[OpenFOAM.org] Building buoyantBoussinesqPimpleEHDFoam under OpenFOAM4 |
November 14, 2024, 19:59 |
James bowery
Rep Power: 17 |
buoyantBoussinesqPimpleEHDFoam specifies OpenFOAM v-4.1. As I was not prepared to figure out how to build such an ancient version from source, on the latest Ubuntu, I decided to try the Docker image openfoam/openfoam4-paraview50. However when attempting to wmake the source for buoyantBoussinesqPimpleEHDFoam, I was stumped by this error:
/usr/bin/ld: cannot open output file /opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/buoyantBoussinesqPimpleEHDFoam: Permission denied collect2: error: ld returned 1 exit status /opt/openfoam4/wmake/makefiles/general:132: recipe for target '/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/buoyantBoussinesqPimpleEHDFoam' failed make: *** [/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/buoyantBoussinesqPimpleEHDFoam] Error 1 Here are the relevant environment variables: Code:
OpenFOAM-4.1(63) printenv|grep -i foam FOAM_SOLVERS=/opt/openfoam4/applications/solvers FOAM_EXT_LIBBIN=/opt/ThirdParty-4.1/platforms/linux64GccDPInt32/lib FOAM_APPBIN=/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin FOAM_TUTORIALS=/opt/openfoam4/tutorials FOAM_JOB_DIR=/opt/jobControl FOAM_SITE_APPBIN=/opt/site/4.1/platforms/linux64GccDPInt32Opt/bin FOAM_APP=/opt/openfoam4/applications user=openfoam FOAM_SITE_LIBBIN=/opt/site/4.1/platforms/linux64GccDPInt32Opt/lib LD_LIBRARY_PATH=/opt/ThirdParty-4.1/platforms/linux64Gcc/gperftools-svn/lib:/opt/paraviewopenfoam50/lib/paraview-5.0:/opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/openmpi-system:/opt/ThirdParty-4.1/platforms/linux64GccDPInt32/lib/openmpi-system:/usr/lib/openmpi/lib:/home/openfoam/platforms/linux64GccDPInt32Opt/lib:/opt/site/4.1/platforms/linux64GccDPInt32Opt/lib:/opt/openfoam4/platforms/linux64GccDPInt32Opt/lib:/opt/ThirdParty-4.1/platforms/linux64GccDPInt32/lib:/opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/dummy FOAM_SRC=/opt/openfoam4/src FOAM_SIGFPE= ParaView_DIR=/opt/paraviewopenfoam50 FOAM_UTILITIES=/opt/openfoam4/applications/utilities WM_PROJECT_DIR=/opt/openfoam4 WM_PROJECT=OpenFOAM PATH=/opt/ThirdParty-4.1/platforms/linux64Gcc/gperftools-svn/bin:/opt/paraviewopenfoam50/bin:/home/openfoam/platforms/linux64GccDPInt32Opt/bin:/opt/site/4.1/platforms/linux64GccDPInt32Opt/bin:/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin:/opt/openfoam4/bin:/opt/openfoam4/wmake:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin FOAM_USER_LIBBIN=/home/openfoam/platforms/linux64GccDPInt32Opt/lib PWD=/home/openfoam/buoyantBoussinesqPimpleEHDFoam/buoyantBoussinesqPimpleEHDFoam FOAM_ETC=/opt/openfoam4/etc PV_PLUGIN_PATH=/opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/paraview-5.0 FOAM_INST_DIR=/opt ParaView_INCLUDE_DIR=/opt/paraviewopenfoam50/include/paraview-5.0 FOAM_MPI=openmpi-system FOAM_LIBBIN=/opt/openfoam4/platforms/linux64GccDPInt32Opt/lib WM_DIR=/opt/openfoam4/wmake HOME=/home/openfoam XDG_CONFIG_HOME=/home/openfoam/.config FOAM_SETTINGS= FOAMY_HEX_MESH=yes WM_PROJECT_USER_DIR=/home/openfoam FOAM_RUN=/home/openfoam/run FOAM_USER_APPBIN=/home/openfoam/platforms/linux64GccDPInt32Opt/bin OLDPWD=/home/openfoam/buoyantBoussinesqPimpleEHDFoam OpenFOAM-4.1(64) pwd /home/openfoam/buoyantBoussinesqPimpleEHDFoam/buoyantBoussinesqPimpleEHDFoam |
docker, ehd, opanfoam4.x, wmake |
Building direct interaction list for stirred column with Lagrangian Particles | nuzzknacker | OpenFOAM Running, Solving & CFD | 0 | September 6, 2024 06:23 |
[OpenFOAM.org] Instructions to install OpenFOAM-2.4.x on CentOS-6.10 | redbullah | OpenFOAM Installation | 9 | September 7, 2019 18:18 |
[foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 15:56 |
Paraview Compiling Error (OpenFOAM 2.1.x + openSUSE 12.2) | sfigato | OpenFOAM Installation | 22 | January 31, 2013 11:16 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 05:55 |
