OpenFOAM on MinGW crosscompiler hosted on Linux |
April 1, 2008, 17:52 |
Hi, Richard,
Thank you so m
#22 |
Allen Zhao
Rep Power: 17 |
Hi, Richard,
Thank you so much for your work. Sorry that I was sidetrip to another project these days and have not tested your patch. Just tested your patch on a SuSE 10.2 box, and it went much further than before. There is only one roadblock left, though: SOURCE=interfaceProperties.C ; mingw32-g++ -Dlinux -DDP -DWIN32 -DLITTLE_ENDIAN -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -O3 -DNDEBUG -DNoRepository -ftemplate-depth-40 -I/User/allen/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OSspecific/MSwindows/lnInclude -I/User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -c $SOURCE -o Make/linuxmingw32DPOpt/interfaceProperties.o In file included from /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/Time.H:47, from /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/GeometricField.C:28, from /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/GeometricField.H:570, from /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/GeometricScalarField. H:39, from /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/GeometricFields.H:35, from /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/volFields.H:38, from interfaceProperties.H:42, from interfaceProperties.C:35: /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/cpuTime.H:40:23: error: sys/times.h: No such file or directory In file included from /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/Time.H:47, from /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/GeometricField.C:28, from /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/GeometricField.H:570, from /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/GeometricScalarField. H:39, from /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/GeometricFields.H:35, from /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/volFields.H:38, from interfaceProperties.H:42, from interfaceProperties.C:35: /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/cpuTime.H:57: error: field 'startTime_' has incomplete type /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/cpuTime.H:58: error: field 'lastTime_' has incomplete type /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/cpuTime.H:59: error: field 'newTime_' has incomplete type make: *** [Make/linuxmingw32DPOpt/interfaceProperties.o] Error 1 ------------------------------------------ It sounds like the <sys/times.h> is not available. I checked the following location: hurricane:/usr/mingw/i686-pc-mingw32/include # ls sys/time*.h sys/time.h sys/timeb.h My minGW problem? Here is my MinGW installation: hurricane:/User/allen/OpenFOAM/OpenFOAM-1.4.1 # mingw32-gcc --version mingw32-gcc (GCC) 4.2.1-sjlj (mingw32-2) Copyright (C) 2007 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. I grab the source code from MinGW's site. Maybe I should just grab a vanilla gnu c as you have mentioned? |
April 1, 2008, 19:25 |
Still have the same issue (
#23 |
Allen Zhao
Rep Power: 17 |
Still have the same issue (<sys/times.h> missing) when using a 4.2.3 MinGW compiler (compiled from vanilla gnu C).
Any suggestions? I notice that the Linux' /usr/include/sys/ indeed has times.h there. But the MinGW gcc does not have it. Can it be my MinGW build process? |
April 1, 2008, 19:50 |
Hi Allen,
From the look of
#24 |
Richard Smith
Rep Power: 17 |
Hi Allen,
From the look of your error message: /User/allen/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/cpuTime.H:57: error: field 'startTime_' has incomplete type I think you've got include files in the wrong place. I'm guessing that is probably due to you having compiled another platform with this build prior to applying the patch (v4). I suggest you remove all lnInclude directories by using wcleanLnInclude in the top OpenFOAM directory. Also make sure that the Unix directory is deleted from src/OpenFOAM/OSspecific. Hopefully it's this include issue and not your MinGW configuration. Rich
Symscape, Computational Fluid Dynamics for all |
April 2, 2008, 13:17 |
Hi, Rich,
Thanks for the po
#25 |
Allen Zhao
Rep Power: 17 |
Hi, Rich,
Thanks for the pointers. Well, tried from scratch again, and still got the same errors. Where do you have struct tms defined in your MinGW header? In my MinGW, /usr/local/mingw/mingw32/include/ should be the location, and there is not <sys/times.h> there. Do you see times.h in your path? Maybe I miss something in my MinGW installation. Best regards, Allen |
April 2, 2008, 13:56 |
Hi Allen,
There shouldn't b
#26 |
Richard Smith
Rep Power: 17 |
Hi Allen,
