October 20, 2008, 03:12 |
Again you are right. Th
#41 |
Pattyn Eric
Rep Power: 17 |
Again you are right. The version given by ld --version was 2.15. I have successfully installed Binutils 2.18, then gmp 4.2.2 but I have again a problem with mpfr 2.3.2. The make command gives a problem "warning: Clock skew detected. your build may be incomplete". I have read on this forum that it should not be important. But when running "make check", I have an error (see below). Should I install mpfr even if there is this error ? When I suppressed the additional line in my .bashrc file, the gcc compiler used is a 3.4.6-8 version. Could it be the problem ? Should I install mpfr 2.3.1 and not mpfr 2.3.2 ? Thank you. ranlib .libs/libfrtests.a creating libfrtests.la (cd .libs && rm -f libfrtests.la && ln -s ../libfrtests.la libfrtests.la) gcc -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_STDARG=1 -DHAVE_SYS_TIME_H=1 -DHAVE_SETLOCALE=1 -DHAVE_GETTIMEOFDAY=1 -DMPFR_HAVE_FESETROUND=1 -DHAVE_DENORMS=1 -DHAVE_FLOOR=1 -DHAVE_CEIL=1 -DHAVE_LDOUBLE_IEEE_EXT_LITTLE=1 -DHAVE_ATTRIBUTE_MODE=1 -DHAVE_ALLOCA_H=1 -I. -I.. -I.. -Wall -Wmissing-prototypes -g -O2 -MT tversion.o -MD -MP -MF .deps/tversion.Tpo -c -o tversion.o tversion.c mv -f .deps/tversion.Tpo .deps/tversion.Po /bin/sh ../libtool --tag=CC --mode=link gcc -Wall -Wmissing-prototypes -g -O2 -o tversion tversion.o libfrtests.la -lm ../libmpfr.la -lgmp gcc -Wall -Wmissing-prototypes -g -O2 -o .libs/tversion tversion.o ./.libs/libfrtests.a -lm ../.libs/libmpfr.so -lgmp -Wl,--rpath -Wl,/usr/local/lib ../.libs/libmpfr.so: undefined reference to `__gmp_get_memory_functions' collect2: ld returned 1 exit status make[2]: *** [tversion] Fehler 1 make[2]: Leaving directory `/net/ric_home/ep4/Desktop/mpfr-2.3.2/tests' make[1]: *** [check-am] Fehler 2 make[1]: Leaving directory `/net/ric_home/ep4/Desktop/mpfr-2.3.2/tests' make: *** [check-recursive] Fehler 1 |
October 20, 2008, 07:35 |
I haven't had problems with cl
#42 |
Ville Tossavainen
Rep Power: 17 |
I haven't had problems with clock skew. Anyway, have you compiled mpfr this way (I think gmp wasn't found):
./configure --prefix=/x/mpfr-2.3.1 --with-gmp=/x/gmp-4.2.2 |
October 20, 2008, 07:51 |
The command ./configure --pref
#43 |
Pattyn Eric
Rep Power: 17 |
The command ./configure --prefix=/x/mpfr-2.3.1 --with-gmp=/x/gmp-4.2.2 says that the gmp.h and the libgmp files are not of the same version.
I only have installed one thing found on http://gmplib.org/#DOWNLOAD. Should I installed something else ? checking for alloca... yes checking for __gmpz_init in -lgmp... yes checking if gmp.h version and libgmp version are the same... (4.2.4/4.1.4) no configure: WARNING: 'gmp.h' and 'libgmp' seems to have different versions or configure: WARNING: we cannot run a program linked with GMP (if you cannot configure: WARNING: see the version numbers above). configure: WARNING: However since we can't use 'libtool' inside the configure, configure: WARNING: we can't be sure. See 'config.log' for details. configure: creating ./config.status config.status: creating Makefile config.status: creating tests/Makefile config.status: creating mparam.h config.status: executing depfiles commands |
October 21, 2008, 02:46 |
It's getting quite tricky. Che
#44 |
Ville Tossavainen
Rep Power: 17 |
It's getting quite tricky. Check the MPFR documentation (INSTALL file in source code) and try to add more parameters to find GMP. Do you have a system admistrator who can help you?
