[OpenFOAM.com] paraFoam can't connect to display |
June 25, 2024, 22:50 |
Asiimwe Paul
When I run the "paraFoam" command just after installing OpenFOAM and going through the first test example, I receive the following response:
qt.qpa.xcb: could not connect to display qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found. This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem. Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb. Aborted I have tried many ways to go about this including the a windows X server download for WSL2, checked firewall settings etc but still no luck. Any ideas on how to solve this? |
#parafoam, #paraview, #qt, #xcb |
[OpenFOAM] QXcbConnection: Could not connect to display :0 | Schurl | ParaView | 7 | March 11, 2019 06:19 |
error: connect failed | destroy | FLUENT | 7 | March 18, 2018 14:59 |
[Other] paraFoam error | scybchenjun | OpenFOAM Meshing & Mesh Conversion | 0 | May 11, 2016 23:25 |
[OpenFOAM] Xlib: extension "GLX" missing on display | goldbeard | ParaView | 5 | March 24, 2013 13:12 |
errors when installing openfoam2.1 on ubuntu12.o4 | hewei | OpenFOAM Installation | 5 | May 29, 2012 07:43 |
