[OpenFOAM.com] How to install with zoltanRenumber
Old   August 10, 2022, 02:29
Default How to install with zoltanRenumber
Saang Bum Kim
sbkim is on a distinguished road
During the installation of OpenFOAM.com,
I found several errors on the 'log.linux64GccDPInt32Opt':
==> skip zoltanRenumber (no library)
==> skip ccmio (no header)
==> skip optional libccm adapter
==> skip optional ccm conversion components (no libccm)
==> Before running, verify that PETSc libraries can be found
but it set VTK_FOUND to FALSE so package "VTK" is considered to be NOT
FOUND. Reason given by package:
Could not find the VTK package with the following required components:
IOFFMPEG, ParallelMPI, PythonInterpreter, WrappingPythonCore.
After the installation, running a tutorial (multiphase/interFoam/RAS/DTCHull) was OK without error.
But paraFoam showed following error on the terminal .
Loguru caught a signal: SIGSEGV
Stack trace:
57 0x55666f8162a5 paraview(+0x92a5) [0x55666f8162a5]
56 0x7fcd5727fe40 __libc_start_main + 128
55 0x7fcd5727fd90 /lib/x86_64-linux-gnu/libc.so.6(+0x29d90) [0x7fcd5727fd90]
54 0x55666f8160a4 paraview(+0x90a4) [0x55666f8160a4]
53 0x7fcd55915ce4 QCoreApplication::exec() + 148
52 0x7fcd5590d74b QEventLoop::exec(QFlags<QEventLoop::ProcessEventsF lag>) + 299
51 0x7fcd559680a8 QEventDispatcherGlib:rocessEvents(QFlags<QEventL oop::ProcessEventsFlag>) + 104
50 0x7fcd5064d3c3 g_main_context_iteration + 51
49 0x7fcd506a46f8 /lib/x86_64-linux-gnu/libglib-2.0.so.0(+0xaa6f8) [0x7fcd506a46f8]
48 0x7fcd5064fd1b g_main_context_dispatch + 619
47 0x7fcd45b91d6e /lib/x86_64-linux-gnu/libQt5XcbQpa.so.5(+0x73d6e) [0x7fcd45b91d6e]
46 0x7fcd55ccaa2c QWindowSystemInterface::sendWindowSystemEvents(QFl ags<QEventLoop::ProcessEventsFlag>) + 172
45 0x7fcd55cf5307 QGuiApplicationPrivate:rocessMouseEvent(QWindowS ystemInterfacePrivate::MouseEvent*) + 1687
44 0x7fcd5590ee2a QCoreApplication::notifyInternal2(QObject*, QEvent*) + 314
43 0x7fcd569fd713 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 131
42 0x7fcd56a5cfd5 /lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x1cbfd5) [0x7fcd56a5cfd5]
41 0x7fcd56a59d40 /lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x1c8d40) [0x7fcd56a59d40]
40 0x7fcd56a03e47 QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) + 439
39 0x7fcd5590ee2a QCoreApplication::notifyInternal2(QObject*, QEvent*) + 314
38 0x7fcd56a05364 QApplication::notify(QObject*, QEvent*) + 2692
37 0x7fcd569fd713 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 131
36 0x7fcd56a404ee QWidget::event(QEvent*) + 526
35 0x7fcd56af51e7 QAbstractButton::mouseReleaseEvent(QMouseEvent*) + 247
34 0x7fcd56af4fc4 /lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x263fc4) [0x7fcd56af4fc4]
33 0x7fcd56af339e /lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x26239e) [0x7fcd56af339e]
32 0x7fcd56af3116 QAbstractButton::clicked(bool) + 70
31 0x7fcd559467b8 /lib/x86_64-linux-gnu/libQt5Core.so.5(+0x2f17b8) [0x7fcd559467b8]
30 0x7fcd566bb018 pqPropertiesPanel::apply() + 1080
29 0x7fcd565844a6 pqPropertiesPanel::applied(pqProxy*) + 70
28 0x7fcd559467b8 /lib/x86_64-linux-gnu/libQt5Core.so.5(+0x2f17b8) [0x7fcd559467b8]
27 0x7fcd5704b39e pqApplyBehavior::applied(pqPropertiesPanel*, pqProxy*) + 238
26 0x7fcd5704c57a pqApplyBehavior::showData(pqPipelineSource*, pqView*) + 426
