2006-03-28 16:13:00 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/modifyMesh
-rwxr-x--- henry/foam 97207 2006-03-28 16:26:12 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/engineCompRatio
-rwxr-x--- henry/foam 577916 2006-03-28 15:36:23 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/potentialFoam
-rwxr-x--- henry/foam 286349 2006-03-28 16:20:03 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/Ucomponents
-rwxr-x--- henry/foam 183225 2006-03-28 16:13:23 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceMeshTriangulate
-rwxr-x--- henry/foam 217804 2006-03-28 16:30:21 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/engineSwirl
-rwxr-x--- henry/foam 125035 2006-03-28 16:13:04 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceAdd
-rwxr-x--- henry/foam 360219 2006-03-28 16:11:21 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/gambitToFoam
-rwxr-x--- henry/foam 1041535 2006-03-28 16:02:09 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/twoPhaseEulerFoam
-rwxr-x--- henry/foam 161266 2006-03-28 16:11:54 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/gmshToFoam
-rwxr-x--- henry/foam 562689 2006-03-28 16:02:38 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/mhdFoam
-rwxr-x--- henry/foam 384662 2006-03-28 16:09:26 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/stitchMesh
-rwxr-x--- henry/foam 120389 2006-03-28 16:30:27 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/mixtureAdiabaticFlameT
-rwxr-x--- henry/foam 242843 2006-03-28 16:15:41 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/reconstructParMesh
-rwxr-x--- henry/foam 402883 2006-03-28 16:05:07 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/estimateScalarError
-rwxr-x--- henry/foam 657170 2006-03-28 16:30:01 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/mapFields
-rwxr-x--- henry/foam 98952 2006-03-28 16:13:27 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceSetOutside
-rwxr-x--- henry/foam 137800 2006-03-28 16:13:12 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceCoarsen
-rwxr-x--- henry/foam 582780 2006-03-28 15:41:06 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/rhoTurbFoam
-rwxr-x--- henry/foam 664230 2006-03-28 15:42:18 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/sonicFoam
-rwxr-x--- henry/foam 638716 2006-03-28 15:39:56 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/buoyantFoam
-rwxr-x--- henry/foam 943646 2006-03-28 15:47:57 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/Xoodles
-rwxr-x--- henry/foam 460537 2006-03-28 16:05:28 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/icoErrorEstimate
-rwxr-x--- henry/foam 96385 2006-03-28 16:13:14 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceConvert
-rwxr-x--- henry/foam 402822 2006-03-28 16:23:53 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/wallShearStress
-rwxr-x--- henry/foam 874323 2006-03-28 15:56:27 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/rasInterFoam
-rwxr-x--- henry/foam 96812 2006-03-28 16:13:48 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceSplitByPatch
-rwxr-x--- henry/foam 144751 2006-03-28 16:12:46 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/splitCells
-rwxr-x--- henry/foam 408961 2006-03-28 16:19:20 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/Lambda2
-rwxr-x--- henry/foam 122529 2006-03-28 16:30:30 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/equilibriumFlameT
-rwxr-x--- henry/foam 169170 2006-03-28 16:12:08 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/writeMeshObj
-rwxr-x--- henry/foam 588334 2006-03-28 15:45:01 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/sonicLiquidFoam
-rwxr-x--- henry/foam 187649 2006-03-28 16:11:11 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/ansysToFoam
-rwxr-x--- henry/foam 212720 2006-03-28 16:19:02 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/pPrime2
-rwxr-x--- henry/foam 114774 2006-03-28 16:30:33 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/equilibriumCO
-rwxr-x--- henry/foam 227095 2006-03-28 16:12:54 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/refinementLevel
-rwxr-x--- henry/foam 97206 2006-03-28 16:08:57 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/moveMesh
-rwxr-x--- henry/foam 281687 2006-03-28 16:02:50 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/electrostaticFoam
-rwxr-x--- henry/foam 158349 2006-03-28 16:08:32 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/mergeMeshes
