February 21, 2023, 17:11 |
Errors building addr2line
Anthony Allison
I am building OpenFOAM-v2212 on macOS Ventura, and can't fix the error below that occurs when trying to build addr2line. I was trying to build this separately, because when I run Allwmake from my foam directory, I get errors about addr2line.o missing. Any help would be much appreciated.
anthony@Tony-MacBook-Pro OpenFOAM-v2212 % ./applications/utilities/miscellaneous/OSspecific/Allwmake ==> Darwin-specific utilities wmake addr2line clang++ -std=c++14 -m64 -pthread -ftrapping-math -DOPENFOAM=2212 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-undefined-var-template -Wno-unknown-warning-option -O3 -DNoRepository -ftemplate-depth-100 -iquote. -IlnInclude -I/Users/anthony/OpenFOAM/OpenFOAM-v2212/src/OpenFOAM/lnInclude -I/Users/anthony/OpenFOAM/OpenFOAM-v2212/src/OSspecific/POSIX/lnInclude -fPIC -Wl,-execute,-undefined,dynamic_lookup /Users/anthony/OpenFOAM/OpenFOAM-v2212/build/darwin64ClangDPInt64Opt/applications/utilities/miscellaneous/OSspecific/addr2line/addr2line.o -L/Users/anthony/OpenFOAM/OpenFOAM-v2212/platforms/darwin64ClangDPInt64Opt/lib \ -lOpenFOAM -ldl \ -lm -o /Users/anthony/OpenFOAM/OpenFOAM-v2212/platforms/darwin64ClangDPInt64Opt/bin/addr2line ld: library not found for -lOpenFOAM clang-15: error: linker command failed with exit code 1 (use -v to see invocation) make: *** [/Users/anthony/OpenFOAM/OpenFOAM-v2212/platforms/darwin64ClangDPInt64Opt/bin/addr2line] Error 1 |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
[OpenFOAM.org] Instructions to install OpenFOAM-2.4.x on CentOS-6.10 | redbullah | OpenFOAM Installation | 9 | September 7, 2019 18:18 |
GAMG crash | fxzf | OpenFOAM Running, Solving & CFD | 6 | June 5, 2018 06:09 |
[swak4Foam] groovyBC issue - k and epsilon | sagnikmazumdar | OpenFOAM Community Contributions | 24 | March 1, 2015 08:16 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 05:55 |
