Debian package for ubuntu 810
Old   March 11, 2009, 08:57
Default My bad (tail draggging low....
  #21
Steven Zalek
zaleksf is on a distinguished road
My bad (tail draggging low....)
I was attempting to run the icoFoam example from a write-protected directory.
Everything seems to run perfectly - thanks Oliver!
zaleksf is offline   Reply With Quote
Old   March 16, 2009, 10:16
Leonardo Honfi Camilo
lhcamilo is on a distinguished road
great release, the package seems to work fine with ubuntu 9.04 64-bit as well, thought the paraview package won't work just yet due to the dependency on the package libavcondec51.
paraview aside, this is immensely appreciated.
Keep up the good work
regards
leo
lhcamilo is offline   Reply With Quote
Old   April 15, 2009, 19:18
Question Still doesn't launch
  #23
Jonathan Benning
Jonomac is on a distinguished road
I'm using ubuntu 9.04 and installed the OpenFOAM.deb from your site using apt-get install (name).deb
It gave some errors because some dependencies weren't met so I installed those and then openfoam installed just fine. As the previous message said, paraview will not install this way but I was able to follow some links and got it installed a different way. Anyway, to the point.
I have added the line;
alias startOF15="source /usr/lib/Ojon@jon:~$ startOF15
penFOAM/OpenFOAM-1.5/etc/bashrc"
to the end of my ~/.bashrc file and rebooted the system.
then opened a terminal and ran the startOF15 from there, this is the output
jon@jon:~$ startOF15jon@jon:~$ startOF15
bash: /usr/lib/OpenFOAM/OpenFOAM-1.5/etc/bashrc: No such file or directory
Ideas on what I can do to get openfoam working would be much appreciated. Thanks in advance for anyones input to this matter.
Jonomac is offline   Reply With Quote
Old   June 8, 2009, 04:38
maja ondracka
maja is on a distinguished road
I am not very familiar with Linux and I am trying to install OF1.5 or OF1.5-dev and paraView. I am using ubuntu 8.10 and I used the packages from https://launchpad.net/~oli-borm/+archive/ppa.
The installation of OF was ok. I have also added
alias startOF15="source /usr/lib/OpenFOAM/OpenFOAM-1.5/etc/bashrc"
to my ~/.bashrc.
When I typed startOF15, I got the message:
maja@maja-laptop:/$ startOF15
bash: startOF15: command not found
I saw others had the same problem but I did not find the answer. I know it must be a stupid reason but I will be very glad if someone helps me.
Thanks a lot.
Maja
maja is offline   Reply With Quote
Old   June 8, 2009, 05:21
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Hi Maja!
Perhaps you mistyped alias for startOF15....
The best way to check it is to type "alias" (without quotes) in your bash shell.
It will produce list of your aliases. So check, is startOF15 in that list.
Good luck!
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   June 8, 2009, 05:37
maja ondracka
Thanks a lot! I have no idea what was wrong. Anyway it works now!
Thanks again!
Regards, Maja
Old   May 5, 2010, 08:43
Default OpenFOAM-1.5-dev for ubuntu 10.04 LTS
  #27
Oliver Borm
deepblue17 is on a distinguished road
I've updated the OpenFOAM-1.5-dev and paraview-3.6.2 debian packages for Ubuntu 10.04. You can get the packages from the CAE-Team PPA:
https://launchpad.net/~cae-team/+archive/ppa/+packages
Just follow the installation instructions from the wiki:
http://openfoamwiki.net/index.php/In...ucid_10.04_LTS
deepblue17 is offline   Reply With Quote
Compiling Problem on Debian besto OpenFOAM Installation 8 August 13, 2008 16:29
Compilation whith a debian pifou74 OpenFOAM Installation 3 April 10, 2008 09:31
Trouble compiling on Debian Etch jkr OpenFOAM Installation 2 April 14, 2006 15:56
Fluent 6.2 on debian linux Chris FLUENT 3 June 2, 2005 06:21
Fluent on Suse,Debian Linux? Angus MacLeod FLUENT 3 September 27, 2000 12:48
