[OpenFOAM.com] Installing different copies of the same OF release - possible? |
September 11, 2022, 23:37 |
TWB
Rep Power: 19 |
I know it's possible to install OF 2006, 2112 on the same system. However, is it possible to install different copies of the same OF on the same system? So I would like to have: 1. OF 2206 using system C + MPI compiler 2. OF 2206 using self installed newer version of C + MPI compiler I tried once a while ago by using a different install dir but I can't remember the exact details. I think part of my earlier installation got overwrite. If anyone has experience, pls let me know if it's possible. Thanks. |
November 25, 2022, 23:10 |
TWB
Rep Power: 19 |
I have personally tested it and what I do is: 1. instead of /home/user/OpenFOAM/OpenFOAM-v2112, use /home/user/OpenFOAM_new/OpenFOAM-v2112 2. If you are compiling codes, it is better to edit the etc/bashrc: export WM_COMPILER=Gcc to export WM_COMPILER=Gcc_new This is because your new lib will then be in different dir: /home/user/OpenFOAM/tsltaywb-v2112/platforms/linux64GccDPInt32Opt/lib/ to /home/user/OpenFOAM/tsltaywb-v2112/platforms/linux64Gcc_newDPInt32Opt/lib/ So the libraries will not overwrite the different versions. Hope this helps. |
December 8, 2022, 11:08 |
#3 | |
Mark Olesen
Rep Power: 40 |
We do this all of the time. It is no problem, but you will want to adjust the compilation names to avoid overwriting the same locations. Here is my default setup (saved as etc/prefs.sh) Code:
# -*- sh -*- # Preferences for system clang-xxx, label-size=32 export WM_COMPILER_TYPE=system export WM_COMPILER=Clang140 export WM_COMPILE_CONTROL="version=14.0 +lld" export WM_LABEL_SIZE=32 ## Use system openmpi export WM_MPLIB=SYSTEMOPENMPI ## Use system openmpi4 # export WM_MPLIB=SYSTEMOPENMPI4 Code:
# -*- sh -*- # Preferences for system gcc, label-size=32 export WM_COMPILER_TYPE=system export WM_COMPILER=Gcc unset WM_COMPILE_CONTROL export WM_LABEL_SIZE=32 Code:
# -*- sh -*- # Preferences for third-party Gcc48, label-size=32 export WM_COMPILER_TYPE=ThirdParty # export WM_CONFIG=gcc48 export WM_COMPILER=Gcc48 export WM_LABEL_SIZE=32 unset WM_COMPILE_CONTROL Code:
source etc/bashrc gcc-system source etc/bashrc gcc48 In the regular prefs example, you will see there is a version number in the WM_COMPILE_CONTROL. This means it will compile with clang++-14.0 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
Heat Release vs. Apparent Heat Release // Comparison with GT Power | MFGT | CONVERGE | 10 | August 17, 2016 03:38 |
[foam-extend.org] Installing old release OpenFOAM 1.5-dev | Lorenzo92 | OpenFOAM Installation | 0 | May 26, 2016 13:15 |
Openfoam Ubuntu 12.04 Unmet dependencies | slls33 | OpenFOAM Installation | 10 | April 9, 2013 05:16 |
Installing 2.1.x (Repository Release) on RHEL 6.2 | socon009 | OpenFOAM Installation | 9 | May 19, 2012 12:38 |
