OpenFOAM Install Script
Old   March 5, 2009, 13:26
Default Andreas, Here is what i did
  #41
Joseph
jnattia is on a distinguished road
Andreas,
Here is what i did as a new user of Linux as well:
1. Take Jure's second script above and create a doc on your machine.
2. set the file to executable by using the command: chmod a+x (name of file)
3. run the script (from a terminal) as if it was a normal program and enter your password when asked.
that's it.
one very important note. DO NOT run the script as a root.
i use Ubuntu 8.04 and the above worked fine except for a small glitch which was resolved with Jure's help (see above messages). but maybe you won't face it.
Enjoy.
Joseph
jnattia is offline   Reply With Quote
Old   March 14, 2009, 09:18
Default Hei Jure thanks for your sc
  #42
Nugroho Adi
mahaputra is on a distinguished road
Hei Jure
thanks for your script, it is brillian idea. make everything more simple.
by the way, i would like to upgrade my OpenFOAM 1.5 to OpenFOAM 1.5.x or OpenFOAM 1.5-dev
what should i do to modify your script?
please let me know
since i really fresh with LINUX
anybody have some idea ?
many thanks
have a nice weekend
mahaputra is offline   Reply With Quote
Old   March 14, 2009, 10:29
Default You don't need the script for
  #43
jlakovic
You don't need the script for this.
How about just following the instructions here?
http://www.cfd-online.com/cgi-bin/Op.../show.cgi?4/12
You will need the package git-core:
sudo aptitude install git-core
move to your OpenFOAM directory
cd $WM_PROJECT_INST_DIR
and execute
git clone git://repo.or.cz/OpenFOAM-1.5.x.git
The post says to follow the instructions in the documentation to compile OpenFOAM. I suggest reading them thoroughly before continuing.
If you have everything needed installed (which I suppose you do, since you have OpenFOAM-1.5 working already), then what I would do is execute
OpenFOAM-1.5.x/Allwmake
and wait until it finishes compiling or until it spits out some error which could take hours/days/forever to fix.
After compilation, if you wish to "upgrade", you will need to update your .bashrc.
nano ~/.bashrc
Edit the line
source /home/$USER/OpenFOAM/OpenFOAM-1.5/etc/bashrc
(where $USER is your username) so that it says OpenFOAM-1.5.x instead of OpenFOAM-1.5. Save, exit, and do
source ~/.bashrc
to update the paths.
Now you can remove the old OpenFOAM folder.
rm -rf OpenFOAM-1.5
To carry over your user files, either copy or rename the personal folder in $WM_PROJECT_INST_DIR to fit the new version, e.g.
mv $USER-1.5 $USER-1.5.x
I think that's it.
Jure
Old   March 14, 2009, 13:30
Default fantastic, thanks for quick
  #44
Nugroho Adi
fantastic,
thanks for quick answer
i will try it today!
Old   March 14, 2009, 15:47
Default Dear Jure i have a problem
  #45
Nugroho Adi
Dear Jure
i have a problem after finish with the OpenFOAM
when i tried to type : paraFoam or paraview
it could open the paraview only 1 second
after that error message came :
''Bus error''
do you know how to solve this problem?
regards
Nugie
Old   March 14, 2009, 16:28
Default From http://en.wikipedia.org/w
  #46
jlakovic
From http://en.wikipedia.org/wiki/Bus_error:
"In computing, a bus error is generally an attempt to access memory that the CPU cannot physically address. Bus errors can also be caused by any general device fault that the computer detects. A bus error rarely means that computer hardware is physically broken - it is normally caused by a bug in a program's source code."
I guess you've encountered your first bug ;-)
Old   March 14, 2009, 16:47
Default hemm, im using ubuntu 8.
