[Other] Persistent difficulty installing and running libAcoustics |
January 12, 2024, 10:08 |
Niall O'Neill
Rep Power: 3 |
I have spent the past 2 days trying to get libAcoustics working and I am getting nowhere. I have tried many different approaches such as https://www.youtube.com/watch?v=Fym_...ist=LL&index=2 and libacoustic but regardless, I seem to be getting the same problem when running one of the tutorial cases "--> FOAM Warning : From void* Foam::dlLibraryTable:penLibrary(const Foam::fileName&, bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 188 Could not load "libAcoustics.so"" at the end of the output from the (wmakeAll) file, I get the following: "/usr/bin/ld: cannot find -lAcoustics: No such file or directory collect2: error: ld returned 1 exit status make: *** [/usr/lib/openfoam/openfoam2312/wmake/makefiles/general:174: /home/niall/OpenFOAM/niall-v2312/platforms/linux64GccDPInt32Opt/bin/surfaceNoise] Error 1 " I would have hoped it would be somewhat of a straightforward process just installing a library, and assumed the hard part would actually be the simulation settings, but I have hit a major block in the road before even starting here, and I am not even remotely sure where to go. Any advice would be much appreciated, thanks! |
January 12, 2024, 14:13 |
Joern Beilke
Rep Power: 20 |
You should use OF v2212.
The latest version of libAcoustics is this: https://github.com/unicfdlab/libAcoustics/tree/v2212 |
January 14, 2024, 11:09 |
Niall O'Neill
Rep Power: 3 |
Update: It turns out that the version of OpenFOAM that I am using needed to be the exact same as the version of libAcoustics, who would have thunk
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
[OpenFOAM.org] Installing and Running on a Cluster | Lucc | OpenFOAM Installation | 2 | August 11, 2022 15:03 |
[foam-extend.org] Problems installing the FSI-toolkit on foam-extend-4.0 | Elstro | OpenFOAM Installation | 0 | June 20, 2021 18:50 |
[OpenFOAM.com] Installing and running Swak4Foam on 1912 docker | hektorWartgard | OpenFOAM Installation | 3 | May 25, 2021 14:00 |
[Other] Basic questions about OpenFOAM cluster running and installing | Fauster | OpenFOAM Installation | 0 | May 25, 2018 16:00 |
