[OpenFOAM.com] 404 Errors when installing openFOAM2112
Old   June 14, 2022, 10:56
Default 404 Errors when installing openFOAM2112
Sigmar
RageDragon is on a distinguished road
I'm trying to install openFOAM 2112 by following the directions for Ubuntu on the wiki, but I am receiving several 404 file not found errors when I run sudo apt-get install openfoam2112. When I navigate to the URL given in the error the error is correct, part of the path 2112_220610 doesn't exist. Can someone help? Below is the error output.
Ign:1 https://dl.openfoam.com/repos/deb focal/main amd64 openfoam2112-common all 2112.220610-1
Err:2 https://dl.openfoam.com/repos/deb focal/main amd64 openfoam2112 amd64 2112.220610-1
  404  Not Found [IP: 82.71.205.33 443]
Err:3 https://dl.openfoam.com/repos/deb focal/main amd64 openfoam2112-tools amd64 2112.220610-1
Ign:4 https://dl.openfoam.com/repos/deb focal/main amd64 openfoam2112-source all 2112.220610-1
Err:5 https://dl.openfoam.com/repos/deb focal/main amd64 openfoam2112-dev amd64 2112.220610-1
Ign:6 https://dl.openfoam.com/repos/deb focal/main amd64 openfoam2112-tutorials all 2112.220610-1
Err:7 https://dl.openfoam.com/repos/deb focal/main amd64 openfoam2112-default amd64 2112.220610-1
Err:1 https://dl.openfoam.com/repos/deb focal/main amd64 openfoam2112-common all 2112.220610-1
Err:4 https://dl.openfoam.com/repos/deb focal/main amd64 openfoam2112-source all 2112.220610-1
Err:6 https://dl.openfoam.com/repos/deb focal/main amd64 openfoam2112-tutorials all 2112.220610-1
E:  Failed to fetch  https://dl.openfoam.com/repos/deb/dists/focal/main/pool/2112_220610/binary-all/openfoam2112-common_2112.220610-1_all.deb   404  Not Found [IP: 82.71.205.33 443]
E: Failed to fetch  https://dl.openfoam.com/repos/deb/dists/focal/main/pool/2112_220610/binary-amd64/openfoam2112_2112.220610-1_amd64.deb   404  Not Found [IP: 82.71.205.33 443]
E: Failed to fetch  https://dl.openfoam.com/repos/deb/dists/focal/main/pool/2112_220610/binary-amd64/openfoam2112-tools_2112.220610-1_amd64.deb   404  Not Found [IP: 82.71.205.33 443]
E: Failed to fetch  https://dl.openfoam.com/repos/deb/dists/focal/main/pool/2112_220610/binary-all/openfoam2112-source_2112.220610-1_all.deb   404  Not Found [IP: 82.71.205.33 443]
E: Failed to fetch  https://dl.openfoam.com/repos/deb/dists/focal/main/pool/2112_220610/binary-amd64/openfoam2112-dev_2112.220610-1_amd64.deb   404  Not Found [IP: 82.71.205.33 443]
E: Failed to fetch  https://dl.openfoam.com/repos/deb/dists/focal/main/pool/2112_220610/binary-all/openfoam2112-tutorials_2112.220610-1_all.deb   404  Not Found [IP: 82.71.205.33 443]
E: Failed to fetch  https://dl.openfoam.com/repos/deb/dists/focal/main/pool/2112_220610/binary-amd64/openfoam2112-default_2112.220610-1_amd64.deb   404  Not Found [IP: 82.71.205.33 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
RageDragon is offline   Reply With Quote
Old   June 15, 2022, 10:17
Sigmar
I ran it again this morning and it all appears to be working now. Whatever the issue was got fixed.
Old   June 15, 2022, 12:13
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
No idea what happened there - but thanks for getting back with an update.
olesen is offline   Reply With Quote
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 10:10
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
[OpenFOAM.org] Errors in installing OpenFOAM 2.2.2 on Ubuntu 18.04 LTS xixiuqi OpenFOAM Installation 3 December 12, 2019 11:03
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