-rwxr-x--- henry/foam 165384 2006-03-28 16:12:22 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/autoRefineMesh
-rwxr-x--- henry/foam 410598 2006-03-28 15:36:41 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/scalarTransportFoam
-rwxr-x--- henry/foam 550016 2006-03-28 16:16:22 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/foamToFieldview9
-rwxr-x--- henry/foam 286554 2006-03-28 16:26:24 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/writeCellCentres
-rwxr-x--- henry/foam 124708 2006-03-28 16:13:30 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceSmooth
-rwxr-x--- henry/foam 131185 2006-03-28 16:30:24 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/adiabaticFlameT
-rwxr-x--- henry/foam 685760 2006-03-28 15:51:58 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/oodles
-rwxr-x--- henry/foam 600495 2006-03-28 15:49:02 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/coldEngineFoam
-rwxr-x--- henry/foam 152632 2006-03-28 16:13:35 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceSubset
-rwxr-x--- henry/foam 114937 2006-03-28 16:11:47 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/foamMeshToFluent
-rwxr-x--- henry/foam 709905 2006-03-28 15:43:49 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/rhopSonicFoam
-rwxr-x--- henry/foam 139263 2006-03-28 16:12:01 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/tetgenToFoam
-rwxr-x--- henry/foam 360354 2006-03-28 16:23:27 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/checkYPlus
-rwxr-x--- henry/foam 520555 2006-03-28 15:38:52 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/turbFoam
-rwxr-x--- henry/foam 119802 2006-03-28 16:11:44 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/netgenNeutralToFoam
-rwxr-x--- henry/foam 673412 2006-03-28 16:24:55 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/sample
-rwxr-x--- henry/foam 814586 2006-03-28 15:50:04 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/engineFoam
-rwxr-x--- henry/foam 515195 2006-03-28 15:39:17 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/boundaryFoam
-rwxr-x--- henry/foam 184680 2006-03-28 16:11:05 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/sammToFoam
-rwxr-x--- henry/foam 113287 2006-03-28 16:09:38 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/objToVTK
-rwxr-x--- henry/foam 539797 2006-03-28 16:08:22 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/subsetMesh
-rwxr-x--- henry/foam 253164 2006-03-28 16:21:03 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/streamFunction
-rwxr-x--- henry/foam 108709 2006-03-28 16:30:35 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/chemkinToFoam
-rwxr-x--- henry/foam 363911 2006-03-28 16:20:29 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/enstrophy
-rwxr-x--- henry/foam 220234 2006-03-28 16:07:41 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/checkMesh
-rwxr-x--- henry/foam 641019 2006-03-28 15:40:31 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/buoyantSimpleFoam
-rwxr-x--- henry/foam 214537 2006-03-28 16:21:10 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/uprime
-rwxr-x--- henry/foam 126140 2006-03-28 16:13:46 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceTransformPoints
-rwxr-x--- henry/foam 636832 2006-03-28 16:15:33 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/reconstructPar
-rwxr-x--- henry/foam 453812 2006-03-28 16:28:45 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/FoamXCaseBrowser
-rwxr-x--- henry/foam 111473 2006-03-28 16:12:41 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/removeFaces
-rwxr-x--- henry/foam 131465 2006-03-28 16:09:30 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/autoPatch
-rwxr-x--- henry/foam 669806 2006-03-28 15:50:40 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/dieselFoam
-rwxr-x--- henry/foam 98065 2006-03-28 16:07:42 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/attachMesh
-rwxr-x--- henry/foam 534741 2006-03-28 15:37:08 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/icoFoam
-rwxr-x--- henry/foam 101868 2006-03-28 16:09:06 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/insideCells
-rwxr-x--- henry/foam 436863 2006-03-28 16:04:48 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/financialFoam
-rwxr-x--- henry/foam 124463 2006-03-28 16:08:28 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/flattenMesh
-rwxr-x--- henry/foam 281016 2006-03-28 16:17:39 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/smapToFoam
