[OpenFOAM.com] Cant find simpleFoam executable on aws cluster |
Tom
Rep Power: 2 ![]() |
I am going through the step by step guide on setting up an aws cluster and install of openFoam (here)
When I submit the motor bike tutorial run that's included, the blockmesh and snappyhexmesh run correctly, however the simplefoam command does not run and i get the error "mpirun was unable to find the specified executable file"..... "Executable: simpleFoam" in the log file. My submit file: Code:
#!/bin/bash #SBATCH --job-name=foam #SBATCH --ntasks=288 #SBATCH --output=%x_%j.out #SBATCH --partition=compute module load openmpi source /fsx/OpenFOAM/OpenFOAM-v2312/etc/bashrc surfaceFeatureExtract > ./log/surfaceFeatureExtract.log 2>&1 blockMesh > ./log/blockMesh.log 2>&1 decomposePar -decomposeParDict system/decomposeParDict.hierarchical > ./log/decomposePar.log 2>&1 mpirun -np $SLURM_NTASKS snappyHexMesh -parallel -overwrite -decomposeParDict system/decomposeParDict.hierarchical > ./log/snappyHexMesh.log 2>&1 mpirun -np $SLURM_NTASKS checkMesh -parallel -allGeometry -constant -allTopology -decomposeParDict system/decomposeParDict.hierarchical > ./log/checkMesh.log 2>&1 mpirun -np $SLURM_NTASKS redistributePar -parallel -overwrite -decomposeParDict system/decomposeParDict.ptscotch > ./log/decomposePar2.log 2>&1 mpirun -np $SLURM_NTASKS renumberMesh -parallel -overwrite -constant -decomposeParDict system/decomposeParDict.ptscotch > ./log/renumberMesh.log 2>&1 mpirun -np $SLURM_NTASKS patchSummary -parallel -decomposeParDict system/decomposeParDict.ptscotch > ./log/patchSummary.log 2>&1 ls -d processor* | xargs -i rm -rf ./{}/0 ls -d processor* | xargs -i cp -r 0.orig ./{}/0 mpirun -np $SLURM_NTASKS simpleFoam -parallel -decomposeParDict system/decomposeParDict.ptscotch > ./log/simpleFoam.log 2>&1 Thanks! Tom |
Tom
I have run the foamInstallationTest and got the output below. It looks like icoFoam was not installed correctly. I've tried doing a search on how to correct this but have not found any examples that are applicable to my application. If there are any thoughts on this it would be much appreciated.
Shell: bash Host: ip-172-31-29-242 OS: Linux version 5.10.218-208.862.amzn2.x86_64 System check: PASS ================== Can continue to OpenFOAM installation. [ec2-user@ip-172-31-29-242 OpenFOAM]$ foamInstallationTest Executing foamInstallationTest Basic setup : ------------------------------------------------------------------------------- OpenFOAM: OpenFOAM-v2312 ThirdParty: ThirdParty-v2312 Shell: bash Host: ip-172-31-29-242 OS: Linux version 5.10.218-208.862.amzn2.x86_64 ------------------------------------------------------------------------------- Main OpenFOAM env variables : ------------------------------------------------------------------------------- Environment FileOrDirectory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_USER_DIR /home/ec2-user/OpenFOAM/ec2-user-v2312 no no $WM_THIRD_PARTY_DIR /fsx/OpenFOAM/ThirdParty-v2312 yes maybe $WM_PROJECT_SITE [env variable unset] no ------------------------------------------------------------------------------- OpenFOAM env variables in PATH : ------------------------------------------------------------------------------- Environment FileOrDirectory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /fsx/OpenFOAM/OpenFOAM-v2312 yes yes yes $FOAM_APPBIN ...12/platforms/linux64GccDPInt32Opt/bin yes yes yes $FOAM_SITE_APPBIN ...12/platforms/linux64GccDPInt32Opt/bin no no [ec2-user@ip-172-31-29-242 OpenFOAM]$ $WM_DIR /fsx/OpenFOAM/OpenFOAM-v2312/wmake yes yes often ------------------------------------------------------------------------------- OpenFOAM env variables in LD_LIBRARY_PATH : ------------------------------------------------------------------------------- Environment FileOrDirectory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...12/platforms/linux64GccDPInt32Opt/lib yes yes yes $FOAM_SITE_LIBBIN ...12/platforms/linux64GccDPInt32Opt/lib no no $FOAM_USER_LIBBIN ...12/platforms/linux64GccDPInt32Opt/lib no no $FOAM_EXT_LIBBIN ...v2312/platforms/linux64GccDPInt32/lib yes yes maybe $MPI_ARCH_PATH /opt/amazon/openmpi yes no yes ------------------------------------------------------------------------------- Software Components ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- flex 2.5.37 /usr/bin/flex make 3.82 /usr/bin/make wmake 2312 /fsx/OpenFOAM/OpenFOAM-v2312/wmake/wmake gcc 7.3.1 /usr/bin/gcc g++ 7.3.1 /usr/bin/g++ ------------------------------------------------------------------------------- icoFoam *** not installed *** CRITICAL ERROR Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for troubleshooting. Done |
Mark Olesen
Rep Power: 40 ![]() ![]() |
Examine the contents of the FOAM_APPBIN and the FOAM_LIBBIN directories. They really should contain something...
Tom
Thanks for the response.
When searching for either directory (FOAM_APPBIN, FOAM_LIBBIN) in my OpenFoam-v2312 directory does not return anything. Is there a typical file path for these directories? I am also not finding them in the .tgz files (which I downloaded from here: https://develop.openfoam.com/Develop...r/doc/Build.md) |
SimpleFoam convergence problems | brahim | OpenFOAM Running, Solving & CFD | 20 | June 9, 2015 09:09 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 06:32 |
OpenFoam 2.0.0 installation + ICC + Rocks Cluster | chinper | OpenFOAM Installation | 5 | July 13, 2011 16:00 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
