September 3, 2008, 23:51 |
Victor:
Thanks for the correc
#21 |
musaddeque hossein
Rep Power: 18 |
Victor:
Thanks for the correction. You must have a differnt Suse 10 build. Since the one I have, when I run the command: buildParaview3.3-cvs, I get errors that require libmpfr and not gcc 4.3.1 The error is as follows: __________________________________________________ musa@linux:~/OpenFOAM/ThirdParty> buildParaView3.3-cvs Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /home/musa/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /home/musa/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/li nuxGcc -- Check for working C compiler: /home/musa/OpenFOAM/ThirdParty/gcc-4.3.1/platfo rms/linux/bin/gcc -- Check for working C compiler: /home/musa/OpenFOAM/ThirdParty/gcc-4.3.1/platfo rms/linux/bin/gcc -- broken CMake Error: The C compiler "/home/musa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/ linux/bin/gcc" is not able to compile a simple test program. It fails with the following output: /usr/bin/gmake -f CMakeFiles/cmTryCompileExec.dir/build.make CMakeFiles/cmTryCo mpileExec.dir/build gmake[1]: Entering directory `/home/musa/OpenFOAM/ThirdParty/ParaView3.3-cvs/pla tforms/linuxGcc/CMakeFiles/CMakeTmp' /home/musa/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/bin/cmake -E cmake_pr ogress_report /home/musa/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/ CMakeFiles/CMakeTmp/CMakeFiles 1 Building C object CMakeFiles/cmTryCompileExec.dir/testCCompiler.o /home/musa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -o CMakeFiles /cmTryCompileExec.dir/testCCompiler.o -c /home/musa/OpenFOAM/ThirdParty/ParaVi ew3.3-cvs/platforms/linuxGcc/CMakeFiles/CMakeTmp/testCCompiler.c /home/musa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../libexec/gcc/i686 -pc-linux-gnu/4.3.1/cc1: error while loading shared libraries: libmpfr.so.1: can not open shared object file: No such file or directory gmake[1]: *** [CMakeFiles/cmTryCompileExec.dir/testCCompiler.o] Error 1 gmake[1]: Leaving directory `/home/musa/OpenFOAM/ThirdParty/ParaView3.3-cvs/plat forms/linuxGcc/CMakeFiles/CMakeTmp' gmake: *** [cmTryCompileExec/fast] Error 2 CMake will not be able to correctly generate this project. -- Configuring done make: *** No targets specified and no makefile found. Stop. done musa@linux:~/OpenFOAM/ThirdParty> _____________________________________________ Please let me know what your thoughts are on this. Thanks Musa |
September 4, 2008, 17:29 |
Hello Musa !
Hope you're do
#22 |
victor
Rep Power: 17 |
Hello Musa !
Hope you're doing fine. If you look carefully in the error message, you can see, that in order to compile paraview, your gcc must fit the requirments: "-- Check for working C compiler" after the test, the script found: "-- broken ..." "The C compiler .... is not able to compile a simple test program." So, the "Cmake" sends the message: "It fails with the following output: " Then you have more specific error messages, i.e, where to look a bit closer: "...cc1: error while loading shared libraries: libmpfr.so.1: can not open shared object file: No such file or directory " So, since the gcc is not ok, then Cmake have problems to work: "CMake will not be able to correctly generate this project. -- Configuring done " *************** So, since OF-1.5 comes with gcc-4.3.1, this version of gcc requires gmp and mpfr. That's why you get the "libmpfr message", since it is gcc-related. In the Gnu-gcc-website, under the prerequisites http://gcc.gnu.org/install/prerequisites.html it is stated (among others) " . . GNU Multiple Precision Library (GMP) version 4.1 (or later) Necessary to build GCC. If you do not have it installed in your library search path, you will have to configure with the --with-gmp configure option. See also --with-gmp-lib and --with-gmp-include. MPFR Library version 2.3.0 (or later) Necessary to build GCC. It can be downloaded from http://www.mpfr.org/. The version of MPFR that is bundled with GMP 4.1.x contains numerous bugs. Although GCC may appear to function with the buggy versions of MPFR, there are a few bugs that will not be fixed when using this version. It is strongly recommended to upgrade to the recommended version of MPFR. The --with-mpfr configure option should be used if your MPFR Library is not installed in your default library search path. See also --with-mpfr-lib and --with-mpfr-include. .. " ####### In my case, I have SLED 10 SP1, and also got the same error message as yours at the beginning. What I did, was to install from scratch, gmp, mpfr, and gcc-4.3.1. Then installed QT-4.3.5. Once I did that I could compile Paraview. this is what I did, but there could be other ways. Hope this helps best V |
September 8, 2008, 22:15 |
Victor:
many thanks for your
#23 |
musaddeque hossein
Rep Power: 18 |
Victor:
many thanks for your response to my message. i sincerely appreciate the time you took to explain the error messages. I installed Suse 11.0 on my computer with all the C/C++ and other development files. I was able to install Openfoam 1.5 and including the kitware visualisation package. As a test, I ran the damBreak problem and it ran fine. I must say OpenFoam 1.5 and suse 11.0 are much more robust than their predecessors. Almost loads like a windows based software (sorry - I was weaned on MS Windows) - w/o hiccups. Musa |
September 9, 2008, 16:34 |
Hi Musa !
