[OpenFOAM.com] funkySetBoundaryField: Istream not OK for reading dictionary
Old   September 22, 2024, 21:13
Default funkySetBoundaryField: Istream not OK for reading dictionary
Oscar Zagal
oscar_zagal is on a distinguished road
Hi dear all, I am using the solver chtMultiRegionTwoPhaseEulerFoam. I have some trouble with swak4foam:
The content of my funkySetBoundaryDict is:
| \\ / O peration | Version: v2312 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
inletGas
field alpha.gas;
expressions
target value;
patchName inlet;
variables "posX=pos().x;posY=pos().y;";
expression "pow(posX,2) + pow(posY,2) < pow(0.020,2)";
when I try to set the field with funkySetBoundaryField -time 0 terminal prints the next output:
swakVersion: 202x.yy (Release date: Next release)
Create time
Create mesh for time = 0
Time = 0
Part: inletGas working on field alpha.gas
--> FOAM FATAL IO ERROR: (openfoam-2312 patch=240220)
From bool Foam::dictionary::read(Foam::Istream&, bool)
in file db/dictionary/dictionaryIO.C at line 93.
FOAM exiting
can you please give some help with this issue?
Best regards, Oscar
Last edited by oscar_zagal; September 22, 2024 at 21:27. Reason: adding vital information
oscar_zagal is offline   Reply With Quote
How to create a dictionary from a *char[]? jgs55 OpenFOAM Programming & Development 0 January 24, 2023 07:33
What are dictionaries in Openfoam ? granzer OpenFOAM 3 November 25, 2020 01:47
driftFluxFoam viscosity model modification problem dleduc OpenFOAM Programming & Development 15 October 1, 2018 10:37
ill defined primitiveEntry starting at keyword 'value' on line 197 ChangeDictionary Struggle_Achieve OpenFOAM Pre-Processing 2 December 20, 2017 04:58
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
