[OpenFOAM.com] OpenFOAM dynamic library linking with GUIX. |
May 17, 2024, 10:49 |
Rep Power: 7 |
Hi everyone,
I'm having some trouble getting various versions of OpenFOAM to link properly with dynamic libraries installed on a HPC cluster. The GUIX package manager is used to install the required version of the library, but I would rather use the pre-installed libraries on the cluster. For example, if I build OpenFOAM-5.x and run, I get the error "error while loading shared libraries: libz.so.1: cannot open shared object file: No such file or directory". zlib is installed on the cluster, but it's under "libz.so", not "libz.so.1" Similarly, if I build OpenFOAM-v2312 and try to run I get "/lib64/libm.so.6: version `GLIBC_2.29' not found". libc is installed, but it's under libc-2.28.so How does wmake determine the path of the linked library during build, is it hard-coded? And is there any way to get it to point to the pre-installed libraries instead? Best regards, Vivio |
dynamic library not found | nor nazifah | System Analysis | 1 | June 22, 2024 16:12 |
how to link the path of a newly compiled library to another library in OpenFOAM | sourav8016 | OpenFOAM | 3 | December 28, 2023 17:21 |
What's the Eigen library setup for OpenFOAM? | klausb | OpenFOAM Programming & Development | 3 | December 12, 2023 17:37 |
Dynamic Contact Angle library install and Helyx-OpenFoam Connection | alinuman15 | OpenFOAM | 0 | May 31, 2016 01:30 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 08:53 |
