[OpenFOAM.com] ./Allwmake : blockMesh not found
Old   November 12, 2022, 13:11
Default ./Allwmake : blockMesh not found
Kristjan Gjata
kristjan is on a distinguished road
Hello.
I'm trying to install openfoam10 in ubuntu linux via vitrual box.
I'm following the instructions of this guide:
https://openfoam.org/download/10-source/
When I run the command ./Allwmake for the compilaton, it runs but after some time my terminal disappears (I think it should be open after the compilation command).
Anyways, I'm trying to do the example to see if the installation is correct and at the blockMesh command it shows me the message:
Command 'blockmesh' not found but can be installed with sudo apt install openfoam
I did it, I ran the "sudo apt install openfoam" but after that it appears another error with the message:
blockMesh: symbol lookup error: /lib/libblockMesh.so: undefined symbol: _ZN4Foam8fileName20allowSpaceInfileNameE
Can someone help me please ?
kristjan is offline   Reply With Quote
./allwmake, blockmesh dict, openfoam 10
error in fireFoam, when running the case wallFireSpread2D zhoubiao1088 OpenFOAM Running, Solving & CFD 9 February 1, 2018 19:45
[swak4Foam] installation problem: "./Allwmake: ... [[: not found" Rajarshi OpenFOAM Community Contributions 8 May 13, 2013 09:05
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 12:37
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 14:28
