[OpenFOAM.com] Error getting while installing openFoam 1606 on ubuntu22.04
Old   September 9, 2023, 09:06
Exclamation Error getting while installing openFoam 1606 on ubuntu22.04
Swaraj Bhure
Swaraj is on a distinguished road
Hi community
I am trying to install openFoam-v1606 on ubuntu 22.04 using source code with help of
https://openfoamwiki.net/index.php/I...1606%2B/Ubuntu
commands from the above website.
After putting the ./Allwmake command I am getting the following error:
fileStat.C:78:13: error: ‘major’ was not declared in this scope
78 | major(status_.st_dev) == major(stat2.status().st_dev)
fileStat.C:79:13: error: ‘minor’ was not declared in this scope
79 | && minor(status_.st_dev) == minor(stat2.status().st_dev)
fileStat.C: In function ‘Foam::Istream& Foam:perator>>(Foam::Istream&, Foam::fileStat&)’:
fileStat.C:104:20: error: ‘makedev’ was not declared in this scope
104 | dev_t st_dev = makedev(stat[1], stat[2]);
fileStat.C: In function ‘Foam::Ostream& Foam:perator<<(Foam::Ostream&, const Foam::fileStat&)’:
fileStat.C:132:21: error: ‘major’ was not declared in this scope
132 | stat[1] = label(major(fStat.status_.st_dev));
fileStat.C:133:21: error: ‘minor’ was not declared in this scope
133 | stat[2] = label(minor(fStat.status_.st_dev));
In file included from /home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/token.H:46,
from /home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/Istream.H:47,
from /home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/ISstream.H:39,
from /home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/IOstreams.H:38,
from fileStat.C:27:
/home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/typeInfo.H: In instantiation of ‘To& Foam::dynamicCast(From&) [with To = Foam::token::Compound<Foam::List<int> >; From = Foam::token::compound]’:
/home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/FixedListIO.C:58:13: required from ‘Foam::Istream& Foam:perator>>(Foam::Istream&, Foam::FixedList<T, Size>&) [with T = int; unsigned int Size = 13]’
/home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/FixedListIO.C:37:15: required from ‘Foam::FixedList<T, Size>::FixedList(Foam::Istream&) [with T = int; unsigned int Size = 13]’
fileStat.C:100:33: required from here
/home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/typeInfo.H:91:5: warning: catching polymorphic type ‘class std::bad_cast’ by value [-Wcatch-value=]
91 | catch (std::bad_cast)
make: * [/home/varphi/OpenFOAM/OpenFOAM-plus/wmake/rules/General/transform:8: /home/varphi/OpenFOAM/OpenFOAM-plus/platforms/linux64GccDPInt32Opt/src/OSspecific/POSIX/fileStat.o] Error 1.
Please tell me, what should I do to resolve this error.
@wyldkat
Swaraj is offline   Reply With Quote
openfoam installation
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
[OpenFOAM.org] Installing OpenFoam 3.0.1 on cluster hello177 OpenFOAM Installation 1 April 24, 2016 09:35
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 wyldckat OpenFOAM Installation 14 February 12, 2013 05:43