-rwxr-x--- henry/foam 301211 2006-03-28 16:10:41 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/ccm24ToFoam
-rwxr-x--- henry/foam 926249 2006-03-28 15:58:37 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/settlingFoam
-rwxr-x--- henry/foam 92928 2006-03-28 16:30:37 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/foamDebugSwitches
-rwxr-x--- henry/foam 130974 2006-03-28 16:08:25 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/mirrorMesh
-rwxr-x--- henry/foam 359129 2006-03-28 16:11:29 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/fluentMeshToFoam
-rwxr-x--- henry/foam 141522 2006-03-28 16:07:10 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/transformPoints
-rwxr-x--- henry/foam 142449 2006-03-28 16:13:43 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceSplitNonManifolds
-rwxr-x--- henry/foam 407156 2006-03-28 16:22:15 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/flowType
-rwxr-x--- henry/foam 163150 2006-03-28 16:08:36 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/splitMesh
-rwxr-x--- henry/foam 92561 2006-03-28 16:07:44 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/zipUpMesh
-rwxr-x--- henry/foam 155279 2006-03-28 16:11:38 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/kivaToFoam
-rwxr-x--- henry/foam 136121 2006-03-28 16:13:39 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/surfaceToPatch
-rwxr-x--- henry/foam 356977 2006-03-28 16:21:24 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/vorticity
-rwxr-x--- henry/foam 380544 2006-03-28 16:29:24 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/setFields
-rwxr-x--- henry/foam 124944 2006-03-28 16:11:41 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/plot3dToFoam
-rwxr-x--- henry/foam 105924 2006-03-28 16:30:39 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/foamInfoExec
-rwxr-x--- henry/foam 878733 2006-03-28 15:54:55 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/interFoam
-rwxr-x--- henry/foam 284005 2006-03-28 16:30:12 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/boxTurb
-rwxr-x--- henry/foam 116470 2006-03-28 16:09:45 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/cellSet
-rwxr-x--- henry/foam 142398 2006-03-28 16:12:38 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/collapseEdges
-rwxr-x--- henry/foam 220102 2006-03-28 16:07:07 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/extrudeMesh
-rwxr-x--- henry/foam 555775 2006-03-28 15:37:37 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/icoDyMFoam
-rwxr-x--- henry/foam 136630 2006-03-28 16:09:42 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/createPatch
-rwxr-x--- henry/foam 278508 2006-03-28 16:15:53 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/foamDataToFluent
-rwxr-x--- henry/foam 650521 2006-03-28 16:04:02 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/contactStressFoam
-rwxr-x--- henry/foam 201322 2006-03-28 16:28:20 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/FoamXHostBrowser
-rwxr-x--- henry/foam 473392 2006-03-28 16:04:26 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/stressFemFoam
-rwxr-x--- henry/foam 713506 2006-03-28 15:53:08 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/channelOodles
-rwxr-x--- henry/foam 392564 2006-03-28 16:25:50 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/postChannel
-rwxr-x--- henry/foam 200649 2006-03-28 14:30:00 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/foamFlex++
-rwxr-x--- henry/foam 351263 2006-03-28 16:06:58 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/blockMesh
-rwxr-x--- henry/foam 106766 2006-03-28 16:09:08 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/couplePatches
-rwxr-x--- henry/foam 1018843 2006-03-28 15:57:41 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/bubbleFoam
-rwxr-x--- henry/foam 511872 2006-03-28 15:38:27 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/simpleFoam
-rwxr-x--- henry/foam 637130 2006-03-28 15:48:30 OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPOpt/reactingFoam
Old   March 15, 2007, 14:54
Default Hrv and Eugene, I found my
  #26
Toni Toney
Hrv and Eugene,
I found my problem. My opteron system's date was messed up. We've had problems with it for awhile now. When I did the tar again, I paid closer attention to output and it kept giving me a time stamp error. I corrected the date/time on my operton, reinstalled the file, and the directory now has the correct files. foamInstallationTest runs fine now. I guess it's time to run some tutorials.
