OF15dev installation error
Old   January 26, 2009, 10:20
Default Hi I got the error message
Velan
velan is on a distinguished road
Hi
I got the error message while installing openfoam-1.5-dev.... Does anybody knows what is that error. Earlier openfoam 1.5 was worked properly
+ wmake libso OpenFOAM
SOURCE=db/regIOobject/regIOobject.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/vc/OpenFOAM/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/vc/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/vc/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/regIOobject.o
lnInclude/PrimitivePatchCheck.C: In instantiation of 'Foam::PrimitivePatch<foam::face,> >':
lnInclude/polyPatch.H:79: instantiated from here
lnInclude/PrimitivePatchCheck.C:347: error: forming reference to reference type 'const Foam::pointField&'
lnInclude/PrimitivePatchCheck.C:429: error: forming reference to reference type 'const Foam::pointField&'
make: *** [Make/linuxGccDPOpt/regIOobject.o] Error 1
velan is offline   Reply With Quote
Old   January 26, 2009, 11:52
Default Hi Velan, You are doing m
Michael Jaworski
mike_jaworski is on a distinguished road
Hi Velan,
You are doing more than just installing OpenFOAM - you are compiling OpenFOAM. There are binaries available online if you don't need to compile yourself. Otherwise, did you make sure all of your package dependencies were installed? There are several forum threads that discuss the necessary items (binutils, flex, etc). I'd suggest checking those first.
Good luck!
Mike J.
mike_jaworski is offline   Reply With Quote
Old   January 26, 2009, 13:47
Default Hi Velan, Once you have ins
Mathieu Olivier
mathieu is on a distinguished road
Hi Velan,
Once you have installed all required packages, run the "foamInstallationTest" and make sure there are no problems except the missing icoFoam solver. Then, the compilation should work (maybe except for stuff associated with paraview; search the forum for more details on this).
Mathieu
mathieu is offline   Reply With Quote
Old   January 28, 2009, 05:05
Default Hi Velan, I also encountere
Naoko Oyama
naoko_oyama is on a distinguished road
Hi Velan,
I also encountered exactly the same situation. Actually I have managed to compile the previous OpenFOAM-1.5-dev released on 12th Jan, so I don't know why this time it does not work...
Hope we can solve this. Any ideas appreciated!
Naoko
naoko_oyama is offline   Reply With Quote
Old   February 4, 2009, 06:19
Default Thanks to Prof.Jasak and Wikki
Naoko Oyama
Thanks to Prof.Jasak and Wikki the problem was solved with the newer version!
(OpenFOAM-1.5-dev.General_2009-02-02.tgz)
Just a quick note.
Naoko
Old   February 10, 2009, 04:32
Default Hi, I have got the followi
Virginie Ehrlacher
virginie_e is on a distinguished road
I have got the following error message when I am trying to compile the OpenFOAM-1.5-dev version (02-02-2009)
g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/users/V1117324/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude -I/users/V1117324/OpenFOAM/OpenFOAM-1.5-dev/src/meshTools/lnInclude -IlnInclude -I. -I/users/V1117324/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/users/V1117324/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC Make/linux64GccDPOpt/refinementLevel.o -L/users/V1117324/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt \
-lfiniteVolume -lmeshTools -lOpenFOAM -liberty -ldl -lm -o /users/V1117324/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linux64GccDPOpt/refin ementLevel
/usr/bin/ld: cannot find -lfiniteVolume
collect2: ld returned 1 exit status
make[3]: *** [/users/V1117324/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linux64GccDPOpt/refi nementLevel] Error 1
make[2]: *** [refinementLevel] Error 2
make[2]: Target `application' not remade because of errors.
make[1]: *** [advanced] Error 2
make[3]: Warning: File `Make/linux64GccDPOpt/dontIncludeDeps' has modification time 0.13 s in the future
make[3]: warning: Clock skew detected. Your build may be incomplete.
I have tried to close th shell and recompile again but I still have the same problem. Can soemone tell me what I should do please? Thank you a lot
Virginie
virginie_e is offline   Reply With Quote
Old   February 10, 2009, 04:58
Default Just a hint: your finiteVolume
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Just a hint: your finiteVolume library is not compiled.
Try to follow the Allwmake scripts and run each command in a terminal to see exactly where it complains the first time and why.
Another hint is: try to do the compilation localy not on a nfs mounted directory. I think this is the cause of the following warning:
I hope this is helpful,
Dragos
dmoroian is offline   Reply With Quote
Old   February 13, 2009, 06:13
Default Thank you for your advise Drag
Virginie Ehrlacher
Thank you for your advise Dragos. I saw where teh problem was.
When OpenFOAM-1.5-dev compiles in the directory OpenFOAM-1.5-dev/src, everything runs fine until the following command:
wmake libso triSurface
And there is the error message i get :
SOURCE=triSurface/interfaces/STL/readSTLASCII.L ; flex --c++ -f $SOURCE ; mv lex.yy.cc Make/linux64GccDPOpt/readSTLASCII.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/users/V1117324/OpenFOAM/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/users/V1117324/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/users/V1117324/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -c Make/linux64GccDPOpt/readSTLASCII.C -o Make/linux64GccDPOpt/readSTLASCII.o
SOURCE=triSurface/interfaces/GTS/writeGTS.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/users/V1117324/OpenFOAM/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/users/V1117324/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/users/V1117324/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/writeGTS.o
flex: unknown flag '-'. For usage, try
flex --help
mv: cannot stat `lex.yy.cc': No such file or directory
g++: Make/linux64GccDPOpt/readSTLASCII.C: No such file or directory
g++: no input files
make: *** [Make/linux64GccDPOpt/readSTLASCII.o] Error 1
make: *** Waiting for unfinished jobs....
