[OpenFOAM.org] Terminal shows blank screen after adding a line 'source /opt/openfoam11/etc/bashrc'
Old   December 6, 2023, 07:47
Default Terminal shows blank screen after adding a line 'source /opt/openfoam11/etc/bashrc'
Jinbong Kim
Jinbong is on a distinguished road
I am following the instructions posted on openfoam.org
(https://openfoam.org/download/11-ubuntu/)
At the User configuration, I could not go further because adding the following line 'source /opt/openfoam11/etc/bashrc' to the .bashrc file makes my ubuntu terminal blank screen(no prompt appearing)
Return to the original bashrc by removing the line makes the terminal work
What is the problem here?
Jinbong is offline   Reply With Quote
Old   December 6, 2023, 11:55
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
I would guess that you might have somehow created an infinite loop of sourcing itself - but that really is just a guess.
Could also try installing the openfoam-selector (follow some of the instructions: https://develop.openfoam.com/Develop...ompiled/debian)
The openfoam-selector is dead simple, but makes it simpler to switch between different versions.
olesen is offline   Reply With Quote
Old   December 8, 2023, 16:14
Jinbong Kim
Re-install solved the problem. Thank you
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