You're welcome..
#24 |
victor
Rep Power: 17 |
Hi Musa !
You're welcome.. Good to hear you already have OF-1.5. !! enjoy it best and a nice day V |
October 4, 2008, 16:27 |
Hi
does anyone know how to
#25 |
Hi
does anyone know how to build mpfr for OF1.5? just: 1) ./configure --prefix=$HOME/OpenFOAM-1.5/Thirdparties/mpfr-2.3.2 2) make 3) make install is there any other settings? i do not have "root",i am just a user of school`s cluster. is there any other packages needed to be installed on AS4 to just run the applications,but NOT paraView? thanks yours wayne |
October 4, 2008, 18:39 |
Hi Wayne,
You don't need to
#26 |
Håkan Nilsson
Rep Power: 18 |
Hi Wayne,
You don't need to be root to install mpfr. Do the following steps: cd $WM_THIRD_PARTY_DIR wget http://www.mpfr.org/mpfr-2.3.2/mpfr-2.3.2.tar.gz gunzip mpfr-2.3.2.tar.gz tar xf mpfr-2.3.2.tar mv mpfr-2.3.2 mpfr-2.3.2_Src mkdir mpfr-2.3.2 cd mpfr-2.3.2_Src ./configure --prefix=$WM_THIRD_PARTY_DIR/mpfr-2.3.2 > & log_configure (the prefix option makes it possible to do this without being root, but it means that you will have to specify the path to the mpfr installation later on - I'll show you.) make > & log_make make check > & log_make_check make install > & log_make_install If everything goes alright you should now see in the log_configure file that the gmp version is 4.1 or later (otherwise I guess that you will have to get that also). In log_make_check you should see that all tests have passed. You find some info on your installation in log_make_install. To use the new mpfr library with the distributed gcc-4.3.1, modify the following in the OpenFOAM-1.5/etc/settings.csh file (or similar in the settings.sh file): case Gcc: setenv WM_COMPILER_DIR $WM_THIRD_PARTY_DIR/gcc-4.3.1/platforms/$WM_ARCH$WM_COMPILER_ARCH #mpfr specific: if ($?LD_LIBRARY_PATH) then setenv LD_LIBRARY_PATH ${WM_THIRD_PARTY_DIR}/mpfr-2.3.2/lib:${LD_LIBRARY_PATH} else setenv LD_LIBRARY_PATH ${WM_THIRD_PARTY_DIR}/mpfr-2.3.2/lib endif breaksw Hċkan |
October 5, 2008, 13:54 |
Hi all
Thanks for all the u
#27 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi all
Thanks for all the useful comments above. I have successfully applied them and have compiled OF-1.5 on a cluster which does not support gcc-4.3.1. In the attached document, I have tried to compile all the necessary steps into one documents which in details goes through the installation process. Best regards Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
October 5, 2008, 13:58 |
The file was to large. Find it
#28 |
Rep Power: 37 |
October 6, 2008, 04:21 |
Hi Hakan
thanks!
