[OpenFOAM.com] Error compiling waves2Foam
Old   September 26, 2022, 12:11
Default Error compiling waves2Foam
Dimitris Tsoumpelis
Jim1310 is on a distinguished road
Hello foamers. I would like to report an error i am facing the last days when i try to compile waves2foam. The most related thread to my problem is this one i believe:
Can't compile on OpenFOAM v-1912
where the libgfortranfile.so wasn't located in /usr/lib. After creating a soft link of this file to /usr/lib the error persists.
There are some extra errors that appear around lines 600-700 in the log file compared to the log file of the above thread, and might be the cause of the problem but i have no clue how to solve them.
Also i have checked that i have the dependencies installed (gls, gfortran, svn, git), so this shouldn't be the cause.
Jim1310 is offline   Reply With Quote
Old   September 30, 2022, 06:59
Default Almost solved
Dimitris Tsoumpelis
I subsequently tried to reinstall the entire operating system (ubuntu 22.04 LTS) and tried again, but i got the exact same errors. I downgraded the ubuntu system to 20.04, installed the last compatible version of openfoam (v2106) and it looks like all the applications are compiled. All except postProcessWaves2Foam, which isn't in the /platforms /linux64GccDPInt32Opt /bin directory (where i guess it should be).
compile, error, help for a newbie, waves2foam
[waves2Foam] combined set of waves with waves2Foam blaise OpenFOAM Community Contributions 7 December 16, 2023 09:33
[waves2Foam] installing waves2foam into OpenFoam 6 madgeogr OpenFOAM Community Contributions 1 June 15, 2021 12:17
[waves2Foam] waves2Foam compatible with IHFoam [v. 2012] ngj OpenFOAM Community Contributions 4 April 24, 2021 08:43
[waves2Foam] Couple waves2foam with dynamic mesh vasava OpenFOAM Community Contributions 2 April 8, 2014 02:17
Segmentation fault running waveDyMFoam solver (mod. interDyMFoam solver - waves2Foam) Ed R OpenFOAM Running, Solving & CFD 5 July 2, 2013 12:36
