July 25, 2024, 01:07 |
Conflicting Installation
HyunGoo Moon
After making mistakes in customizing my own FvPatchField, I had to recompile the OpenFOAM.
the result of foamInstallationTest says there are conflicting installations. How can I solve this issue? Basic setup : ------------------------------------------------------------------------------- OpenFOAM: OpenFOAM-v2306 ThirdParty: ThirdParty-v2306 Shell: bash Host: OS: Linux version 3.10.0-1062.18.1.el7.x86_64 ------------------------------------------------------------------------------- Main OpenFOAM env variables : ------------------------------------------------------------------------------- Environment FileOrDirectory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_USER_DIR /home/name/OpenFOAM/name-v2306 yes no $WM_THIRD_PARTY_DIR ...pc/pub/apps/OpenFOAM/ThirdParty-v2306 yes maybe $WM_PROJECT_SITE [env variable unset] no ------------------------------------------------------------------------------- OpenFOAM env variables in PATH : ------------------------------------------------------------------------------- Environment FileOrDirectory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR ...ohpc/pub/apps/OpenFOAM/OpenFOAM-v2306 yes yes yes $FOAM_APPBIN ...06/platforms/linux64GccDPInt64Opt/bin yes yes yes $FOAM_SITE_APPBIN ...06/platforms/linux64GccDPInt64Opt/bin no no $FOAM_USER_APPBIN ...06/platforms/linux64GccDPInt64Opt/bin yes yes no $WM_DIR ...ub/apps/OpenFOAM/OpenFOAM-v2306/wmake yes yes often ------------------------------------------------------------------------------- OpenFOAM env variables in LD_LIBRARY_PATH : ------------------------------------------------------------------------------- Environment FileOrDirectory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...06/platforms/linux64GccDPInt64Opt/lib yes yes yes $FOAM_SITE_LIBBIN ...06/platforms/linux64GccDPInt64Opt/lib no no $FOAM_USER_LIBBIN ...06/platforms/linux64GccDPInt64Opt/lib yes yes no $FOAM_EXT_LIBBIN ...v2306/platforms/linux64GccDPInt64/lib yes yes maybe $MPI_ARCH_PATH ...06/platforms/linux64Gcc/openmpi-4.1.2 yes yes yes ------------------------------------------------------------------------------- Software Components ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- flex 2.5.37 /usr/bin/flex make 3.82 /usr/bin/make wmake 2306 /opt/ohpc/pub/apps/OpenFOAM/OpenFOAM-v2306/wmake/wmake gcc 7.3.0 /opt/ohpc/pub/compiler/gcc/7.3.0/bin/gcc g++ 7.3.0 /opt/ohpc/pub/compiler/gcc/7.3.0/bin/g++ ------------------------------------------------------------------------------- icoFoam WARNING: Conflicting installations: OpenFOAM settings : /opt/ohpc/pub/apps/OpenFOAM/OpenFOAM-v2306/platforms/linux64GccDPInt64Opt/bin/icoFoam current path : /home/name/OpenFOAM/name-v2306/platforms/linux64GccDPInt64Opt/bin/icoFoam CRITICAL ERROR Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for troubleshooting. Done |
Ansys Installation on Docker Container | mohsen.shiea | ANSYS | 11 | March 14, 2024 11:18 |
Installation problems | indy | OpenFOAM Installation | 7 | April 3, 2009 09:40 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Conflicting installation of c | yejungong | OpenFOAM Installation | 0 | March 26, 2008 10:44 |
Installation problems | shellbell1999 | OpenFOAM Installation | 9 | April 6, 2006 13:29 |
