[foam-extend.org] Installing swak4Foam on Foam-Extend-4.1
Old   May 20, 2022, 12:15
Default Installing swak4Foam on Foam-Extend-4.1
Mohammad Reza
Bana is on a distinguished road
Hello everyone,
I am facing problems installing swak4foam on foam-extend 4.1 which I can not identify the source of it.
The main error I think is this one:
PHP Code:
RawFoamDictionaryParserDriver.C:38:10fatal errorRawFoamDictionaryParser.tab.hhNo such file or directory
#include "RawFoamDictionaryParser.tab.hh"
compilation terminated
Why is this file not found and how can I resolve this issue?
There are also other errors like these:
PHP Code:
/RawFoamDictionaryParser.yy:455:21error‘FATALERROR’ is not a member of ‘Foam::token’
ExpressionResult
/ExpressionResult.CIn member function ‘void Foam::ExpressionResult::uglyDelete():
ExpressionResult/ExpressionResult.C:315:20warningdeleting ‘void*’ is undefined [-Wdelete-incomplete]
delete valPtr_
PHP Code:
make: *** [RawFoamDictionaryParser.dep:145Make/linux64GccDPInt32Opt/RawFoamDictionaryParser.oError 1
repositories
/MeshesRepository.CIn member function ‘Foam::scalar Foam::MeshesRepository::setTime(const Foam::word&, Foam::scalarFoam::label):
repositories/MeshesRepository.C:302:59errorno matching function for call to ‘Foam::HashTable<const Foam::regIOobject*>::HashTable(Foam::HashTable<Foam::regIOobject*>)
         regIOTable content
(mesh.lookupClass<regIOobject>());
PHP Code:
plugins/CommonPluginFunction.CIn member function ‘Foam::label Foam::IStringStreamWithPos::pos():
plugins/CommonPluginFunction.C:198:26error‘stream’ was not declared in this scope
return label(stream().tellg());
and etc.
I have tried downloading the package both using:
PHP Code:
git clone https://github.com/Unofficial-Extend-Project-Mirror/openfoam-extend-swak4Foam-dev.git
AND
PHP Code:
hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam swak4Foam
cd swak4Foam
./AllwmakeAll
I also have tried:
PHP Code:
./maintainanceScripts/compileRequirements.sh
and then Allwmake.
the result is:
PHP Code:
This script is rather crude. If it doesn't work try the steps by hand. And be sure to run it from the root of the swak-installation (as ./maintainanceScripts/compileRequirements.sh). Otherwise it probably won't work
Bison already installed
/compiled
Bison successfully compiled
Lua already installed
/compiled
Lua successfully compiled
Add
/Address/bin to PATH-variableThe ./Allwmake-script will use this directory automatically
If any one can have a suggestion or guidance on how to resolve the issue I will be very grateful.
Regards,
Mohammadreza
Bana is offline   Reply With Quote
Old   May 23, 2022, 05:40
Mohammad Reza
Any suggestion?
Old   September 22, 2022, 11:52
Mohammad Reza
This problem is solved.
For anyone who may encounter the same error:
This error is related to the python versions. try installing anaconda3.
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
[swak4Foam] Basic Error when installing swak4foam with foam extend 3.0 mnobrega OpenFOAM Community Contributions 6 April 1, 2014 02:47
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
