[OpenFOAM.com] Native OpenFOAM for macOS: OpenFOAM-v2112.app (install instructions and GitHub link)
Like Tree12Likes
Old   May 3, 2023, 17:24
Akthem Rehab
Akthem is on a distinguished road
Hi Gerlero,
Apologies for the late reply. I tried to compile EOF-Library from within the openFOAM terminal and command not found this time:
openfoam2206:~/downloads/EOF-Library/
Akthem$ eofCompile
bash: eofCompile: command not found
Any other clues?
Akthem is offline   Reply With Quote
Old   May 4, 2023, 11:44
Gabriel Gerlero
gerlero is on a distinguished road
Not familiar at all with EOF-Library, but are you sourcing/activating that library's build tools too? (https://github.com/jvencels/EOF-Libr...l-installation)
gerlero is offline   Reply With Quote
Old   May 5, 2023, 13:51
Akthem Rehab
Well, I installed elmerFEM before installing openFOAM. Are you asking, whether I installed from within the openFOAM terminal (I did not)? Would this make a difference?
Old   May 6, 2023, 15:45
Gabriel Gerlero
I'm wondering whether you activated the EOF-Library (i.e., you ran the command ". EOF-Library/etc/bashrc", as appears in that link) before trying to run "eofCompile" and if that command ran successfully or if it gave you any errors.
Old   May 6, 2023, 16:32
Akthem Rehab
I did not run it before. I thought I had to add the following line in the .Zhsrc:
source /Users/Akthem/Downloads/EOF-Library/etc/bashrc
I ran the line now and then ran eofCompile. warnings and error are returned:
openfoam2206:~/Downloads/
Akthem$ eofCompile
wmake /Users/Akthem/Downloads/EOF-Library/etc/../libs/coupleElmer
/bin/sh: line 0: test: v2206: integer expression expected
************ OF version v2206 ************
ln: ./lnInclude
Making dependency list for source file Elmer.C
wmkdepend: could not open 'dynamicFvMesh.H' for source file 'Elmer.C': No such file or directory
clang++ -std=c++14 -m64 -pthread -ftrapping-math -DOPENFOAM=2206 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-undefined-var-template -Wno-unknown-warning-option -O3 -DNoRepository -ftemplate-depth-100 -I/Volumes/OpenFOAM-v2206/src/finiteVolume/lnInclude -I/Volumes/OpenFOAM-v2206/src/meshTools/lnInclude -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/opt/homebrew/Cellar/open-mpi/4.1.5/include -std=gnu++0x -DFOAM_MAJOR_VERSION=v2206 -Wno-old-style-cast -I/Volumes/OpenFOAM-v2206/src/Pstream/mpi/lnInclude -iquote. -IlnInclude -I/Volumes/OpenFOAM-v2206/src/OpenFOAM/lnInclude -I/Volumes/OpenFOAM-v2206/src/OSspecific/POSIX/lnInclude -fPIC -c Elmer.C -o Make/darwin64ClangDPInt32Opt/Elmer.o
Elmer.C:39:10: fatal error: 'dynamicFvMesh.H' file not found
#include "dynamicFvMesh.H"
1 error generated.
