FOAM installation compiler issues
Old   February 9, 2009, 09:27
Default Hello, I am totally new to
Gareth
gareth__it_power is on a distinguished road
I am totally new to both OpenFoam and Linux Ubuntu, which is the OS I'm using. I'm probably pretty computer-illiterate compared to most of you lot!
I've had endless problems so far, but the latest one is something to do with gcc compiler (I don't really know what that is).
The excerpt from the InstalltionTest is below. I'd be very grateful for any advice please!
Thank you
Gareth
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.1
User version :
Minimum required: 4.2.0
gcc .../OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc
gzip 1.3.12 /bin/gzip
tar 1.19 /bin/tar
icoFoam
WARNING: Conflicting installations:
OpenFOAM settings : /home/itpower/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam
current path :
CRITICAL ERROR
gareth__it_power is offline   Reply With Quote
Old   February 9, 2009, 09:35
Default Hello Gareth, Is it possible
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hello Gareth,
Is it possible that you unpacked only the sources (OpenFOAM-1.5.General.gtgz)?
If so, you must unpack the binaries, too (OpenFOAM-1.5.linux64GccDPOpt.gtgz).
The order is or used to be important (first sources, second binaries).
I hope this is helpful,
Dragos
dmoroian is offline   Reply With Quote
Old   February 9, 2009, 10:01
Default Hi Gareth, It looks like yo
Mathieu Olivier
mathieu is on a distinguished road
Hi Gareth,
It looks like your installation is set to 32 bits. If it is what you really want, then you'll need to download the 32 bits binaries from this web page:
http://www.opencfd.co.uk/openfoam/linux.html
If your computer is 64 bits, then unset the $WM_32 variable in your .bashrc.
Mathieu
mathieu is offline   Reply With Quote
Old   February 9, 2009, 10:06
Default Dragos - yes, it's all unpacke
Gareth
Dragos - yes, it's all unpacked. Thanks
Matthieu - thanks for that, it sounds promising. Is it in the $HOME/.bashrc? How do I 'unset' it?
Old   February 9, 2009, 11:52
Default Just comment this line: # e
Mathieu Olivier
# export WM_32=1
in the $HOME/.bashrc file.
Mathieu
Old   February 9, 2009, 11:57
Default I don't have that line in the
Gareth
I don't have that line in the $HOME/.bashrc file!?
Old   February 9, 2009, 12:38
Default I think he meant in $HOME/Open
dmoroian's Avatar
Dragos
I think he meant in $HOME/OpenFOAM/OpenFOAM-1.5/etc/bashrc
Old   February 9, 2009, 15:12
Default Does this commands: echo $W
Mathieu Olivier
Does this commands:
echo $WM_ARCH
returns " linux " or " linux64 " ?
Typing " wm64 " in a terminal should set your environment in 64 bits. Thus try the following in a terminal:
wm64
foamInstallationTest
Mathieu
OpenFOAM 15 and CentOS 52 installation issues remrich OpenFOAM Bugs 9 March 20, 2009 02:48
OpenFOAM installation on AIX 53 with gnu 40 compiler chauvin OpenFOAM Installation 3 June 15, 2006 14:12
two issues on cfd guang ai Main CFD Forum 1 March 16, 2006 08:24
FOAM installation error gcc amp g hanks OpenFOAM Installation 9 January 26, 2006 15:14
Installation of Open foam 12 ds2taieb OpenFOAM Installation 1 January 16, 2006 00:46
