December 3, 2008, 21:25 |
The following is what I get wh
The following is what I get when trying to follow the README to a tee. This is a squeaky clean ubuntu install. Any advice greatly recommended. I already tried the 'sudo apt-get libqt4-dev' successfully, as appeared to be the solution in another thread.
./buildParaView3.3-cvs Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /home/i3enhamin/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /home/i3enhamin/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc -- Check for working C compiler: /home/i3enhamin/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -- Check for working C compiler: /home/i3enhamin/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -- broken CMake Error: The C compiler "/home/i3enhamin/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc" is not able to compile a simple test program. It fails with the following output: /usr/bin/make -f CMakeFiles/cmTryCompileExec.dir/build.make CMakeFiles/cmTryCompileExec.dir/build make[1]: Entering directory `/home/i3enhamin/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFil es/CMakeTmp' /home/i3enhamin/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/bin/cmake -E cmake_progress_report /home/i3enhamin/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFile s/CMakeTmp/CMakeFiles 1 Building C object CMakeFiles/cmTryCompileExec.dir/testCCompiler.o /home/i3enhamin/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -o CMakeFiles/cmTryCompileExec.dir/testCCompiler.o -c /home/i3enhamin/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFile s/CMakeTmp/testCCompiler.c /home/i3enhamin/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../libexec/gcc /i686-pc-linux-gnu/4.3.1/cc1: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory make[1]: *** [CMakeFiles/cmTryCompileExec.dir/testCCompiler.o] Error 1 make[1]: Leaving directory `/home/i3enhamin/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFil es/CMakeTmp' make: *** [cmTryCompileExec/fast] Error 2 CMake will not be able to correctly generate this project. -- Configuring done make: *** No targets specified and no makefile found. Stop. done i3enhamin@i3enhamin-laptop:~/OpenFOAM/OpenFOAM-1.5/bin$ ./buildParaView3.3-cvs |
December 3, 2008, 21:58 |
I instaled OpenFOAM-1.5 on a P
Lee
I instaled OpenFOAM-1.5 on a PC running CentOS-5.1. I got a problem with paraView too. I reinstalled the cmake package and Qt-4.3.5 to fix the problem. It seems that paraView does not work with Qt-4.3.1.
Good luck! |
December 4, 2008, 01:45 |
It looks like something in thi
It looks like something in this sequence fixed it.
i.e. sudo apt-get install gcc sudo apt-get install gcc-4.2 ... and so on gcc gcc-4.2 gcc-4.2-base libqt-4-core libqt-4-debug libqt-4-dev libqt-4-gui libqt-4-qt3support libqt-4-sql libqthreads-12 libmpfr-dev |
December 4, 2008, 03:38 |
if you are going to compile pa
Leonardo Honfi Camilo
Rep Power: 17 |
if you are going to compile paraview in ubuntu, make sure you have those two packages, just search for them in synaptic:
libmpfr-dev libmpfr1|dbl |
February 20, 2009, 19:13 |
My issue with compiling paraVi
John Weaver
Rep Power: 17 |
My issue with compiling paraView is slightly different. The OS is ubuntu 8.04 and I have a correct version of qmake
QMake version 2.01a Using Qt version 4.3.4 in /usr/lib Here is the error that I get when I try to build paraView ~/OpenFOAM/ThirdParty$ buildParaView3.3-cvs Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /home/john/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /home/john/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc -- Check for working C compiler: /home/john/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- Check for working C compiler: /home/john/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- broken CMake Error: The C compiler "/home/john/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc" is not able to compile a simple test program. It fails with the following output: /usr/bin/make -f CMakeFiles/cmTryCompileExec.dir/build.make CMakeFiles/cmTryCompileExec.dir/build make[1]: Entering directory `/home/john/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles/ CMakeTmp' /home/john/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/bin/cmake -E cmake_progress_report /home/john/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles/C MakeTmp/CMakeFiles 1 make[1]: /home/john/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/bin/cmake: Command not found make[1]: Leaving directory `/home/john/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles/ CMakeTmp' make[1]: *** [CMakeFiles/cmTryCompileExec.dir/testCCompiler.o] Error 127 make: *** [cmTryCompileExec/fast] Error 2 I am new to using Linux and have gotten to this point in the installation of OF 1.5 using the README notes and trying the suggestions in this forum. Any ideas as to why the cmake command is not being found would be much appreciated. |
February 22, 2009, 14:12 |
Hi John,
You can che
Sayantan Datta Gupta
Rep Power: 17 |
Hi John,
You can check out the below post and I must say the installation in Ubuntu 8.04 is much easier than any other OS. you just have to follow a different procedure before building ParaView3.3-cvs. Fine and let me know if any problem. http://www.cfd-online.com/cgi-bin/Op...2166#POST32166 Bye Rishi
Rishi |
February 22, 2009, 19:56 |
Hi Rishi
Thanks for your re
John Weaver
Rep Power: 17 |
Hi Rishi
Thanks for your reply. I ve gone through the procedure (including not executing the rm -rf ParaView3.3-cvs/platforms command) as well as updating the bashrc file, but am getting the following reply when I execute the ccmake command: john@john-laptop:~/OpenFOAM/ThirdParty$ ccmake $HOME/OpenFOAM/ThirdParty/ParaView3.3-cvs bash: /home/john/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/bin/ccmake: No such file or directory The comment "No such file or directory" does not make sense to me, since there is an executable file named ccmake in the /home/john/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/bin/ folder Thanks, John |
February 23, 2009, 10:49 |
Hi John,
I suppose you must c
Rep Power: 17 |
Hi John,
I suppose you must check out whether cmake or make is installed in the system using the synaptic manager. It is a possibility that it tries to run ccmake in the OpenFOAM directory and the cmake in the system to find out the system settings. Pl. try that out because its given in that paraview-wiki site, they load and install ccmake before setting ccmake. But UBUNTU has ccmake in synaptic (if not check it out in install and remove software). Fine try it and let me know if any problem. Bye Rishi.
Rishi |
February 24, 2009, 00:49 |
Hi Rishi
Success. Thanks f
#9 |
John Weaver
Rep Power: 17 |
Hi Rishi
Success. Thanks for your advice. The breakthrough occurred when I used the script in the following post: http://www.cfd-online.com/OpenFOAM_D...tml?1222736035 I also had to change the mention of cmake 2.4.6 to 2.4.7 (which is the version that is included now with Ubuntu 8.04) in the bashrc file in the OpenFoam-1.5/etc/apps/paraview folder. John |
[OpenFOAM] OF15 for Ubuntu804 buildParaView33cvs stoped suddenly | yan | ParaView | 4 | October 25, 2009 20:21 |
BuildParaView33cvs problem | jcw | OpenFOAM Installation | 11 | October 27, 2008 08:28 |
CMake Error about testCCompilerc | wu_wen | OpenFOAM Installation | 3 | September 20, 2008 00:06 |
Cmake 243 not 242 | unoder | OpenFOAM Installation | 4 | August 29, 2006 13:30 |
Fatal error error writing to tmp No space left on device | maka | OpenFOAM Installation | 2 | April 3, 2006 09:48 |
