October 28, 2008, 11:39 |
I wasn't aware of this precomp
#61 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I wasn't aware of this precompiled version. If it works for you: Use it. But be aware that there comes the time in the live of a man where the precompiled version is not enough and he wants to recompile his installation (but that is some time after the tutorials)
The reason why I'm only releasing patches is that my disk-image is hopelessly intermixed with other stuff and I don't have the disk space to build another image for distribution (plus I'm too lazy) Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
October 28, 2008, 13:58 |
I am trying to compile on OS X
#62 |
sesha
Rep Power: 17 |
I am trying to compile on OS X10.5 and when I run the Allmake in the directory doc, I get
+ chmod a+rX /Users/stsriniv/OpenFOAM/OpenFOAM-1.5 + chmod a+rX /Users/stsriniv/OpenFOAM/OpenFOAM-1.5/doc + chmod -R a+rX Doxygen + cd Doxygen + ./Allwmake + umask 22 + rm -rf html latex man + doxygen ./Allwmake: line 6: doxygen: command not found + chmod -R a+rX ./ Allmake run from OpenFOAM-1.5 directory seem to have gone through ok. Can someone suggest something on this? Thanks, ss |
October 28, 2008, 15:40 |
There is an obvious error
#63 |
Hua Zen
Rep Power: 17 |
There is an obvious error.You need to install doxygen first,which is not included in OpenFOAM. |
October 28, 2008, 15:54 |
Hi ss!
Hua is right. The si
#64 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi ss!
Hua is right. The simplest thing would be to install it via "port install doxygen" IF you got port installed. But there is a binary distribution for the Mac at the website if I'm not mistaken Bernhard
October 29, 2008, 11:19 |
Thanks Hua and Bernhard,
I
#65 |
sesha
Rep Power: 17 |
I was not defining the path to doxygen correctly. It seems to be compiling now. I hope there will be no further issues with the installation! Thanks again ss |
November 1, 2008, 18:24 |
I am having issues with 'dot'
#66 |
sesha
Rep Power: 17 |
I am having issues with 'dot' now. It says 'dot command not found'. For some reason the Allwmake in doc/ directory cannot undertand that path of Doxygen. I had to explicitly state the path for doxygen. But am not sure if this is the right thing.
Any ideas? Thanks, ss |
November 2, 2008, 01:48 |
Hi
For my linux system,"dot"
#67 |
Hua Zen
Rep Power: 17 |
Hi
For my linux system,"dot" command is contained in the package "graphviz",hope it helps. |
January 15, 2009, 12:56 |
Hi Pierre-Oliver,
Were you
#68 |
Sung-Eun Kim
Rep Power: 17 |
Hi Pierre-Oliver,
Were you able to sort out how to apply patches to 1.5-x on Mac? If you did, can you tell me how? |
January 18, 2009, 12:28 |
Hi Ilja
You get this error
#69 |
Michael Wild
Rep Power: 17 |
Hi Ilja
You get this error because the disk image I provide is read-only. I made this choice mainly because the whole thing is intended to be used by the students attending our course. And they are very likely to shoot themselves in the foot (yes, copying a folder from one place to another is a real challenge). You probably forgot to change $FOAM_APPBIN into $FOAM_USER_APPBIN in the file /Users/ilja/OpenFOAM/ilja-1.5/run/applications/solvers/incompressible/turbFoam/M ake/files. If you make this change, the build system will put the resulting application into your user-disk image and not into the one of OpenFOAM. As an alternative you can use the program 'hdiutil' to convert the disk image into one which is writable, however I don't recommend that (which is also why I don't explain it here how to use it: man hdiutil will tell you). I hope this helps Michael |
January 18, 2009, 13:17 |
Dear Michael!
Thank You for
#70 |
Ilja
Rep Power: 17 |
Dear Michael!
Thank You for help. Code has compiled when I did chandes. PS. Sorry for my bad English. |
January 18, 2009, 13:23 |
Dear Michael!
Thank You for
#71 |
Ilja
Rep Power: 17 |
Dear Michael!