The problem comes from flex apparently... So I checked my flex version and the problem comes from the fact that my flex version does not have the option --c++ (flex --c++ -f $SOURCE ). The corresponding option in my case is -+
I tried to compile "manually" with this option and everything ran fine.
So my next question is the following: does someone know where I could change the options --c++ which are used to call flex into -+? Is it in a wmake file or rather in triSurface?
Another question otherwise: are there a lot of files which need to have flex with this option? If there are ten of them I can run them manually, otherwise, it will be difficult ...
I hope my problem is clear. I you need some more information, do not hesitate to ask.
Thanks,
Virginie
Old   February 13, 2009, 06:52
Default Hello Virginie, the general
Etienne Lorriaux
elorriaux is on a distinguished road
Hello Virginie,
the general compiling rules are located in the wmake directory. 'cd' to this directory, and find the file that fix this particular rule.
Generally, i don't want to waste my time exploring the different files, so i use grep (barbar method, but efficient) :
~/OpenFOAM/OpenFOAM-1.5-dev/wmake $ grep -R flex * | grep 'c++'
rules/General/flex:ltoo = flex $$SOURCE ; mv lex.yy.c $*.C ; $(CC) $(c++FLAGS) -c $*.C -o $@
rules/General/flex++:# For older versions of flex, the option --c++ is not avaliable
rules/General/flex++:#Ltoo = flex++ -f $$SOURCE ; mv lex.yy.cc $*.C ; $(CC) $(c++FLAGS) -c $*.C -o $@
rules/General/flex++:Ltoo = flex --c++ -f $$SOURCE ; mv lex.yy.cc $*.C ; $(CC) $(c++FLAGS) -c $*.C -o $@
rules/General/.svn/text-base/flex++.test.svn-base:Ltoo = flex++ $$SOURCE ; mv lex.yy.cc $*.C ; $(CC) $(c++FLAGS) -c $*.C -o $@
rules/General/.svn/text-base/flex++.svn-base:# For older versions of flex, the option --c++ is not avaliable
rules/General/.svn/text-base/flex++.svn-base:#Ltoo = flex++ -f $$SOURCE ; mv lex.yy.cc $*.C ; $(CC) $(c++FLAGS) -c $*.C -o $@
rules/General/.svn/text-base/flex++.svn-base:Ltoo = flex --c++ -f $$SOURCE ; mv lex.yy.cc $*.C ; $(CC) $(c++FLAGS) -c $*.C -o $@
rules/General/.svn/text-base/flex.svn-base:ltoo = flex $$SOURCE ; mv lex.yy.c $*.C ; $(CC) $(c++FLAGS) -c $*.C -o $@
rules/General/flex++.test:Ltoo = flex++ $$SOURCE ; mv lex.yy.cc $*.C ; $(CC) $(c++FLAGS) -c $*.C -o $@
rules/SiCortex64Gcc/flex++:Ltoo = flex --c++ -f $$SOURCE ; mv lex.yy.cc $*.C ; $(CC) $(c++FLAGS) -c $*.C -o $@
rules/SiCortex64Gcc/.svn/text-base/flex++.svn-base:Ltoo = flex --c++ -f $$SOURCE ; mv lex.yy.cc $*.C ; $(CC) $(c++FLAGS) -c $*.C -o $@
Edit your rules/General/flex++ and modify the flex option.
Have fun,
Etienne.
elorriaux is offline   Reply With Quote
Old   February 13, 2009, 07:04
Default Hello again Virginie, I looke
dmoroian's Avatar
Dragos
I looked in the OpenFOAM-1.5-dev directory and here is the result:
grep -r -e "--c++" *
wmake/rules/General/flex++:Ltoo = flex --c++ -f $$SOURCE ; mv lex.yy.cc $*.C ; $(CC) $(c++FLAGS) -c $*.C -o $@
Dragos
Old   February 13, 2009, 10:16
Default Thank you very much Etienne an
  #11
Virginie Ehrlacher
Thank you very much Etienne and Dragos, it works fine now!
Old   February 13, 2009, 10:23
Default Hello, You can also take in
  #12
Martin Beaudoin
mbeaudoin will become famous soon enough
You can also take into consideration the following comments in the file: OpenFOAM-1.5-dev/wmake/rules/General/flex++
.SUFFIXES: .L
# Switching to flex++ is an alternative
.L.dep:
$(MAKE_DEP)
Martin
mbeaudoin is offline   Reply With Quote
Error OF15dev interDyMFoam keyword agglomerator is undefined in dictionary eberberovic OpenFOAM Running, Solving & CFD 6 July 29, 2019 12:54
Error during Postprocessing in OF15dev hannes OpenFOAM Bugs 1 January 8, 2009 09:06
Installation error sukratu OpenFOAM Installation 6 September 16, 2007 23:46
Error after installation.. Nari Siemens 5 June 28, 2007 15:02
Installation Error rafal OpenFOAM Installation 3 February 2, 2006 12:43