  #47
Nugroho Adi
hemm,
im using ubuntu 8.10
and i install OpenFoam 1.5 with your script to my collegue laptop.
everything looks fine by type : foamInstallationTest
test run on the simpleFoam tutorial as well
but when i tried to run paraFoam and paraView, it gived error message : Bus error
spech of the laptop is :
DELL
intel centrino 2
ram 3.5 GB
dual os with windows xp professional
any solution for this problem?
Old   March 14, 2009, 17:17
Default Hmmm.... 32-bit or 64-bit U
  #48
jlakovic
Hmmm....
32-bit or 64-bit Ubuntu?
Old   March 14, 2009, 18:30
Default No, this is unrelated. I ad
  #49
jlakovic
I advise against installing QT from the repositories (libqt4-dev) because it may come to a version mismatch.
The QT libraries in Ubuntu have been updated to version 4.4.3 - a version ParaView doesn't compile with.
All the needed packages are automatically selected and installed in my ParaView installation script, and the correct version of QT (4.3.5) is downloaded.
You're mixing up OpenFOAM and ParaView. The QT libraries are needed for ParaView, not for OpenFOAM to run properly.
You're saying you're trying to install OpenFOAM-1.5 using my script. You don't need to collect any packages before running the script - the script does that for you.
If you're trying to compile OpenFOAM-1.5.x, you don't need the script. All you need is gcc and wmake, which is included with OpenFOAM.
Also, the bus error your friend is experiencing - I'm thinking the problem lies in the fact that you're using a 32-bit distribution on a system with 3,5 GB of RAM. Can you try again, this time on Ubuntu 64?
Jure
Old   March 15, 2009, 00:25
Default the laptop is DELL Precision M
  #50
Nugroho Adi
the laptop is DELL Precision M4400
32 ? 64 of linux ubuntu installation?
Old   March 15, 2009, 09:12
Default Smart !!!! you are right Jure
  #51
Nugroho Adi
Smart !!!! you are right Jure !!
its because of wrong Ubuntu bit.
after i reinstall Ubuntu from 32 to 64 bit, now i can run paraview / paraFoam
but
it asks for the reader, wich one i have to choose ?
VTK??
* Kitware ParaView 3.2.2
Old   March 15, 2009, 09:33
Default if i type $ paraview , it work
  #52
Nugroho Adi
if i type $ paraview , it works fine (without openfoam case)
but if i run $paraFoam , it asks :
Open Data with ....
a reader for ''cavity.OpenFOAM'' could not be found. Please choose one :
Exodus
Exodusll
LSDyna
Paraview Data Files
VTK PolyData Files
and soon
which reader should be ?
Old   March 15, 2009, 09:35
Default i already tried several option
  #53
Nugroho Adi
i already tried several option , but the error message came :
vtkXMLPImageDataReader (0x2d60a90): Error parsing input file. ReadXMLInformation aborting.
ERROR: In /build/buildd/paraview-3.2.2/VTK/Filtering/vtkExecutive.cxx, line 757
vtkCompositeDataPipeline (0x2d33060): Algorithm vtkXMLPImageDataReader(0x2d60a90) returned failure for request: vtkInformation (0x2d14b90)
Debug: Off
Modified Time: 94299
Reference Count: 1
Registered Events: (none)
Request: REQUEST_INFORMATION
FORWARD_DIRECTION: 0
KEYS_TO_COPY: COMPOSITE_DATA_INFORMATION
ALGORITHM_AFTER_FORWARD: 1
Old   March 15, 2009, 10:09
Default ahaaa... i found this one
  #54
Nugroho Adi
ahaaa...
i found this one :
http://ubuntuforums.org/archive/index.php/t-156298.html
if paraFoam gives you the "open with" bug then instead of parafoam do
foamToVTK
then try running
paraview
@ your case directory
go to open file and you should notice that there is a VTK folder at your case directory, open it and view your results using by opening the last file.
now i can open and get post processing simulation on the paraview
finnally thanks God
NB : but i still could not use $paraFoam command
Old   March 16, 2009, 04:59
jlakovic
Open Data with ....
