[OpenFOAM.org] mpi shared library issue in Azure cluster & slurm
Old   July 25, 2023, 04:13
Default mpi shared library issue in Azure cluster & slurm
Song Young Ik
songyi719 is on a distinguished road
I am using Azure cluster with slurm, and trying to run openfoam in multiple node. So I installed openfoam in shared disk.
However, when I try to run openfoam script with srun, it returns error.
error while loading shared libraries: libmpi.so.40: cannot open shared object file: No such file or directory
When I type $WM_MPLIB, it returns SYSTEMOPENMPI, It seems like mpi have some error in compute nodes. How can I fix it? How can I make every compute nodes to have every necessary programs installed through server node?
songyi719 is offline   Reply With Quote
azure, cluster, mpi, slurm
[foam-extend.org] foam-extend-3.1 installation on cluster using system mpi and intel compiler mmmn036 OpenFOAM Installation 3 February 12, 2019 11:26
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 15:53
Fluent MPI process doesn't end in cluster martins ANSYS 0 November 5, 2013 05:18
Run Functions Failed - Attempted MPI Cluster LordLoss OpenFOAM Pre-Processing 0 August 14, 2013 08:43