but i can
#29 |
Hi Hakan
thanks! but i can not build correctly with error message: warning: Clock skew detected. your build may be incomplete. how can i resolve it ? thanks yours wayne |
October 6, 2008, 06:13 |
Hi Wayne,
This is not an er
#30 |
Håkan Nilsson
Rep Power: 18 |
Hi Wayne,
This is not an error message, but a warning. It sais that there is a problem with your clock. I don't think this will cause any trouble unless you are compiling the same thing several times simultaneously (or some other strange behaviour). As long as you get the binaries and they work as they should, you should be fine. Hċkan. |
October 6, 2008, 12:07 |
Hi Hakan.
i am sorry for i
#31 |
Hi Hakan.
i am sorry for i am not successful.when i build applications such as MRFSimpleFoam,it is error as following: shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory when i do whereis libmpfr report is /usr/lib/libmpfr.aonly one without libmpfr.so the attachment is the log_make and log_make_install for building of mpfr and gmp here is mpfr here is gmp |
October 6, 2008, 12:10 |
i am sorry. i dont attach them
#32 |
i am sorry. i dont attach them corrctly
here is of mpfr mpfr.zip here is of gmp gmp.rar by the way,would you mind give me some advices ont the topic of computeTorqueMRF problem( http://www.cfd-online.com/cgi-bin/Op...how.cgi?1/9426) best regards thanks! your wayne |
October 14, 2008, 02:55 |
I have an error when
#33 |
Pattyn Eric
Rep Power: 17 |
I have an error when i use wmake or tried to install ParaFoam: shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory. When trying to install the mpfr library to have the file libmpfr.so.1, it returns (after command ./configure) that it can't find libmpfr.so.1 ... I'm a little bit lost.... I only found libmpfr.a. I haven't found yet a solution on the forum. Does somoene have an idea to help me? ep4 |
October 14, 2008, 05:06 |
Pattyn Eric:
You have proba
#34 |
Ville Tossavainen
Rep Power: 17 |
Pattyn Eric:
You have probably sourced /OpenFOAM-1.5/etc/bashrc file before trying to install the mpfr-library. That makes the new c++ compiler active and the compilation fails. The new gcc 4.3.x compiler requires the mpfr library to work. So you should use the system compiler to compile mpfr (i.e. without sourcing the OpenFOAM bashrc file). If, possible, a better solution is to use your system's package manager to obtain the mpfr library. |
October 16, 2008, 04:05 |
Exactly, i have sourced the ba
#35 |
Pattyn Eric
Rep Power: 17 |
Exactly, i have sourced the bashrc file and then tryed to install mpfr library.
When you say that i should use the sytem compiler, what does it mean exactly? I have suppress the line in my bashrc file, then make ./configure but i still have the same error. I don't know either what's the system's package manager. Could you maybe give me some more details, i'm not really a king for those things... Thank you eric |
October 16, 2008, 07:41 |
Sorry, I wasn't clear enough.
#36 |
Ville Tossavainen
Rep Power: 17 |
Sorry, I wasn't clear enough. The system compiler is located in "/usr/bin/gcc". After sourcing the OpenFOAM bashrc file, the command "gcc" points to the newer c++ compiler provided in the OpenFOAM distribution.
I suggest you have removed the OpenFOAM bashrc source line from your .bashrc in your home directory. Then you should open a new terminal, because the OpenFOAM settings will stay in memory. Just make sure that "which gcc" command points to the system compiler "/usr/bin/gcc". By package manager I mean a program in which you can manage the installed programs and libraries in your Linux system. In Debian based distributions it's called Synaptic etc. You should find the mpfr-library there. If not then you need to install the library manually like you have tried. I hope this helps. |
October 16, 2008, 09:50 |
Thank you very much for the ti
#37 |
Pattyn Eric
Rep Power: 17 |
Thank you very much for the time you are taking for me.
