[OpenFOAM.com] ThirdParty-v2006 Error building gcc-4.8.5 with ./makeGcc Centos8
Old   May 10, 2022, 11:44
Default ThirdParty-v2006 Error building gcc-4.8.5 with ./makeGcc Centos8
Huw
Huwedwards is on a distinguished road
I am trying to install Openfoam-v2006 on my local machine which is running Centos8. I have been following the linked instructions (https://sourceexample.com/en/6fd29c0ca6c4680b69dd/) but when it comes to build GCC with the ./makeGcc command I get the following error:
make: *** [Makefile:886: all] Error 2
Error building: gcc-4.8.5
After much troubleshooting I haven't been able to find an explanation of what Error 2 refers to, or any others with the same issue. If anyone has experience with the same issue or could offer some guidance that would be much appreciated.
Thanks
Huwedwards is offline   Reply With Quote
Old   May 10, 2022, 12:09
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by Huwedwards View Post
Thanks
If you have centos-8 I really don't know why you would want to bother building a much, much older compiler from scratch. Simply doesn't make sense to me. If you want to use older/new compilers, by far the easiest is to install them from your system. If you need to reference different system compilers, use the WM_COMPILE_CONTROL (see etc/bashrc for comments) to pick the version. My current compilation setup:
# etc/prefs.sh
export WM_COMPILER_TYPE=system
export WM_COMPILER=Clang140
export WM_COMPILE_CONTROL="version=14.0 +lld"
On my system this equates to "/usr/bin/clang-14.0"
olesen is offline   Reply With Quote
Old   May 10, 2022, 12:30
Huw
Thank you for your reply. I am attempting to use the third party packages from ThirdParty-v2006 which as far as I'm aware requires WM_COMPILER_TYPE=ThirdParty in etc/bashrc. Is it possible to build the third party packages (e.g scotch) using a system-installed compiler? If so, how would I go about doing so.
Old   May 11, 2022, 06:56
Mark Olesen
Using the system compiler for other ThirdParty components is completely standard.
The main (only?) reason for making your own ThirdParty gcc etc would be if you have a really, really old operating system with an old compiler (eg, gcc-4.4) that does not support c++11. The only other reason (what I have) is on new system but need to check if the OpenFOAM code is still acceptable for old compilers.
Old   November 4, 2023, 08:41
Default Problem with too high gcc version
Yanjun Tong
Hughtong is on a distinguished road
There's another problem...If you got too high gcc version, up to gcc-11.*
When you using this compiler to compile OpenFOAM-2.3.x, got error:
warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
335 | register label i = min(this->size_, newSize);
Will this effect the compile process?
Hughtong is offline   Reply With Quote
[foam-extend.org] foam-extend-4.1 cannot compile on Centos8 Ya_Squall2010 OpenFOAM Installation 2 July 22, 2020 03:03
[foam-extend.org] foam-extend-4.0 gcc errors & maybe paraFoam powerline332 OpenFOAM Installation 3 May 24, 2018 22:16
OpenFOAM 1.6 ext fportela OpenFOAM Installation 11 December 26, 2013 19:55
Thirdparty mesquite-2.1.2 compile fix for newer gcc kmooney OpenFOAM Bugs 3 May 10, 2012 10:27
