March 9, 2009, 06:36 |
I download the 2 packs from th
Duarte Albuquerque
Rep Power: 17 |
I download the 2 packs from the site http://www.opencfd.co.uk/openfoam/.
I follow the instructions in the readme file. but i still have 2 critical erros than I run ./foamInstalationTest function in the console: Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.1 User version : ../src/configure 4.3.2 Minimum required: 4.2.0 gcc ...figure WARNING: Conflicting installations: OpenFOAM settings : /home/dmsa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.3.12 /bin/gzip tar 1.20 /bin/tar icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/dmsa/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam current path : CRITICAL ERROR ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_dilbert Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the OpenFOAM enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. I try to change the gcc path by editing the following file OpenFOAM-1.5/etc/settings.sh "#WM_COMPILER_INST=OpenFOAM WM_COMPILER_INST=System" I also try to make ./Allmake but it has to much erros: collect2: ld returned 1 exit status make[3]: *** [/home/dmsa/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/pPrime2] Error 1 make[3]: Leaving directory `/home/dmsa/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/scalarFi eld/pPrime2' make[2]: *** [pPrime2] Error 2 make[2]: Target `application' not remade because of errors. make[2]: Leaving directory `/home/dmsa/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/scalarFi eld' make[1]: *** [scalarField] Error 2 make[2]: Entering directory `/home/dmsa/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/stressFi eld' make[3]: Entering directory `/home/dmsa/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/stressFi eld/stressComponents' Making dependency list for source file stressComponents.C make[3]: Leaving directory `/home/dmsa/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/stressFi eld/stressComponents' make[3]: Entering directory `/home/dmsa/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/stressFi eld/stressComponents' SOURCE=stressComponents.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/dmsa/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/dmsa/OpenFOAM/OpenFOAM-1.5/src/turbulenceModels/RAS -I/home/dmsa/OpenFOAM/OpenFOAM-1.5/src/transportModels -IlnInclude -I. -I/home/dmsa/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/dmsa/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/stressComponents.o g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/dmsa/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/dmsa/OpenFOAM/OpenFOAM-1.5/src/turbulenceModels/RAS -I/home/dmsa/OpenFOAM/OpenFOAM-1.5/src/transportModels -IlnInclude -I. -I/home/dmsa/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/dmsa/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC Make/linux64GccDPOpt/stressComponents.o -L/home/dmsa/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt \ -lfiniteVolume -lincompressibleRASModels -lincompressibleTransportModels -lOpenFOAM -liberty -ldl -lm -o /home/dmsa/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/stressComponen ts /usr/bin/ld: cannot find -liberty collect2: ld returned 1 exit status make[3]: *** [/home/dmsa/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/stressCompone nts] Error 1 make[3]: Leaving directory `/home/dmsa/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/stressFi eld/stressComponents' make[2]: *** [stressComponents] Error 2 make[2]: Target `application' not remade because of errors. make[2]: Leaving directory `/home/dmsa/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/stressFi eld' make[1]: *** [stressField] Error 2 make[1]: Target `application' not remade because of errors. make[1]: Leaving directory `/home/dmsa/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing' make: *** [postProcessing] Error 2 make: Target `application' not remade because of errors. |
March 9, 2009, 08:04 |
Hei Duarte Albuquerque
yo
Nugroho Adi
Rep Power: 17 |
you should try this one : http://www.cfd-online.com/OpenFOAM_D...tml?1234975312 Regarding the script: 1.Just copy all the contents and put it in to a file. 2. then change the file to an executable file using chmod a+x file name. 3.then execute the file from the command line as this ./filename this will go to the corresponding website and download the software and will ask you for password before installing it. http://www.cfd-online.com/OpenFOAM_D...tml?1232888756 Regards Nugroho Adi |
March 11, 2009, 12:53 |
Tkx for the info
now i have
Duarte Albuquerque
Rep Power: 17 |
Tkx for the info
now i have access to the icoFoam and blockMesh functions. I still have a problem with paraFoam its says I don't a reader for the File cavity.OpenFOAM Also if I run the "foamInstalationtest" it shows a critical error. Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.1 User version : ../src/configure 4.3.2 Minimum required: 4.2.0 gcc ...figure WARNING: Conflicting installations: OpenFOAM settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.3.12 /bin/gzip tar 1.20 /bin/tar icoFoam 1.5 .../OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_dilbert Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the OpenFOAM enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. any solutions? tkx for the help |
March 12, 2009, 00:44 |
Hi Duarte,
The critical err
Prapanch Nair
Rep Power: 17 |
Hi Duarte,
The critical error is OK. It is because you are not installing it actively while being connected to the openFOAM's server. You have downloaded files and installed. That is why it shows the error. You should still be able to use OF without any issue. You have some issue with your Qt version, hence not able to view Foam files in paraview. Instead you can do the following: after running your case, for example icofoam, run foamToVTK in the same directory. Now you will see a new folder called VTK created. Now type paraFoam. You will get the same error message. Click cancel. Go to file->open, open the folder called VTK. You will have a file called cavity.vtk. Double click on it. The rest will work as explained in your User's Guide. Hope this helps. Prapanj |
Instalation on ubuntu 710 | basilwatson | OpenFOAM Installation | 17 | March 16, 2012 21:16 |
Help with parallel working instalation. | Jonathan | FLUENT | 9 | November 8, 2011 00:25 |
141 Instalation on Fedora Core 8 with Pentium 4 | markozeta | OpenFOAM Installation | 0 | April 16, 2008 20:52 |
Comet Instalation | Merkru | Siemens | 0 | June 12, 2006 04:31 |
cfx-4.2 or cfx-4.3 instalation | Antonio Melendez | CFX | 1 | June 28, 2001 04:58 |