Exodus
Exodusll
LSDyna
Paraview Data Files
VTK PolyData Files
and soon
You still need to compile PV3FoamReader:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3FoamReader
./Allwclean
./Allwmake
Old   March 17, 2009, 14:22
Default I dont find the script
  #56
Xabi is on a distinguished road
Hi Jure,
Just some days ago I found the script you've made and today when i wanted to install the openFoam Ive not been able to get it. Could you tell me where it is (i am new with the program and in the forum as well) or otherwise send it to me by email?
Thanks,
xabi
Xabi is offline   Reply With Quote
Old   March 17, 2009, 14:31
jlakovic
Originally Posted by Xabi View Post
Hi Jure,
Thanks,
xabi
Apparently, not all posts were transferred to the new forum. Some larger posts have not been transferred. This is strange, very strange. I will repost them shortly.
Old   March 17, 2009, 14:54
Arrow OpenFOAM + ParaView Install Scripts
  #58
jlakovic
The installOpenFOAM script simply downloads and sets up OpenFOAM to work. It is platform independent. It does not install ParaView - that's what the second script is for. The installParaView script needs an APT-based distribution (Debian, Ubuntu) to work.
Instructions:
1. Download the files to your computer:
Attachment 20
Attachment 111
2. Open a terminal and cd to where you downloaded them
3. Type
chmod +x installOpenFOAM.txt installParaView.txt
./installOpenFOAM.txt
4. Follow the instructions to download and install OpenFOAM.
5. Run the second script:
./installParaView.txt
6. Follow instructions to compile ParaView.
Jure
Update: while doing some testing myself, it seems I've forgotten to include one package PV3FoamReader requires to compile properly:
libreadline5-dev
I've updated the installParaView script to reflect the changes.
Old   March 24, 2009, 08:09
Nugroho Adi
./Allwclean
./Allwmake
Dear Jure Lakovic
im sorry to post the report late, since i didnt touch my friend laptop after i install the the OpenFOAM in his Ubuntu 8.10 64 bit.
he still run the foamToVTK until now to post processing on paraview, or
foamDataToFluent to open on Fluent.
by the way, i just followed your instruction, to compile PV3FoamReader:
./Allwclean
./Allwmake
as i shown below :
user@user-laptop:~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV3FoamReader$ ./Allwclean
+ rm -r PV3FoamReader/Make
+ wclean libso vtkPV3Foam
wclean vtkPV3Foam
user@user-laptop:~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV3FoamReader$ ./Allwmake
+ [ -d /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc -a -r /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc ]
+ wmake libso vtkPV3Foam
wmakeLnInclude: linking include files to /home/user/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV3FoamReader/vtkPV3Foam/lnInclude
Making dependency list for source file vtkPV3Foam.C
could not open file vtkConfigure.h for source file vtkPV3Foam.C
Making dependency list for source file vtkPV3FoamAddVolumeMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddVolumeMesh.C
Making dependency list for source file vtkPV3FoamAddLagrangianMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddLagrangianMesh.C
Making dependency list for source file vtkPV3FoamAddPatchMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddPatchMesh.C
Making dependency list for source file vtkPV3FoamAddFaceZoneMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddFaceZoneMesh.C
Making dependency list for source file vtkPV3FoamAddPointZoneMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddPointZoneMesh.C
Making dependency list for source file vtkPV3FoamAddFaceSetMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddFaceSetMesh.C
Making dependency list for source file vtkPV3FoamAddPointSetMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamAddPointSetMesh.C
Making dependency list for source file vtkPV3FoamUpdate.C
could not open file vtkConfigure.h for source file vtkPV3FoamUpdate.C
Making dependency list for source file vtkPV3FoamUpdateInformation.C
could not open file vtkConfigure.h for source file vtkPV3FoamUpdateInformation.C
Making dependency list for source file vtkPV3FoamConvertMesh.C
could not open file vtkConfigure.h for source file vtkPV3FoamConvertMesh.C
SOURCE=vtkPV3Foam.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/user/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/VTK -I/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/user/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/vtkPV3Foam.o
In file included from /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:30,
from /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIndent.h:24,
from /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObjectBase.h:43,
from /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObject.h:41,
from /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkAlgorithm.h:32,
from /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkMultiBlockDataSetAlgorithm.h:25,
from ../PV3FoamReader/vtkPV3FoamReader.h:26,
from vtkPV3Foam.C:36:
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkWin32Header.h:27:26: error: vtkConfigure.h: No such file or directory
In file included from /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:40,
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:68:68: error: iostream.h: No such file or directory
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:69:23: error: iomanip.h: No such file or directory
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:70:70: error: fstream.h: No such file or directory
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:129:58: error: strstream.h: No such file or directory
In file included from /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:44,
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkType.h:162:3: error: #error "No native data type can represent an 8-bit integer."
