[OpenFOAM.com] There is no bin folder inside the installation directory
Old   January 4, 2023, 09:39
Default There is no bin folder inside the installation directory
Foad
foadsf is on a distinguished road
Following this post, I installed OpenFOAM inside the WSL2/Ubuntu from the default repository:
sudo apt install openfoam
I found the bashrc file in
/usr/share/openfoam/etc/
directory, but when I source the bashrc file I get the error messages:
-bash: /usr/share/openfoam/bin/foamEtcFile: No such file or directory
-bash: /usr/share/openfoam/bin/foamCleanPath: No such file or directory
indicating that there is no bin folder in the installation location. Please help me understand what the problem is and how I can resolve it.
P.S. for those who end up here, the OpenFOAM examples are installed in the "/usr/share/doc/openfoam-examples/" directory.
foadsf is offline   Reply With Quote
Old   January 4, 2023, 11:00
s1291's Avatar
s1291 is on a distinguished road
To correctly install OpenFOAM ESI versions, see the instructions here:
https://develop.openfoam.com/Develop.../debian#ubuntu
"When in doubt, use brute force." -- Ken Thompson
s1291 is offline   Reply With Quote
Old   January 6, 2023, 07:16
Foad
Following my own instruction here, I ran the command
bash --debug /usr/share/openfoam/etc/bashrc
and realized the files "setup" and "functions", in the "/usr/share/openfoam/etc/config.sh/" directory, have several references to the above files. By commenting them out I could stop the error messages (check the modified scripts in the attachments). But please consider that this is not a solution at all.
Old   January 6, 2023, 15:24
s1291's Avatar
Unless you've got a very good reason for using an outdated version (v1906) with a potentially faulty setup, you're setting yourself up for a lot of headaches.
It's just two commands away to get a fully functioning recent version (such as v2212):
sudo apt remove openfoam  -y
wget -q -O - https://dl.openfoam.com/add-debian-repo.sh | sudo bash
sudo apt install openfoam2212-default
bashrc, ubuntu, wsl2
Ansys Installation on Docker Container mohsen.shiea ANSYS 11 March 14, 2024 12:18
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
[OpenFOAM.com] Installation of OpenFOAM 1.7.1 on Ubuntu 16.04 MM_Khan OpenFOAM Installation 11 September 3, 2017 10:22
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 12:52
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
