Building paraview
Old   February 23, 2009, 13:46
Default centOS 5.0 at step 7 of in
Neil McFadyen
neilm is on a distinguished road
centOS 5.0
at step 7 of installation:
removed platforms
added addCMakeVariable "VTK_USE_RPATH:BOOL=OFF" to buildParaViewFunctions
buildParaView3.3-cvs
CMake Error: Error in cmake code at
/home/user1/OpenFOAM/ThirdParty/ParaView3.3-cvs/DartConfig.cmake:1:
INCLUDE Could not find include file: /home/user1/OpenFOAM/ThirdParty/ParaView3.3-cvs/CTestConfig.cmake
-- Found Qt-Version 4.3.5
-- Application: default ParaView Client enabled
-- Application: Custom Server enabled
-- Application: DobranoViz enabled
-- Plugin: Prism enabled
CMake Error: This project requires some variables to be set,
and cmake can not find them.
Please set the following variables:
QT_X11_ICE_LIBRARY (ADVANCED)
QT_X11_SM_LIBRARY (ADVANCED)
QT_X11_Xext_LIBRARY (ADVANCED)
QT_XCURSOR_LIBRARY (ADVANCED)
QT_XINERAMA_LIBRARY (ADVANCED)
QT_XI_LIBRARY (ADVANCED)
QT_XRANDR_LIBRARY (ADVANCED)
QT_XRENDER_LIBRARY (ADVANCED)
where do I set these and what do I set them to?
neilm is offline   Reply With Quote
Old   February 23, 2009, 23:39
Default Hi Neil, You can set your var
Sayantan Datta Gupta
rishi123 is on a distinguished road
Hi Neil,
You can set your variables using ccmake. The below link would help you with the variables to be set. In this site check out "Configure Paraview with cmake" and mind it you need to have cmake installed in your system for it to work. Also this ccmake should be run only in the particular paraview3.3-cvs folder.
http://paraview.org/Wiki/ParaView:Build_And_Install
Try this out and let me know if there is any problem. Fine.
Bye
Rishi
Rishi
rishi123 is offline   Reply With Quote
Old   February 24, 2009, 11:05
Default problem solved by installing:
Neil McFadyen
libXi-devel
libXcursor-devel
libXrender-devel
libXrandr-devel
libICE-devel
libXinerama-devel
libSM-devel
libXext-devel
Old   February 24, 2009, 11:09
Neil McFadyen
libXi-devel
libXcursor-devel
libXrender-devel
libXrandr-devel
libICE-devel
libXinerama-devel
libSM-devel
libXext-devel
Old   February 24, 2009, 11:13
Neil McFadyen
libXi-devel
libXcursor-devel
libXrender-devel
libXrandr-devel
libICE-devel
libXinerama-devel
libSM-devel
libXext-devel
Old   February 24, 2009, 11:30
Neil McFadyen
libXi-devel
libXcursor-devel
libXrender-devel
libXrandr-devel
libICE-devel
libXinerama-devel
libSM-devel
libXext-devel
Old   February 24, 2009, 11:51
Default new error: Building CXX o
Neil McFadyen
new error:
[ 52%] [ 52%] Building CXX object Utilities/VTKClientServer/Graphics/CMakeFiles/vtkGraphicsCS.dir/vtkWindowedSincP olyDataFilterClientServer.o
Building CXX object Utilities/VTKClientServer/Graphics/CMakeFiles/vtkGraphicsCS.dir/vtkGraphicsCSIni t.o
Linking CXX shared library ../../../bin/libvtkGraphicsCS.so
[ 52%] Built target vtkGraphicsCS
make: *** [all] Error 2
done
Old   May 6, 2009, 13:21
matteo lombardi
matteoL is on a distinguished road
hey neil, have you managed to solve that error? i have the same one...
thanks,
matteo
matteoL is offline   Reply With Quote
Old   October 12, 2009, 14:03
Default builParaView3.3-cvs got following error
Nirmal
nirmalrishi is on a distinguished road
When I tried to run buildParaView3.3-cvs after rmoving platforms directory, i got the following messages.
[ 52%] [ 52%] Building CXX object Utilities/VTKClientServer/Graphics/CMakeFiles/vtkGraphicsCS.dir/vtkWindowedSincPolyDataFilterClientServer.o
Building CXX object Utilities/VTKClientServer/Graphics/CMakeFiles/vtkGraphicsCS.dir/vtkGraphicsCSInit.o
done
please let me know, how can i avoid this and complete the installation?
nirmalrishi is offline   Reply With Quote
Error building DICOMAppHelper during ParaView compilation geoffjay OpenFOAM Installation 1 May 7, 2008 14:07
Flow over building Vedavyasa M FLUENT 0 February 25, 2008 05:08
[OpenFOAM] Building Paraview with reader builtin instead of parafoam script tj22 ParaView 2 April 7, 2006 13:55
[OpenFOAM] HI all I cant find display button in paraview when i execute cavity tutorial there is only parameter button in the paraview chan ParaView 2 February 13, 2006 08:37
cfd in building services abdul Phoenics 2 August 22, 2002 05:00
