HowTo Make paraFoam from OpenFOAM15 work on OpenSuse11 by installing Qt435 in home directory |
#41 |
Rep Power: 17 ![]() |
Thank you very much!
It worked here on both Gentoo and Pclinuxos. |
#42 | |
Nugroho Adi
i followed your instruction to install paraview, but i installed it for OpenFOAM-1.5-dev but i got the error message like this below, when i tried to start paraview simulation15@user-laptop:~$ paraview paraview: symbol lookup error: /usr/lib/paraview/libpqCore.so: undefined symbol: _ZN11QFormLayout16staticMetaObjectE and this error when tried to run paraFoam : simulation15@user-laptop:~/OpenFOAM/simulation15-1.5-dev/run/tutorials/icoFoam/cavity$ paraFoam paraview: symbol lookup error: /usr/lib/paraview/libpqCore.so: undefined symbol: _ZN11QFormLayout16staticMetaObjectE could you please help me to solve this problem? |
#43 |
Daniel WEI (老魏)
Rep Power: 21 ![]() |
Okay, allow me put it here, I found paraFoam didn't work on my OpenSUSE-11.0,
qmake --version shows 4.4.3, gcc is 4.4.0, what have to note is the error: /usr/lib/libpython2.5.so, needed by blah blah, and I did: ln -s /usr/lib/libpython2.6.so.1.0 /usr/lib/libpython2.5.so and recompile util/postprocessing graphics/PV3FoamReader, then paraFoam works. ![]()
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
#44 |
Philip Cardiff
Rep Power: 34 ![]() ![]() |
Hi everybody,
I got ParaFoam to work on openSUSE 11.0 with Qt 4.4.0. I am using OpenFOAM-1.5-dev. I installed cmake 2.4-patch 6. I compiled paraview the usual way and then the PV3FoamReader the usual way too. It's ParaView-3.3-cvs. So far paraFoam looks good, I tried it on the icoFoam tutorial case. Kind Regards, Philip |
#45 |
Sebastian Gatzka
Rep Power: 20 ![]() |
Well, last time it worked and now I get this error when doing
sudo make install Code:
make[1]: *** [.obj/release-shared/qapplication.o] Fehler 1
Schrödingers wife: "What did you do to the cat? It's half dead!" |
#46 | |
Sebastian Gatzka
xorg-dev
#47 |
Sebastian Gatzka
After managing to compile the ParaView I am having trouble with my other linux software.
For example, when trying to run kate I get this symbol lookup error Code:
sega@deepblue:~$ kate kate: symbol lookup error: /usr/lib/libkde3support.so.4: undefined symbol: _ZN13QWidgetAction11eventFilterEP7QObjectP6QEvent
#48 | |
Sebastian Gatzka
#49 | |
Steve Hansel
#50 | |
Sebastian Gatzka
Which distribution are you using? I could fix the problem by deleting the Qt related entries in OpenFOAMs bashrc file on my Kubuntu 9.04 system.
#51 | |
Steve Hansel
I've compiled with several versions of QT (The one that 4.5 (I think, its the one that installs with package manager), 4.3.1 and 4.3.5. None of my compilations would run. I am currently trying the binary Thirdparty distribution, but I'm still getting the error about libPWCore.so (again trying different Qts) The strange thing is that library is right in the paraview tree, how can it be messed up? Steve |
#52 |
Steve Hansel
#53 | |
Sebastian Gatzka
I had to delete the entry to make it work on my Kubuntu 9.04
[OpenFOAM] ParaFoam error in OpenFOAM15 | asaha | ParaView | 24 | November 2, 2009 19:16 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 04:41 |
Howto install OpenFOAM on mandriva2009qt44 with Qt435 in home directory | gzy_1228 | OpenFOAM Installation | 0 | November 15, 2008 14:31 |
ParaFoam didnbt work | Leosding (Leosding) | OpenFOAM Installation | 11 | February 17, 2005 16:44 |