Thank you both for your quick assistance. I will probably be back with questions on how to run this software. I have to get it up and running for one of our engineers.
toni
Old   March 15, 2007, 14:55
Default Looks OK. So, if you've unpac
  #27
Hrvoje Jasak
Looks OK. So, if you've unpacked this correctly, why isn't there a file
in your installation? Or is there? icoFoam should ve at the same place.
Hrv
Hrvoje Jasak
Old   March 15, 2007, 16:15
Default I just finished installation o
  #28
Toni Toney
I just finished installation of OpenFOAM 1.3 on my 64 bit AMD operton running SuSe Linux 9. The foamInstallationTest ran fine after numerous
attempts. I now am trying to run blockMesh . cavity, but get the following error messages. I really know nothing about CFD software,
but have to get the software running for one of our engineers at work.
Any suggestions? Thanks.
blockMesh: /lib64/libc.so.6: version `GLIBC_2.3.4' not found (required
by blockMesh)
blockMesh: /lib64/libc.so.6: version `GLIBC_2.3' not found (required
by /home/toni/OpenFOAM/linuxAMD64/gcc-4.1.0/lib64/libstdc++.so.6)
blockMesh: /lib64/libc.so.6: version `GLIBC_2.3.2' not found (required
by
/home/toni/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1/platforms/linuxAMD64Gcc4DPOpt/lib /libmpi.so.0)
blockMesh: /lib64/libpthread.so.0: version `GLIBC_2.3.2' not found
(required by
/home/toni/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1/platforms/linuxAMD64Gcc4DPOpt/lib /liblam.so.0)
by
Old   March 16, 2007, 07:38
Default Hi Toni, Your glibc library i
  #29
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Toni,
Your glibc library is too old!
The best way would be to upgrade SuSE from 9 to 10.x
Dragos
dmoroian is offline   Reply With Quote
Old   May 4, 2007, 07:56
Default Is there a specific version of
  #30
Suresh kumar Kannan
kumar is on a distinguished road
Is there a specific version of the SW(OpenFOAM) for AMD64 bit machine? or Can I install the SW from the web side http://www.cfd-online.com/cgi-bin/Op...us/discus.cgi?
I will appreciate very much for an earlier answer.
Thanks
Kumar
kumar is offline   Reply With Quote
Old   November 5, 2008, 13:48
Default Hi guys! Let's see if anyon
  #31
María
maría is on a distinguished road
Hi guys!
Let's see if anyone can help me. My problem is:
I would like to have two different OF versions (1.4.1 and 1.4.1-dev) in the same machine.
For that purpose:
1.- I have downloaded 1.4.1, compiled it and checked that it works properly.
2.- I have downloaded 1.4.1-dev in a different directory, compiled it and checked that it works as well.
Then, if I want to work again with the 1st version , I do is as follows:
1.- I edit ~/.bashrc replacing:
. ~/OpenFOAM/OpenFOAM-1.4.1-dev/.OpenFOAM-1.4.1-dev/bashrc
with:
. ~/old-OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc
2.- source ~/.bashrc
It turns out that OF-1.4.1, which was installed first, is not compiled.
I guess, somehow the second instalation removes the first one...No idea why!!
Did it happen to anyone else?
Could someone help me?
Nice regards!
María
maría is offline   Reply With Quote
Old   November 10, 2008, 12:37
Default I fixed it! For your inform
  #32
María
I fixed it!
For your information:
1.- Have a look at:
2.- Check if WM_PROJECT_USER_DIR is properly defined!
María
Old   November 14, 2008, 04:01
Default Hallo to all,, I am using t
  #33
emilianyassenov
Hallo to all,,
I am using the IcoFoam and I have added the T field on it.but I have linear in heat flow...Is it possible to have parabolic heat flow in icoFoam
can somebody help me..
