June 6, 2022, 05:45 |
Problem with scotch decompose
Nguyen Trong Hiep
Rep Power: 8 |
Im running OpenFOAM 2112 with wsl Ubuntu 20.04
When im trying to decompose with scotch method, terminal say scoth not installed. Code:
Calculating distribution of cells Decomposition method scotch [12] (region region0) --> FOAM FATAL ERROR: (openfoam-2112) Attempted to use <scotch> without the scotchDecomp library loaded. This message is from the dummy scotchDecomp stub library instead. Please install <scotch> and ensure libscotch.so is in LD_LIBRARY_PATH. The scotchDecomp library can then be built from src/parallel/decompose/scotchDecomp. Dynamically loading or linking this library will add <scotch> as a decomposition method. The LD_LIBRARY_PATH have libscotch.so Code:
echo $LD_LIBRARY_PATH /home/hiep/OpenFOAM/hiep-v2112/platforms/linux64GccDPInt32Opt/lib: /home/hiep/OpenFOAM-v2112/site/2112/platforms/linux64GccDPInt32Opt/lib: /home/hiep/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/sys-openmpi: /home/hiep/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib: /home/hiep/ThirdParty-v2112/platforms/linux64GccDPInt32/lib/sys-openmpi: /home/hiep/ThirdParty-v2112/platforms/linux64GccDPInt32/lib: /home/hiep/ThirdParty-v2112/platforms/linux64Gcc/fftw-3.3.10/lib: /home/hiep/ThirdParty-v2112/platforms/linux64Gcc/CGAL-4.14.3/lib64: /home/hiep/ThirdParty-v2112/platforms/linux64Gcc/boost_1_74_0/lib64: /usr/lib/x86_64-linux-gnu/openmpi/lib: /home/hiep/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/dummy: /usr/local/lib/ Code:
find -name libscotch.so ./home/hiep/ThirdParty-v2112/platforms/linux64GccDPInt32/lib/libscotch.so ./home/hiep/ThirdParty-v2112/platforms/linux64GccDPInt32/lib/sys-openmpi/libscotch.so |
overset decompose problem | daron | OpenFOAM Running, Solving & CFD | 1 | February 10, 2020 11:04 |
BuoyantBoussinesqSimpleFoam_Facing problem | Mondal131211 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2019 20:41 |
Problem with Scotch in 1.7.x? | dancfd | OpenFOAM Running, Solving & CFD | 0 | June 15, 2011 22:52 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
