[OpenFOAM.org] Cannot compile files belonging to root
Old   December 21, 2022, 11:32
Question Cannot compile files belonging to root
gneisenau10 is on a distinguished road
I want to install a module that works with an older OpenFOAM version (specifically version 6) and am trying to compile the module that I downloaded directly from GitHub.
However, whenever I try to compile it I have an error saying I cannot create a file required for the compilation.
Looking into it, I found that the owner of that path is "root" even though it is in my home directory.
I am using a Windows 11 computer, with WSL2 and Ubuntu on Windows to have access to a Linux environment.
I found this thread : From where do I get wmake?
which depicts a somewhat similar issue, but in his case it is because he did not setup his environment correctly (I did change the bashrc files in my case).
I also logged in as root to try and compile it but root does not know the wmake command, and I am a bit afraid to risk making mistakes while being the root user (I tried to add the path to the bashrc for the root user without much success).
I copied the module file directly from my windows download file, is it why?
Any help would be appreciated.
gneisenau10 is offline   Reply With Quote
compilation error, root access
Compiled library vs. inInclude Files, DSMC solver crashes after run GPesch OpenFOAM Programming & Development 8 April 18, 2013 08:17
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 11:46
MPI PROBLEMS gtg627e OpenFOAM Running, Solving & CFD 20 October 5, 2007 05:02
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