October 21, 2008, 03:25 |
Like you suggested yest
#45 |
Pattyn Eric
Rep Power: 17 |
Like you suggested yesterday, the problem was related to the path for gmp. There is different place where libgmp files appear. MPFR has compiled correctly with the command: ./configure --with-gmp-lib=/usr/local/lib Nevertheless, I still have the my first error when compiling paraview. Maybe, it could be also due to the same problem. Does somoene know how i could change the path definitively ? I also accept any other suggestions... Thank you Eric |
October 21, 2008, 05:28 |
You should now include the lib
#46 |
Ville Tossavainen
Rep Power: 17 |
You should now include the libraries for the new compiler:
export LD_LIBRARY_PATH=/usr/local/lib:/x/mpfr-2.3.1/lib |
October 21, 2008, 09:12 |
I'm now installing Qt 4.4.3 bu
#47 |
Pattyn Eric
Rep Power: 17 |
I'm now installing Qt 4.4.3 but I have not suppressed the old one. They are not in the same directories:
old one: /usr/lib64/qt-3.3.3 new one: /us/local/lib64/Qt-4.4.3 When i compile Paraview, it uses the old version. qmake --version gives me 3.3.3.. What can i do to change the path and the application used for the compilation of Paraview? Thanks a lot Eric |
October 21, 2008, 09:43 |
Stupid question: after 'hash -
#48 |
Mark Olesen
Rep Power: 40 |
Stupid question: after 'hash -r' or 'rehash', does "type qmake" (or "which qmake") return /usr/local/bin/qmake first?
October 21, 2008, 09:48 |
The commands you proposed me g
#49 |
Pattyn Eric
Rep Power: 17 |
The commands you proposed me give these results:
[root@wobwslx2 ep4]# hash -r [root@wobwslx2 ep4]# type qmake qmake is /usr/bin/qmake [root@wobwslx2 ep4]# which qmake /usr/bin/qmake [root@wobwslx2 ep4]# rehash bash: rehash: command not found Eric |
October 21, 2008, 10:40 |
Eric,
If you get "qmake is
#50 |
Mark Olesen
Rep Power: 40 |
Eric,
If you get "qmake is /usr/bin/qmake", then the old qmake is apparently still being found first in your PATH (as you saw with qmake --version). It seems reasonable that cmake also takes this first one (/usr/bin/qmake) and determines that you'd likely wish to link in /usr/lib64/qt*. Try placing the new one first in your PATH. |
October 21, 2008, 10:44 |
My question was: how should i
#51 |
Pattyn Eric
Rep Power: 17 |
My question was: how should i try to place the new one first in my path.
I don't know which command i should use. Eric |
October 21, 2008, 13:55 |
Eric,
Assuming that you're
#52 |
Mark Olesen
Rep Power: 40 |
Eric,
Assuming that you're not suffering a minor blackout, you need to grab yourself a basic book on Unix/Linux. You seem to be using bash/ksh/sh, since 'hash -r' worked, but 'rehash' (csh) didn't. To see your path: echo $PATH Add a directory to the front of your path: PATH=/usr/local/bin:$PATH; export PATH The export isn't actually needed, since PATH has already been exported, but it doesn't hurt. If 'type qmake' still points to the old version, try 'hash -r' to clear the rehash the lookup and see if 'type qmake' and 'qmake --version' are doing what you want. |
October 22, 2008, 03:11 |
Thank you for your h
#53 |
Pattyn Eric
Rep Power: 17 |
Thank you for your help. Now it works except that the version 4.4.3 is not supported. I had read that but actually i hadn't found a version 4.3.x. Does somebody know where i could dowload this version? Eric |
October 22, 2008, 04:07 |
Search through the forum. Some
#54 |
Mark Olesen
Rep Power: 40 |
Search through the forum. Someone was complaining about the Readme being slightly inaccurate, since you can actually use a newer qt if you edit a file (or two). You should be posting further stuff on that thread, since you've strayed quite far from the original topic (libmpfr.so.1 not found).
February 4, 2009, 10:32 |
Hi. I'm trying to use the foam
#55 |
John Paul Handrigan
Rep Power: 17 |
Hi. I'm trying to use the foamToTecPlot utility, but I get the following error. I don't have root access, and I'm wondering if there's anyway to fix the below problem. I get the same 'libmpfr.so.1' error that has been mentioned above. Thanks in advance!