make: *** [Make/darwin64ClangDPInt32Opt/Elmer.o] Error 1
no elmerice
/opt/homebrew/bin/gfortran -o /Users/Akthem/Downloads/EOF-Library/etc/../libs/Elmer2OpenFOAM.so -J/Users/Akthem/Downloads/EOF-Library/etc/../libs /Users/Akthem/Downloads/EOF-Library/etc/../libs/Elmer2OpenFOAM.F90 -fallow-argument-mismatch -DCONTIG= -DHAVE_EXECUTECOMMANDLINE -DUSE_ISO_C_BINDINGS -DUSE_ARPACK -O2 -g -DNDEBUG -fPIC -dynamiclib -Wl,-headerpad_max_install_names -I/Users/Akthem/elmer/install//share/elmersolver/include -L/Users/Akthem/elmer/install//lib/elmersolver -shared -lelmersolver
/Users/Akthem/Downloads/EOF-Library/etc/../libs/Elmer2OpenFOAM.F90:217:19:
109 | CALL MPI_Bcast(OF_EL_overlap(:,:,s), totOFRanks*totLocalRanks, MPI_INTEGER, 0, ELMER_COMM_WORLD, ierr)
| 2
217 | CALL MPI_BCAST(ElmerRanksStart, 1, MPI_INTEGER, 0, ELMER_COMM_WORLD, ierr)
| 1
Warning: Rank mismatch between actual argument at (1) and actual argument at (2 (rank-1 and scalar)
/Users/Akthem/Downloads/EOF-Library/etc/../libs/Elmer2OpenFOAM.F90:275:23:
253 | CALL MPI_IRECV(OFp(i,s) % OFMesh % NumberOfNodes, 1, MPI_INTEGER, &
| 2
275 | CALL MPI_IRECV(OFp(i,s) % OFMesh % Nodes % x, OFp(i,s) % OFMesh % NumberOfNodes, MPI_DOUBLE, &
| 1
Warning: Type mismatch between actual argument at (1) and actual argument at (2 (REAL(8)/INTEGER(4)).
/Users/Akthem/Downloads/EOF-Library/etc/../libs/Elmer2OpenFOAM.F90:328:24:
310 | CALL MPI_ISEND( OFp(i,s) % nFoundCells, 1, MPI_INTEGER, &
| 2
328 | CALL MPI_ISEND( OFp(i,s) % foundCellsIndx, OFp(i,s) % nFoundCells, MPI_INTEGER, &
| 1
Warning: Rank mismatch between actual argument at (1) and actual argument at (2 (scalar and rank-1)
/Users/Akthem/Downloads/EOF-Library/etc/../libs/Elmer2OpenFOAM.F90:365:24:
| 2
365 | CALL MPI_ISEND( OFp(i,s) % OFVar % Values, OFp(i,s) % nFoundCells, MPI_DOUBLE, &
| 1
Undefined symbols for architecture arm64:
"_mpi_allgather_", referenced from:
_findoverlappingboxes_ in cc5CFyhc.o
"_mpi_bcast_", referenced from:
_elmer2openfoamsolver_ in cc5CFyhc.o
"_mpi_comm_rank_", referenced from:
"_mpi_comm_size_", referenced from:
"_mpi_irecv_", referenced from:
"_mpi_isend_", referenced from:
"_mpi_recv_", referenced from:
"_mpi_request_free_", referenced from:
"_mpi_send_", referenced from:
"_mpi_test_", referenced from:
_mpi_test_sleep_ in cc5CFyhc.o
(maybe you meant: _mpi_test_sleep_)
"_mpi_wtime_", referenced from:
ld: symbol(s) not found for architecture arm64
collect2: error: ld returned 1 exit status
no elmerice
/opt/homebrew/bin/gfortran -o /Users/Akthem/Downloads/EOF-Library/etc/../libs/OpenFOAM2Elmer.so -J/Users/Akthem/Downloads/EOF-Library/etc/../libs /Users/Akthem/Downloads/EOF-Library/etc/../libs/OpenFOAM2Elmer.F90 -fallow-argument-mismatch -DCONTIG= -DHAVE_EXECUTECOMMANDLINE -DUSE_ISO_C_BINDINGS -DUSE_ARPACK -O2 -g -DNDEBUG -fPIC -dynamiclib -Wl,-headerpad_max_install_names -I/Users/Akthem/elmer/install//share/elmersolver/include -L/Users/Akthem/elmer/install//lib/elmersolver -shared -lelmersolver
/Users/Akthem/Downloads/EOF-Library/etc/../libs/OpenFOAM2Elmer.F90:237:19:
120 | CALL MPI_Bcast(OF_EL_overlap(:,:,s), totOFRanks*totLocalRanks, MPI_INTEGER, 0, ELMER_COMM_WORLD, ierr)
| 2