There shouldn't be a reference to <sys/times.h> or tms in your OpenFOAM MinGW build - they only apply to Unix. So I think your MinGW configuration is fine. Somehow it seems that your MinGW OpenFOAM build is pointing to src/OSspecific/Unix, whereas it should be pointing to src/OSspecific/MSwindows. Check when compiling a source file that the build line includes: -I<openfoam-home>/src/MSwindows/lnInclude Check that the environment variable: export WM_OS_SPECIFIC=OSspecific/MSwindows is set in: .OpenFOAM-1.4.1/bashrc-mingw32 and that you have sourced it prior to compiling. Anyone else seen this problem or has a suggestion as to how to avoid it? Rich
April 2, 2008, 15:48 |
Hi, Rich,
Just check my Ope
#27 |
Allen Zhao
Rep Power: 17 |
Hi, Rich,
Just check my OpenFOAM directory, before patching, I have: <openfoam-home>/OpenFOAM-1.4.1/src/OpenFOAM/OSspecific/Unix/ OSspecific.H Unix.H cpuTime fileStat.C printStack.C timer.C Unix.C clockTime dummyPrintStack.C fileStat.H signals timer.H After OSspecific is removed and a the v4-patch is applied, I have this now: <openfoam-home>/OpenFOAM-1.4.1/src/OpenFOAM/OSspecific OSspecific.H I do not see the MSwindows directory. Any pointers? This seems to be the source of the trouble. The bashrc-mingw32 does contains the following line: # Operating System/Platform from Unix or MSwindows # ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ export WM_OS_SPECIFIC=OSspecific/MSwindows Best regards, Allen Zhao |
April 2, 2008, 16:07 |
Hi Allen,
Sorry, I mistyped
#28 |
Richard Smith
Rep Power: 17 |
Hi Allen,
Sorry, I mistyped where the MSwindows directory now lives - no longer under src/OpenFOAM. It should be: OpenFOAM-1.4.1/src/OSspecific/MSwindows There should be a single file in the old OSspecific directory: OpenFOAM-1.4.1/src/OpenFOAM/OSspecific/OSspecific.H as you correctly have. Sorry for the confusion. If you are still having problems, please post the error message from the compiler - especially with relation to which files it can't find. Rich
April 2, 2008, 17:02 |
Something interesting with the
#29 |
Allen Zhao
Rep Power: 17 |
Something interesting with the OpenFOAM source structure:
After unpack the big tar.gz file to OpenFOAM-1.4.1/ directory, I do not see src/OSspecific/ there, but rather src/OpenFOAM/OSspecific/ and src/OpenFOAM/OSspecific/Unix/ Just read the v4-mingw-openfoam-1-4-1.patch which use "src/OSspecific/" everywhere. I follow the http://www.symscape.com/openfoam-on-windows, first renamed src/OpenFOAM/OSspecific to src/OpenFOAM/OSspecific.orig, and then did `patch -p0 < v4-mingw-openfoam-1-4-1.patch`. This recreates the src/OSspecific directory, but there is only one file in it. Obviously I must have applied your patch incorrectly. ;( |
April 2, 2008, 17:10 |
That's correct.
src/OpenFOA
#30 |
Richard Smith
Rep Power: 17 |
That's correct.
src/OpenFOAM/OSspecific/Unix is gone and OSspecific.H is the only file in the src/OpenFOAM/OSspecific directory. src/OSspecific is created by the patch with subdirectories MSwindows and Unix that contain platform specific sources. Note src/OSspecific and src/OpenFOAM/OSspecific are different locations.
April 2, 2008, 17:14 |
Another thought.
It's not e
#31 |
Richard Smith
Rep Power: 17 |
Another thought.
It's not enough to just rename src/OpenFOAM/OSspecific, you have to move it out of the OpenFOAM distribution, otherwise the symbolic link builder will find it and add links to it - this could be the cause of your problems.
April 2, 2008, 18:06 |
Nice piece of kit!
W
#32 |
Jason Dale
Rep Power: 17 |
Nice piece of kit! Would love to get it working but my limited linux knowledge isn't helping....all day! My problem is that i get stuck at the building gcc stage. For OpenSUSE 10.3 32bit, it worked ok for this config MINGW_URL="http://heanet.dl.sourceforge.net/sourceforge/mingw" GCC_CORE_ARCHIVE="gcc-core-3.4.5-20060117-1-src.tar.gz" GCC_GPP_ARCHIVE="gcc-g++-3.4.5-20060117-1-src.tar.gz" GCC_G77_ARCHIVE="" GCC_OBJC_ARCHIVE="" GCC_JAVA_ARCHIVE="" GCC_ADA_ARCHIVE="" GCC_PATCH="" BINUTILS_ARCHIVE="binutils-2.18.50-20080109-src.tar.gz" MINGW_ARCHIVE="mingw-runtime-3.9.tar.gz" W32API_ARCHIVE="w32api-3.9.tar.gz" But then when I tried to compile OF, after a few seconds it crashed. So, I figured the gcc was so out of date from gcc so I have been trying gcc-xxx-4.2.1.tar.gz, the same as the OF 1.4.1 distribution (hope Im doing this right???) Next config is here, downloaded from different places: GCC_CORE_ARCHIVE="gcc-core-4.2.1.tar.gz" GCC_GPP_ARCHIVE="gcc-g++-4.2.1.tar.gz" GCC_GPP_ARCHIVE="" GCC_G77_ARCHIVE="" GCC_OBJC_ARCHIVE="" GCC_JAVA_ARCHIVE="" GCC_ADA_ARCHIVE="" GCC_PATCH="" BINUTILS_ARCHIVE="binutils-2.18.50-20080109-src.tar.gz" MINGW_ARCHIVE="mingw-runtime-3.14-src.tar.gz" W32API_ARCHIVE="w32api-3.11-src.tar.gz" Earlier, the compiler complained complained that MPRF was buggy so I updated GMP and MPRF and got a bit further. But now it seems to crash out at a point that mentions time.h??? (I saw this mentioned above) Here is my make.log file make.log.zip the error is at the end and configure.log config.log Now I'm stuck, would greatly appreciate some help... Thanks Jason |