25 0x7fcd52d48d56 vtkSMParaViewPipelineControllerWithRendering::Show InPreferredView(vtkSMSourceProxy*, int, vtkSMViewProxy*) + 166
24 0x7fcd52d46d53 vtkSMParaViewPipelineControllerWithRendering::Upda tePipelineBeforeDisplay(vtkSMSourceProxy*, int, vtkSMViewProxy*) + 243
23 0x7fcd554b857f vtkSMSourceProxy::UpdatePipeline(double) + 143
22 0x7fcd5543b15b vtkSMOutputPort::UpdatePipelineInternal(double, bool) + 203
21 0x7fcd5538b098 vtkPVSessionBase::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) + 56
20 0x7fcd5538d1bb vtkPVSessionCore::ExecuteStreamInternal(vtkClientS erverStream const&, bool) + 251
19 0x7fcd52b01f45 vtkClientServerInterpreter::ProcessStream(vtkClien tServerStream const&) + 37
18 0x7fcd52b01a7d vtkClientServerInterpreter::ProcessOneMessage(vtkC lientServerStream const&, int) + 237
17 0x7fcd52b0191d vtkClientServerInterpreter::ProcessCommandInvoke(v tkClientServerStream const&, int) + 1197
16 0x7fcd53477573 vtkSISourceProxyCommand(vtkClientServerInterpreter *, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&, void*) + 2067
15 0x7fcd553c4f12 vtkSISourceProxy::UpdatePipeline(int, double, bool) + 514
14 0x7fcd5103d547 vtkStreamingDemandDrivenPipeline::Update(int, vtkInformationVector*) + 279
13 0x7fcd5103c175 vtkStreamingDemandDrivenPipeline::ProcessRequest(v tkInformation*, vtkInformationVector**, vtkInformationVector*) + 885
12 0x7fcd50ff82b6 vtkDemandDrivenPipeline::ProcessRequest(vtkInforma tion*, vtkInformationVector**, vtkInformationVector*) + 310
11 0x7fcd50ff12cf vtkCompositeDataPipeline::ForwardUpstream(vtkInfor mation*) + 383
10 0x7fcd5103c175 vtkStreamingDemandDrivenPipeline::ProcessRequest(v tkInformation*, vtkInformationVector**, vtkInformationVector*) + 885
9 0x7fcd50ff86cf vtkDemandDrivenPipeline::ProcessRequest(vtkInforma tion*, vtkInformationVector**, vtkInformationVector*) + 1359
8 0x7fcd50ff2481 vtkCompositeDataPipeline::ExecuteData(vtkInformati on*, vtkInformationVector**, vtkInformationVector*) + 129
7 0x7fcd50ff595d vtkDemandDrivenPipeline::ExecuteData(vtkInformatio n*, vtkInformationVector**, vtkInformationVector*) + 61
6 0x7fcd50ffb954 vtkExecutive::CallAlgorithm(vtkInformation*, int, vtkInformationVector**, vtkInformationVector*) + 84
5 0x7fcd3c3e62a7 vtkPVFoamReader::RequestData(vtkInformation*, vtkInformationVector**, vtkInformationVector*) + 231
4 0x7fcd3c29167a Foam::vtkPVFoam::Update(vtkMultiBlockDataSet*, vtkMultiBlockDataSet*) + 3226
3 0x7fcd3c362d6c Foam::vtkPVFoam::convertMeshVolume() + 1276
2 0x7fcd3c367d3b Foam::vtk::vtuAdaptor::internal(Foam::fvMesh const&, bool) + 1851
1 0x7fcd54ddeaba vtkAOSDataArrayTemplate<float>::SetTuple(long long, double const*) + 122
0 0x7fcd57298520 /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x7fcd57298520]
( 4.123s) [paraview ] :0 FATL| Signal: SIGSEGV
Segmentation fault (core dumped)
What would be a reason for this error?
Please help me to solve the issue.
Thanks in advance.
sbkim is offline   Reply With Quote
[OpenFOAM.org] Install OpenFOAM without admin right OpenFoamlove OpenFOAM Installation 1 December 31, 2017 12:45
error make SU2 4.0.1 Heathckliff SU2 Installation 2 November 9, 2015 06:48
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 kobayashi OpenFOAM Community Contributions 2 January 5, 2014 18:33
unable to install openfoam 1.7 using apt-get maazhmd OpenFOAM Installation 7 July 24, 2011 12:18
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