Thanks
Emo
Old   November 17, 2008, 09:10
Default Hello, I'm trying to instal
  #34
Niklas Winkler
nikwin is on a distinguished road
I'm trying to install OpenFOAM-1.4.1-dev on a linux64 OS. When trying to compile the message pasted below comes up, in this case I tried to compile rhoTurbFoam as a test. When running foamInstallationTest it says Critical systems ok.
Is there a solution to this error?
All the Best
/Niklas W
+ wmake
g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/scratch/nwinkler/ProgramFiles/OF1-4/OpenFOAM-1.4.1-dev/src/finiteVolume/lnInc lude -I/scratch/nwinkler/ProgramFiles/OF1-4/OpenFOAM-1.4.1-dev/src/thermophysicalMode ls/specie/lnInclude -I/scratch/nwinkler/ProgramFiles/OF1-4/OpenFOAM-1.4.1-dev/src/thermophysicalMode ls/basic/lnInclude -I/scratch/nwinkler/ProgramFiles/OF1-4/OpenFOAM-1.4.1-dev/src/turbulenceModels -IlnInclude -I. -I/scratch/nwinkler/ProgramFiles/OF1-4/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude -fPIC Make/linux64GccDPOpt/rhoTurbFoam.o -L/scratch/nwinkler/ProgramFiles/OF1-4/OpenFOAM-1.4.1-dev/lib/linux64GccDPOpt \
-lfiniteVolume -lmeshTools -lbasicThermophysicalModels -lspecie -lcompressibleTurbulenceModels -lOpenFOAM -liberty -ldl -lm -o /scratch/nwinkler/ProgramFiles/OF1-4/OpenFOAM-1.4.1-dev/applications/bin/linux64 GccDPOpt/rhoTurbFoam
/usr/bin/ld: cannot find -liberty
collect2: ld returned 1 exit status
make: *** [/scratch/nwinkler/ProgramFiles/OF1-4/OpenFOAM-1.4.1-dev/applications/bin/linux6 4GccDPOpt/rhoTurbFoam] Error 1
nikwin is offline   Reply With Quote
Old   November 17, 2008, 10:12
Default Here we go: 504-> locate li
  #35
Hrvoje Jasak
Here we go:
504-> locate libiberty
/usr/include/libiberty.h
/usr/lib64/libiberty.a
wooster*505-> rpm -q --whatprovides /usr/lib64/libiberty.a
binutils-devel-2.18.50.20080409-11.1
You are missing an rpm package.
Enjoy,
Hrv
Hrvoje Jasak
Old   January 30, 2009, 11:00
Default hi! foam users Can I instal
  #36
hamdi
hamcer is on a distinguished road
hi! foam users
Can I install Of-1.4.1 in user acount and, Of-1.5 in an other user acount in same machine.
Thanks for helps in adavance.
hamcer is offline   Reply With Quote
Old   January 30, 2009, 11:40
Default Hi Hamdi, Yes you can. Furt
  #37
Mathieu Olivier
mathieu is on a distinguished road
Hi Hamdi,
Yes you can. Furthermore, you can install both version in the same user account and switch from one version to another by sourcing the version you want (generally in your .bashrc file).
Mathieu
mathieu is offline   Reply With Quote
Old   January 30, 2009, 14:20
Default hi Marthieu, Thanks for thi
  #38
hamdi
hi Marthieu,
Thanks for this idea , I will do it..
Hamdi.
Installation problems indy OpenFOAM Installation 7 April 3, 2009 10:40
Installation Problems honcho OpenFOAM Installation 0 January 14, 2008 11:48
Problems on 64bit Installation Dietmar Schmidt Siemens 4 April 18, 2007 07:36
Installation problems shellbell1999 OpenFOAM Installation 9 April 6, 2006 14:29
Problems with installation jonititan OpenFOAM Installation 4 November 6, 2005 05:16