February 18, 2009, 13:10 |
if have some Problems c
#72 |
Tino
if have some Problems compiling openfoam. System: Powerbook G4 10.4.11 I have downloaded openfoam, thirdparty and the patches. An extern hard-drive (case-sensitive fs) i link to $HOME/OpenFOAM Then i apply the patches, link the bashrc, resource and start Allwmake. The first error ist this (after e few minutes): + wmake libso zlib-1.2.3 ld: flag: -undefined dynamic_lookup can't be used with MACOSX_DEPLOYMENT_TARGET environment variable set to: 10.1 /usr/bin/libtool: internal link edit command failed make: *** [/Users/tino/OpenFOAM/OpenFOAM-1.5/lib/darwinPpcDPOpt/libz.dylib] Error 1 And the compilation ends with the following error: (after 6 hours) /usr/bin/ld: can't locate file for: -lOpenFOAM collect2: ld returned 1 exit status make[2]: *** [/Users/tino/OpenFOAM/OpenFOAM-1.5/applications/bin/darwinPpcDPOpt/mixtureAdiaba ticFlameT] Error 1 make[1]: *** [mixtureAdiabaticFlameT] Error 2 make[1]: Target `application' not remade because of errors. make: *** [thermophysical] Error 2 make: Target `application' not remade because of errors. + '[' '' = doc ']' Thank You for help. Regards Tino |
February 19, 2009, 06:16 |
i have find a soluti
#73 |
Tino
i have find a solution. You have to install XCodeTools 2.5 from apples homepage. On my Tiger-DVD i had an older Version. Now i can compile OpenFOAM. Thank You Regards Tino |
March 1, 2009, 23:32 |
Good evening,
I was wonderi
#74 |
Pierre-Olivier Dallaire
Rep Power: 17 |
Good evening,
I was wondering if somebody tried to compile it on Mac OS X for 64-bit execution / I believe the flag is "-arch x86_64" ? Best regards, PO |
March 2, 2009, 08:03 |
Hi PO!
Yes. For the ld-comm
#75 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi PO!
Yes. For the ld-command (in rules/darwinIntel/general). For the compiler calls use "gcc -m64" instead of "gcc". I once tried it and it seemed to compile alright. Didn't compile the Paraview-filter because I guess for that you'd have to recompile paraview in 64 bit. Bernhard
March 2, 2009, 08:15 |
Bernhard,
for some reason,
#76 |
Rep Power: 17 |
Bernhard,
for some reason, the compilation breaks at the very beginning : hoard-371/src/userealtls.cpp:261: warning: unused variable 't' make: *** [Make/darwinIntelDPOpt/libhoard.o] Error I still have the warning when compiling 32 bits but the library builds which is not the case here. Any suggestion ? Thanks PO |
March 2, 2009, 08:35 |
The warning is not the problem
#77 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The warning is not the problem. The problem must be further up. Look for an Error.
March 2, 2009, 08:49 |
Basically, because libhoard fa
#78 |
Rep Power: 17 |
Basically, because libhoard fails (make: *** [Make/darwinIntelDPOpt/libhoard.o] Error 1), those components do not build :
make: *** [Make/darwinIntelDPOpt/dlmalloc.o] Error 1 make: *** [Make/darwinIntelDPOpt/printStack.o] Error 1 make: *** [/Users/podallaire/OpenFOAM/OpenFOAM-1.5.x/lib/darwinIntelDPOpt/libOpenFOAM.dyli b] Error 1 ... which is not the case when compiling 32 bits Thanks PO |
March 2, 2009, 15:21 |
Hi PO!
This patch should so
#79 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi PO!
This patch should solve the problem with printStack. Please apply with care. I'm not quite sure whether it is the latest (correct) version and as I don't have the need for a 64bit-version I don't want to spend the time reapplying/testing it. Bernhard
March 2, 2009, 15:34 |
Hi Bernhard,
thanks for loo
#80 |
Rep Power: 17 |
Hi Bernhard,
thanks for looking at this / it looks the the file did not upload correctly, can you copy the patch content direclty here. It seems that the problem with libhoard is not only with the darwin platform : http://www.cfd-online.com/OpenFOAM_D...s/1/10650.html Thanks PO |
New version fluent file open in Old version ? | MANOJKUMAR | FLUENT | 2 | July 10, 2013 04:43 |
Difference between Version 6.3 and Version 6.2 | erikaj | FLUENT | 0 | October 11, 2007 12:36 |
LES with version 6.3 | Steve | FLUENT | 0 | April 26, 2007 15:00 |
SEM in the 3.5 version | Anis | Phoenics | 0 | May 5, 2006 12:41 |
BUG IN VERSION 3.5!!!!!!!! | AERODYNAMIFUN | Phoenics | 0 | May 17, 2004 19:24 |