April 2, 2008, 18:17 |
Hi Jason,
Rather than compi
#33 |
Richard Smith
Rep Power: 17 |
Hi Jason,
Rather than compile your own MinGW cross-compiler, I'd suggest using the pre-compiled binaries Bernhard mentioned at: http://sourceforge.net/projects/mingw-cross/ There's a chance I just got lucky when I compiled my own from scratch. If it helps I'm using Ubuntu 7.10 32bit. Rich
April 2, 2008, 18:39 |
Hi, Rich,
Thank you so much
#34 |
Allen Zhao
Rep Power: 17 |
Hi, Rich,
Thank you so much for the pointers. You must be right about the renaming of src/OpenFOAM/OSspecific. Once I removed the directory completely, I bypassed the road block and started to have codes compiled. Thanks again. |
April 2, 2008, 19:05 |
Hi Rich,
Yes I also tried
#35 |
Jason Dale
Rep Power: 17 |
Hi Rich,
Yes I also tried those too but maybe I made a mistake and got lost along the way. Is it the rpm's I need to download? I tried to install those but then my machine complained that the dependencies were not available or something. Could you list the exact files that I need to download and then what do I do after that? Install them and then just type ./Allmake? Will try it again tomorrow, maybe it was the updates that I needed that stopped that one working... Thanks Jason |
April 2, 2008, 19:37 |
Hi Jason,
I'll have to defe
#36 |
Richard Smith
Rep Power: 17 |
Hi Jason,
I'll have to defer you to Bernhard or Takuya for details on the pre-compiled MinGW compiler. Once you think the MinGW compiler is ready for action I'd suggest you compile a simple program such as: #include <iostream> int main(int argc, char* argv) { std::cout << "Hello World, I'm alive!" << std::endl return 0; } Transfer the compiled binary to your windows environment and make sure it works. Then it should be as easy as: cd <openfoam-home>; ./Allwmake Rich
April 2, 2008, 19:42 |
Anyone spot the mistakes?
a
#37 |
Richard Smith
Rep Power: 17 |
argv should be argv[] std::endl should be std::endl; Hope that's it.
April 3, 2008, 09:18 |
Hi Jason, Richard,
The mingw-
#38 |
Takuya OSHIMA
Rep Power: 20 |
Hi Jason, Richard,
The mingw-cross packages I used were binutils, gcc-core, gcc-g++, gcc-gfortran, runtime, w32api, but I don't know if all of them were indeed required. If it helps I did all under Ubuntu 7.10 on VMware. You have to adjust compiler executable names mingw32-gcc, mingw32-g++, mingw32-ld in OpenFOAM-1.4.1/wmake/rules/linuxmingw32/{c,c++,general} and OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc-ming32 to i386-mingw32-gcc, i386-mingw32-g++, i386-ming32-ld. Takuya |
April 3, 2008, 11:05 |
Thanks Takuya,
I'm getting
#39 |
Jason Dale
Rep Power: 17 |
Thanks Takuya,
I'm getting closer! If I download the rpms and try to install with the software installer I get the error here: Dependency Resolution Failed Unresolved dependencies: Installing mingw-binutils-2.18.50-4.fc8.i386[Local packages] There are no installable providers of rtld(GNU_HASH) for mingw-binutils-2.18.50-4.fc8.i386[Local packages] If I log out and log in as root and extract the rpms to the correct locations, then, log out again , the executables i386-mingw32-xxx can be found by the system. If I compile this #include <iostream> using namespace std; int main () { cout << "Hello World!"; return 0; } by typing for example >g++ helloworld.cpp I get an executable a.out it it runs fine. All good so far.. When I type >i386-mingw32-g++ helloworld.cpp I get the following error i386-mingw32-g++: error trying to exec 'cc1plus': execvp: No such file or directory (I also get this when trying with OF) I also had to download the mingw-gcc-objc rpm to make sure that this file cc1plus is there. Is this because I didn't install the mingw correctly, just extracted the files? Any idea what I can do? Regards Jason |
April 3, 2008, 11:10 |
Jason,
I think your problem
#40 |
Allen Zhao
Rep Power: 17 |
Jason,
I think your problem is due to the fact that those rpm are built on Fedora Core 8 box (FC8). Although the glibc version should be very close to OpenSUSE 10.3, but who knows? Just my 2 cents. Regards, Allen |
OpenFOAM 15x MinGW Windows Port | gocarts | OpenFOAM Installation | 1 | April 17, 2009 11:41 |
divide by zero FPE issue in OpenFOAM 141 MingW port | allenzhao | OpenFOAM Installation | 9 | September 22, 2008 18:13 |
OpenFOAM on SuSE Linux 100 | musahossein | OpenFOAM Installation | 4 | June 20, 2008 17:47 |
OpenFoam and Linux | Tomislav Maric | Main CFD Forum | 13 | October 25, 2007 05:45 |
OpenFOAM and linux distros | billy | OpenFOAM | 8 | September 8, 2005 02:43 |