237 | CALL MPI_BCAST(ElmerRanksStart, 1, MPI_INTEGER, 0, ELMER_COMM_WORLD, ierr)
| 1
/Users/Akthem/Downloads/EOF-Library/etc/../libs/OpenFOAM2Elmer.F90:379:23:
369 | CALL MPI_ISEND(nElements, 1, MPI_INTEGER, &
| 2
379 | CALL MPI_ISEND(commElementX, nElements, MPI_DOUBLE, &
| 1
/Users/Akthem/Downloads/EOF-Library/etc/../libs/OpenFOAM2Elmer.F90:411:23:
395 | CALL MPI_IRECV(OFp(i,s) % nFoundElements, 1, MPI_INTEGER, &
| 2
411 | CALL MPI_IRECV(OFp(i,s) % foundElementIndx, OFp(i,s) % nFoundElements, MPI_INTEGER, &
| 1
/Users/Akthem/Downloads/EOF-Library/etc/../libs/OpenFOAM2Elmer.F90:449:24:
| 2
449 | CALL MPI_IRECV( OFp(i,s) % recvValues, OFp(i,s) % nFoundElements, MPI_DOUBLE, &
| 1
_findoverlappingboxes_ in cc4kliHf.o
_openfoam2elmersolver_ in cc4kliHf.o
_mpi_test_sleep_ in cc4kliHf.o
Old   May 6, 2023, 16:39
Gabriel Gerlero
Is EOF-Library compatible with the OpenFOAM distribution from OpenCFD (i.e., from openfoam.com)?
These lines look like it's failing to parse OpenFOAM's version string. Could it be that this library requires a Foundation (openfoam.org) OpenFOAM distribution (e.g. OpenFOAM 9)? In that case, you might have to resort to Docker, as versions from that distribution can't be run natively on macOS.
Old   May 6, 2023, 17:18
Akthem Rehab
That could be very well the case. I already have EOF-Library together with openFOAM and elmerFEM dockerized on mac as per https://github.com/jvencels/EOF-Library#how-to.
I was hoping I can install it without docker as I already built an environment on my macos that includes freeCAD, gmsh, openFoam, elmerFEM, and paraview. Only missing component is EOF-Library and a multi-body dynamics tool.
I guess your answer concludes this attempt as not possible at the moment. Alternative would be to include all the above software in the EOF-Library docker image! Have to shift my focus to that I guess.
Thank you, gerlero!
gerlero likes this.
Old   July 2, 2023, 23:18
Arrow OpenFOAM-v2306.app
  #28
Gabriel Gerlero
OpenFOAM v2306 builds are now available.
Visit the repo for details.
dlahaye and Akthem like this.
Old   July 8, 2023, 05:50
Miguel Hernandez
Miguel Hernandez is on a distinguished road
Thank you for your work!
gerlero likes this.
Miguel Hernandez is offline   Reply With Quote
Old   June 26, 2024, 21:05
Post OpenFOAM v2406 now available
  #30
Gabriel Gerlero
OpenFOAM v2406 is now available via OpenFOAM.app.
dlahaye likes this.
Old   November 19, 2024, 05:19
Default Custom Solver Installation
  #31
Emil Mammadli
pncln is on a distinguished road
I am really struggling with custom solver compilation. Are there any guides available specifically for this installation? I do not understand the structure of openfoam files with this native app.
Thanks in advance.
pncln is offline   Reply With Quote
Old   November 20, 2024, 19:30
Gabriel Gerlero
Thanks in advance.
What kind of problem are you having?
There's no such guide specifically for OpenFOAM.app since the process of compiling a third-party solver should be the same as with OpenFOAM on Linux.
Old   November 21, 2024, 03:20
Emil Mammadli
It is, indeed, the same process. The solver I was trying to install was faulty. Thanks!
apple, mac, mac os, mac os x
