[OpenFOAM.org] Docker no longer works
Old   December 11, 2023, 20:45
Default Docker no longer works
ET3
Erik T
ET3 is on a distinguished road
Hi All,
I had openFOAM7 installed on my Centos 7 machine. A few days ago I said yes to a Centos update.
Now when I try to run OF, I get a docker-related error:
docker: invalid spec: :/home/openfoam/.Xauthority: empty section between colons.
If you have any idea what might be causing this or how I can fix it, I sure would appreciate it.
I want to add that I would like to stick with OF7 because I use rhocentralfoam, so I dont want to update.
Thanks,
ET
ET3 is offline   Reply With Quote
Old   April 30, 2024, 15:42
Ching Liu
qingqingliu is on a distinguished road
Have you solved this issue? I met the same issue.
Originally Posted by ET3 View Post
Hi All,
Thanks,
ET
qingqingliu is offline   Reply With Quote
Old   April 30, 2024, 18:05
ET3
Erik T
Unfortunately, my memory and understanding of how I got this fixed is not very clear. But I *think* that the solution was to open up space by deleting unnecessary files from where the affected area (the are named between colons, ":/home/openfoam/.Xauthority") was. For some reason dockers fill up my memory with things like crash logs that are not needed. I hope this may help.
centos 7, docker
mpirun during simulation under Docker (start with ./startOpenFOAM) spalartallmaras OpenFOAM Running, Solving & CFD 1 November 3, 2021 05:13
[OpenFOAM.com] Installing and running Swak4Foam on 1912 docker hektorWartgard OpenFOAM Installation 3 May 25, 2021 14:00
How to run an external solver? ([OpenFOAM.com] v2006, docker, win7) complete.basis OpenFOAM Programming & Development 3 February 1, 2021 10:38
[OpenFOAM.org] Compile utilities in openfoam4-linux docker image? fatirishman53 OpenFOAM Installation 1 April 3, 2017 16:23
[GAMBIT] Gambit no longer works FrancescoB ANSYS Meshing & Geometry 1 March 26, 2010 16:46
