Problem in installing OpenFoam15x
Old   February 23, 2009, 06:09
Default After I go to the source direc
Jun Huang
mmjhuang is on a distinguished road
After I go to the source directory and use the ./Allwmake command. The computer take many hours to build everything, but give a massage of error and last few sentences are as below, what's the problem:
collect2: ld returned 1 exit status
make[2]: *** [/home/jun/OpenFOAM/OpenFOAM-1.5.x/applications/bin/linuxGccDPOpt/mixtureAdiabat icFlameT] Error 1
make[2]: Leaving directory `/home/jun/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/thermophysical/mixture AdiabaticFlameT'
make[1]: *** [mixtureAdiabaticFlameT] Error 2
make[1]: Target `application' not remade because of errors.
make[1]: Leaving directory `/home/jun/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/thermophysical'
make: *** [thermophysical] Error 2
make: Target `application' not remade because of errors.
After that i execute the foramInstallationTest and the information are given as:
jun@jun-desktop:~/OpenFOAM/OpenFOAM-1.5.x/bin$ ./foamInstallationTest
Executing ./foamInstallationTest:
Checking basic setup...
Shell: bash
Host: jun-desktop
OS: Linux version 2.6.27-11-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/jun/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/jun/OpenFOAM/jun-1.5.x yes no
$WM_THIRD_PARTY_DIR /home/jun/OpenFOAM/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/jun/OpenFOAM/OpenFOAM-1.5.x yes yes yes
$FOAM_APPBIN ...1.5.x/applications/bin/linuxGccDPOpt yes yes yes
$FOAM_USER_APPBIN ...1.5.x/applications/bin/linuxGccDPOpt yes yes no
$WM_DIR /home/jun/OpenFOAM/OpenFOAM-1.5.x/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OAM/OpenFOAM-1.5.x/lib/linuxGccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...OpenFOAM/jun-1.5.x/lib/linuxGccDPOpt yes yes no
$MPI_ARCH_PATH ...penmpi-1.2.6/platforms/linuxGccDPOpt yes yes yes
Third party software
Software Version Location
gcc 4.3.1 .../OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc
gzip 1.3.12 /bin/gzip
tar 1.20 /bin/tar
icoFoam
WARNING: Conflicting installations:
OpenFOAM settings : /home/jun/OpenFOAM/OpenFOAM-1.5.x/applications/bin/linuxGccDPOpt/icoFoam
current path :
CRITICAL ERROR
Checking networking...
Action Result Crit
Pinging_jun-desktop Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
mmjhuang is offline   Reply With Quote
Old   February 23, 2009, 11:05
Default Hi Jun, I feel that y
Sayantan Datta Gupta
rishi123 is on a distinguished road
Hi Jun,
I feel that you have tried several procedures which I think just wouldn't be required. Could just follow the procedure mentioned in the below link. Hope you are using Ubuntu 8.04?
http://www.cfd-online.com/cgi-bin/Op...2166#POST32166
Fine try that out and let me know if there is any problem.
Bye
Rishi
Rishi
rishi123 is offline   Reply With Quote
Old   March 23, 2009, 07:41
Gareth
gareth__it_power is on a distinguished road
Did you managed to get around this error? I have the same problem and cannot get it to work!
Thanks
Gareth
gareth__it_power is offline   Reply With Quote
Old   March 24, 2009, 05:25
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
icoFoam
current path :
CRITICAL ERROR
Hello Jun,
This type of error appears in many threads. The answer is that the compilation of an OpenFOAM library has failed (and you didn't notice). This failure resulted in another compilation failure of the icoFoam solver.
My suggestion is to go to the top directory OpenFOAM-1.5.x and open the Allwmake file. It is a simple shell script and you can just copy and paste line by line into an xterm, and run. Then you will see exactly where your failure lies, and pinpoint the problem.
Dragos
dmoroian is offline   Reply With Quote
Pls help last problem to be solved for installing OPENfoam daydayuper OpenFOAM Installation 5 November 9, 2008 05:59
Problem installing OpenFOAM 141 sachin OpenFOAM Installation 2 February 22, 2008 11:20
Problem installing on 64bit with ver13 jonititan OpenFOAM Installation 5 May 12, 2006 19:42
problem about installing FOAM linux freshman Main CFD Forum 6 November 4, 2004 11:59
Problem in license file installing rakib FLUENT 0 March 2, 2003 04:30