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkType.h:177:3: error: #error "No native data type can represent a 16-bit integer."
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkType.h:192:3: error: #error "No native data type can represent a 32-bit integer."
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkType.h:212:3: error: #error "No native data type can represent a 64-bit integer."
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkType.h:220:3: error: #error "No native data type can represent a 32-bit floating point value."
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkType.h:228:3: error: #error "No native data type can represent a 64-bit floating point value."
In file included from /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkVariant.h:35,
from /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkAbstractArray.h:45,
from /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkDataArray.h:37,
from /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkCharArray.h:29,
from vtkPV3Foam.C:39:
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkStdString.h:25:54: error: vtkstd/string: No such file or directory
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkStdString.h:30: error: ‘vtkstd’ has not been declared
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkStdString.h:30: error: expected `{' before ‘string’
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkStdString.h:30: error: function definition does not declare parameters
In file included from /home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkAbstractArray.h:45,
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkVariant.h:269: error: ‘vtkTypeInt64’ does not name a type
/home/user/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkVariant.h:270: error: ‘vtkTypeUInt64’ does not name a type
make: *** [Make/linux64GccDPOpt/vtkPV3Foam.o] Error 1
+ cd PV3FoamReader
+ mkdir -p Make/linux64GccDPOpt
+ cd Make/linux64GccDPOpt
+ cmake ../..
-- Check for working C compiler: /home/user/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc
-- Check for working C compiler: /home/user/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- works
-- Check size of void*
-- Check size of void* - done
-- Check for working CXX compiler: /home/user/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/c++
-- Check for working CXX compiler: /home/user/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/c++ -- works
CMake Error: ParaView_DIR is not set. It must be set to the directory containing ParaViewConfig.cmake in order to use ParaView.
-- Configuring done
+ make
make: *** No targets specified and no makefile found. Stop.
as the report says, No target specified found.
could you please help , how to solve this problem?
many thanks
Old   March 31, 2009, 07:36
jlakovic
Download the package ThirdParty.linux64Gcc.gtgz and extract it to your OpenFOAM directory:
wget http://mesh.dl.sourceforge.net/sourc...inux64Gcc.gtgz
tar xzf ThirdParty.linux64Gcc.gtgz -C /home/user/OpenFOAM
Last edited by jlakovic; March 31, 2009 at 15:14. Reason: named wrong package; added link for convenience
How to install OpenFoam in Windows XP robert_dekker OpenFOAM Installation 4 October 20, 2010 22:15
install the openfoam aya CFX 4 July 23, 2008 08:58
How to run Openfoam in a cluster after I install it xiuying OpenFOAM Installation 5 May 5, 2008 13:54
OpenFOAM and Paraview install issues spridal86 OpenFOAM Installation 7 February 13, 2008 14:15
Having problems to Install OpenFOAM 13 release of PowerLab2 ed_teller OpenFOAM Installation 0 June 11, 2007 11:50
