[OpenFOAM.org] Compiling problems on installing packages for Paraview-'qt5-default' installation err |
Rep Power: 0 ![]() |
When installing packages for Paraview on Ubuntu22.0.4 as
HTML Code:
https://openfoam.org/download/source/software-for-compilation/ It appears that: Code:
Package qt5-default is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'qt5-default' has no installation candidate Code:
sudo apt-get install qt5-default When installing all dependencies of qt5-defalt package with: Code:
sudo apt-get install qtbase5-dev qtchooser qt5-qmake qtbase5-dev-tools Could anyone give some advice? Great thanks in advance!!! |
Kanuk
Rep Power: 15 ![]() |
Hello Kaiqi,
Have you found a solution for this? I have a fresh install of Ubuntu 22.04 and getting the same error - as a result I'm unable to build paraview for OpenFoam 11 Cheers D |
Kanuk
Figured I would post an update as I've found a workaround from the below link:
https://discourse.paraview.org/t/seg...tu-22-04/13997 In short, there's an issue with my OpenGL but you can install OpenFoam 11 from the repositories and start paraFoam with the following: ParaView_GL="" paraFoam Hope this helps someone... |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Problems installing SVN in Ubuntu (for later installing PyFoam for OpenFOAM) | immortality | Lounge | 2 | May 24, 2014 03:05 |
Openfoam Ubuntu 12.04 Unmet dependencies | slls33 | OpenFOAM Installation | 10 | April 9, 2013 04:16 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Installation problems | shellbell1999 | OpenFOAM Installation | 9 | April 6, 2006 13:29 |
