[OpenFOAM.org] wmake doesnt recognize subfolders
Old   August 23, 2024, 11:22
Default wmake doesnt recognize subfolders
Lizz4rd is on a distinguished road
I would like to compile a Cantera library. However, when using wmake I get the following error messages that it cannot find many header files
could not open file Reactor.h for source file CanteraSolvers.C due to No such file or directory
could not open file ReactorBase.h for source file CanteraSolvers.C due to No such file or directory
could not open file IdealGasReactor.h for source file CanteraSolvers.C due to No such file or directory
could not open file ConstPressureReactor.h for source file CanteraSolvers.C due to No such file or directory
could not open file FlowDevice.h for source file CanteraSolvers.C due to No such file or directory
could not open file Phase.h for source file CanteraSolvers.C due to No such file or directory
could not open file MultiSpeciesThermo.h for source file CanteraSolvers.C due to No such file or directory
could not open file StoichManager.h for source file CanteraSolvers.C due to No such file or directory
could not open file ct_defs.h for source file CanteraSolvers.C due to No such file or directory
could not open file config.h for source file CanteraSolvers.C due to No such file or directory
could not open file ThermoPhase.h for source file CanteraSolvers.C due to No such file or directory
could not open file Kinetics.h for source file CanteraSolvers.C due to No such file or directory
could not open file MultiRate.h for source file CanteraSolvers.C due to No such file or directory
could not open file SparseCore for source file CanteraSolvers.C due to No such file or directory
could not open file OrderingMethods for source file CanteraSolvers.C due to No such file or directory
could not open file SparseCholesky for source file CanteraSolvers.C due to No such file or directory
could not open file SparseLU for source file CanteraSolvers.C due to No such file or directory
could not open file SparseQR for source file CanteraSolvers.C due to No such file or directory
could not open file IterativeLinearSolvers for source file CanteraSolvers.C due to No such file or directory
could not open file core.h for source file CanteraSolvers.C due to No such file or directory
could not open file format-inl.h for source file CanteraSolvers.C due to No such file or directory
could not open file format.h for source file CanteraSolvers.C due to No such file or directory
In env_vars.sh I have defined the path where the files are located
#!/bin/sh
    export PYBIND11_INC_DIR=$(python3 -m pybind11 --includes)
    export PYBIND11_LIB_DIR=$(python3 -c 'from distutils import sysconfig; print(sysconfig.get_config_var("LIBDIR"))')
    export CANTERA_INC_DIR="/home/user/miniconda3/envs/openfoam/include"
    export CANTERA_LIB_DIR="/home/user/miniconda3/envs/openfoam/lib"
        export OLD_LD_LIBRARY_PATH=$LD_LIBRARY_PATH
       export LD_LIBRARY_PATH=$PYBIND11_LIB_DIR:$CANTERA_LIB_DIR:$LD_LIBRARY_PATH
In the Make Options I reference the path
EXE_INC = \
    -I$(LIB_SRC)/physicalProperties/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/multicomponentThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/functions/Polynomial \
    -I$(LIB_SRC)/ODE/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/chemistryModel/lnInclude \
    -I$(CANTERA_INC_DIR) \
    -Wno-unused-variable \
    -Wno-old-style-cast \
    -std=c++17
The missing files are located in subfolders, e.g. cantera/zeroD
If I specify these paths separately, it will also find the files. But this is very complicated. I would be grateful for any help.
Lizz4rd is offline   Reply With Quote
[OpenFOAM.com] Installing OpenFOAM on hpc nang19960916 OpenFOAM Installation 1 November 25, 2022 19:52
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 02:36
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 05:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 22:45
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 14:28