[actmodel@r4-bcc-loki11 foamToTecplot]$ wmake make: Warning: File `Make/linux64GccDPOpt/dontIncludeDeps' has modification time 0.00052 s in the future make: warning: Clock skew detected. Your build may be incomplete. SOURCE=foamToTecplot.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-styl e-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/mnt/hypatia/linux_home/rhel4_home/actmodel/OpenFOAM/ OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/mnt/hypatia/linux_home/rhel4_home/actmodel/OpenFOAM/OpenFO AM-1.5/src/OpenFOAM/lnInclude -I/mnt/hypatia/linux_home/rhel4_home/actmodel/OpenFOAM/OpenFOAM-1.5/src/OSspecif ic/Unix /lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/foamToTecplot.o /mnt/hypatia/linux_home/rhel4_home/actmodel/OpenFOAM/ThirdParty/gcc-4.3.1/platfo rms/linux64/bin/../libexec/gcc/x86_64 -unknown-linux-gnu/4.3.1/cc1plus: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory make: *** [Make/linux64GccDPOpt/foamToTecplot.o] Error 1 |
February 4, 2009, 10:44 |
John:
This is a common proble
#56 |
musaddeque hossein
Rep Power: 18 |
John:
This is a common problem with OpenFoam that I have faced. The libmpfr.so.1 needs to be installed in the root directory - and should come with your linux distribution. If not, you can download it from several sites on the internet - you will have to do a google search if you dont have a site already. Either way, you will need access to the root file for this error to go away. |
February 4, 2009, 10:46 |
Musaddeque,
Thanks. I guess I
#57 |
John Paul Handrigan
Rep Power: 17 |
Musaddeque,
Thanks. I guess I'll have to get my administrator on the go. :P |
February 22, 2009, 06:23 |
Dear Niels Gjoel Jacobsen
#58 |
Nugroho Adi
Rep Power: 17 |
i followed your guideline on http://www.student.dtu.dk/~ngja/OF_u...eOnCluster.pdf but when i have been on the 8th step (8. Go to mpfr2. x.x and execute the following: a) $ ./configure prefix=$ HOME/install withgmp=$ HOME/install) i got error message : [user@localhost mpfr-2.4.0]$ ./configure --prefix=$HOME/install --with-gmp=$HOME/install checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether to disable maintainer-specific portions of Makefiles... yes checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking for gcc... gcc checking for C compiler default output file name... configure: error: in `/home/user/OpenFOAM/mpfr-2.4.0': configure: error: C compiler cannot create executables See `config.log' for more details. i already looked at config.log but since im a new user in OpenFOAM, i dont understand the error information on config.log could you please help me? or anybody? tusen takk |
February 22, 2009, 12:41 |
it could be that mpfr is not i
#59 |
musaddeque hossein
Rep Power: 18 |
it could be that mpfr is not included in the build of linux that you are using or that you did not load it from your linux boot disc. Check to make sure that you have loaded the version of mpfr that is requried.
February 23, 2009, 10:05 |
Hi Musaddeque
thanks. yup y
#60 |
Nugroho Adi
Rep Power: 17 |
Hi Musaddeque
thanks. yup you correct and i did mistake , i sourced $HOME/OpenFOAM/OpenFOAM1.5/etc/bashrc and $HOME/.bashrc so i have to delete that source refers to installation file or make it as #comment i can manage to configure gcc4.3.1 (follow http://www.student.dtu.dk/~ngja/OF_u...eOnCluster.pdf) but i got another errors on step 13th (13. make j N check # takes quite some time) as shown below : [user@localhost gcc-build]$ make -j 1 check make[1]: Entering directory `/home/user/localSrc/gcc-build' make[2]: Entering directory `/home/user/localSrc/gcc-build/fixincludes' autogen -T .././../gcc-4.3.1/fixincludes/check.tpl .././../gcc-4.3.1/fixincludes /inclhack.def make[2]: autogen: Command not found make[2]: *** [check] Error 127 make[2]: Leaving directory `/home/user/localSrc/gcc-build/fixincludes' make[1]: *** [check-fixincludes] Error 2 make[1]: Leaving directory `/home/user/localSrc/gcc-build' make: *** [do-check] Error 2 somebody could give me any suggestions? please |
injection not found in domain error | San | FLUENT | 3 | March 17, 2009 23:24 |
Error found in stress tutorial | mike_jaworski | OpenFOAM Running, Solving & CFD | 0 | September 23, 2007 03:34 |
Error: Finite angle gap could not be found | Richard | CFX | 0 | December 8, 2005 09:39 |
Boundaries not found error | Simone | Siemens | 2 | June 13, 2005 08:36 |
No warning or error messages found. | Atit Koonsrisuk | CFX | 5 | January 14, 2003 12:06 |