I have successfully installed the mpfr library. Nevertheless, i still have the same error when compiling paraview (see the end of this message). The files of mpfr library have been installed in the usr/local/lib/ directory. Maybe i should copy them somewhere else. I have tried some possible locations without success. Maybe you could help me again? Thank you eric ep4@wobwslx2:~/OpenFOAM/ThirdParty$ buildParaView3.3-cvs Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc -- Check for working C compiler: /ric_home/ep4/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- Check for working C compiler: /ric_home/ep4/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- broken CMake Error: The C compiler "/ric_home/ep4/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc" is not able to compile a simple test program. It fails with the following output: /usr/bin/gmake -f CMakeFiles/cmTryCompileExec.dir/build.make CMakeFiles/cmTryCompileExec.dir/build gmake[1]: Entering directory `/net/ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMak eFiles/CMakeTmp' /ric_home/ep4/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/bin/cmake -E cmake_progress_report /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFile s/CMakeTmp/CMakeFiles 1 Building C object CMakeFiles/cmTryCompileExec.dir/testCCompiler.o /ric_home/ep4/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -o CMakeFiles/cmTryCompileExec.dir/testCCompiler.o -c /ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFile s/CMakeTmp/testCCompiler.c /net/ric_home/ep4/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../libexec /gcc/x86_64-unknown-linux-gnu/4.3.1/cc1: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory gmake[1]: *** [CMakeFiles/cmTryCompileExec.dir/testCCompiler.o] Fehler 1 gmake[1]: Leaving directory `/net/ric_home/ep4/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMak eFiles/CMakeTmp' gmake: *** [cmTryCompileExec/fast] Fehler 2 CMake will not be able to correctly generate this project. -- Configuring done make: *** Keine Targets angegeben und keine ğmakeĞ-Steuerdatei gefunden. Schluss. done |
October 17, 2008, 05:11 |
This may be again a system rel
#38 |
Ville Tossavainen
Rep Power: 17 |
This may be again a system related problem. Now you are using the system compiler and it lacks some components which are needed in the compilation process.
You need at least "g++" package installed (if "which g++" finds nothing). If the same problem prevails, choose development option (installs development packages) in the package manager. Which linux distribution are you using and is it a desktop or a server? |
October 17, 2008, 06:12 |
the which gcc gives:
#39 |
Pattyn Eric
Rep Power: 17 |
the which gcc gives: /ric_home/ep4/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc or /usr/bin/gcc if i don't write the additional line in my .bashrc file. My linux distribution, ... : ep4@wobwslx2:/net/ric_home/ep4$ uname -a Linux wobwslx2 2.6.9-42.0.8.ELsmp #1 SMP Tue Jan 23 12:49:51 EST 2007 x86_64 x86_64 x86_64 GNU/Linux Is there a command to install development packages ? To install mpfr i haven't use the package manager. Thank you eric |
October 17, 2008, 08:49 |
It looks like you are a user o
#40 |
Ville Tossavainen
Rep Power: 17 |
It looks like you are a user on a linux cluster and not a system administrator. The kernel version is similar to what I have in our Rocks linux cluster. At least in my case everything is a "bit" outdated... I get these outputs:
"ld --version" version ~2.15 "gcc --version" version < 3.x.x The system linker (ld command in binutils package) didn't work with new c++ compiler provided in OpenFOAM. It may be the problem in your case, too. Check the install log file under ThirdParty in Paraview directory. There may be more info what's actually wrong. I have used the following compilation procedure to get everything updated (installed in ThirdParty): Binutils 2.18 -> gmp 4.2.2 -> mpfr 2.3.1 -> (gcc 4.3.1) -> QT 4.3.1 Basically I have used the guide (http://openfoamwiki.net/index.php/Ho...mpile_OpenFOAM). |
injection not found in domain error | San | FLUENT | 3 | March 17, 2009 23:24 |
Error found in stress tutorial | mike_jaworski | OpenFOAM Running, Solving & CFD | 0 | September 23, 2007 03:34 |
Error: Finite angle gap could not be found | Richard | CFX | 0 | December 8, 2005 09:39 |
Boundaries not found error | Simone | Siemens | 2 | June 13, 2005 08:36 |
No warning or error messages found. | Atit Koonsrisuk | CFX | 5 | January 14, 2003 12:06 |
