Installation using the precompiled binaries on Suse 103
Old   March 6, 2009, 21:43
Default Hi Everyone, I have been tr
William Komp
pamdirac is on a distinguished road
Hi Everyone,
I have been trying to install OpenFoam on my Suse 10.3 server. After spending some time getting the right path for the libraries in the openfoam install directory for the precompiled binaries in ld.so.conf. When I try to run the applications like Q or mhdFoam. I am getting segmentation faults. Can anyone help me? I am currently trying to install the compiled version and am still working out the library paths for that. any info on that would greatly help as well.
Below is the output of ldd for one of mhdFoam (which is typical output) and a copy of the application giving me a segment fault.
William
william@kentbrockman:~/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt> ldd ./mhdFoam
libfiniteVolume.so => /home/william/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so (0x00002b22ab51c000)
libOpenFOAM.so => /home/william/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so (0x00002b22ac1fb000)
libdl.so.2 => /lib64/libdl.so.2 (0x00002b22ac7e1000)
libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00002b22ac9e6000)
libm.so.6 => /lib64/libm.so.6 (0x00002b22accee000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00002b22acf41000)
libc.so.6 => /lib64/libc.so.6 (0x00002b22ad150000)
libPstream.so => /home/william/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/openmpi-1.2.6/libPstream .so (0x00002b22ad496000)
libtriSurface.so => /home/william/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libtriSurface.so (0x00002b22ad6a1000)
libmeshTools.so => /home/william/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so (0x00002b22ad914000)
libz.so => /usr/lib64/libz.so (0x00002b22adcc1000)
/lib64/ld-linux-x86-64.so.2 (0x00002b22ab2ff000)
libmpi.so.0 => /home/william/OpenFOAM/OpenFOAM-1.5/ThirdParty/openmpi-1.2.6/platforms/linux64Gc cDPOpt/lib/libmpi.so.0 (0x00002b22aded7000)
liblagrangian.so => /home/william/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/liblagrangian.so (0x00002b22ae163000)
libopen-rte.so.0 => /home/william/OpenFOAM/OpenFOAM-1.5/ThirdParty/openmpi-1.2.6/platforms/linux64Gc cDPOpt/lib/libopen-rte.so.0 (0x00002b22ae36b000)
libopen-pal.so.0 => /home/william/OpenFOAM/OpenFOAM-1.5/ThirdParty/openmpi-1.2.6/platforms/linux64Gc cDPOpt/lib/libopen-pal.so.0 (0x00002b22ae5c5000)
libnsl.so.1 => /lib64/libnsl.so.1 (0x00002b22ae826000)
libutil.so.1 => /lib64/libutil.so.1 (0x00002b22aea3e000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00002b22aec41000)
william@kentbrockman:~/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt> ./mhdFoam
Segmentation fault
pamdirac is offline   Reply With Quote
Old   March 9, 2009, 04:05
Default Hello William, I have an Open
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hello William,
I have an OpenSuse 10.3 box, and the binary release did not work for me, thus I had to compile the sources.
However, as a basic principle, you don't have to fiddle with any environment variable, everything is set up by the bashrc script.
Bottom line, my suggestion is to compile the sources.
Dragos
dmoroian is offline   Reply With Quote
Installation using the precompiled binaries on Suse 103 pamdirac OpenFOAM Installation 0 March 6, 2009 21:39
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 07:12
Precompiled 64bit linux installation milkovp OpenFOAM Installation 5 May 15, 2008 05:57
Installation OpenFoam on SUSE 101 t42 OpenFOAM Installation 1 August 1, 2007 07:15
Installation OpenFoam on SuSe 101 mephisto OpenFOAM Installation 1 November 8, 2006 03:15
