[OpenFOAM.com] OpenFOAM 4.1 with GCC-8.3.0
Old   May 5, 2022, 17:34
Default OpenFOAM 4.1 with GCC-8.3.0
Salar
salar is on a distinguished road
Hi everyone,
I need to install OpenFOAM 4.1 with GCC-8.3.0 in our cluster (Centos 7). I made some modification as mentioned in:
https://github.com/OpenFOAM/OpenFOAM...80f406a23d3004
Everything works fine but when It wmake the solvers it shows the following linkage error:
/scratch/user/A/OpenFOAM/OpenFOAM-4.1/applications/solvers/basic/laplacianFoam
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/user/A/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude -I/scratch/user/A/OpenFOAM/OpenFOAM-4.1/src/meshTools/lnInclude -IlnInclude -I. -I/scratch/user/A/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude -I/scratch/user/A/OpenFOAM/OpenFOAM-4.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --no-as-needed /scratch/user/A/OpenFOAM/OpenFOAM-4.1/platforms/linux64Gcc83DPInt32Opt/applications/solvers/basic/laplacianFoam/laplacianFoam.o -L/scratch/user/A/OpenFOAM/OpenFOAM-4.1/platforms/linux64Gcc83DPInt32Opt/lib \
-lfiniteVolume -lmeshTools -lOpenFOAM -ldl \
-lm -o /scratch/user/A/OpenFOAM/OpenFOAM-4.1/platforms/linux64Gcc83DPInt32Opt/bin/laplacianFoam
/scratch/user/A/OpenFOAM/OpenFOAM-4.1/platforms/linux64Gcc83DPInt32Opt/applications/solvers/basic/laplacianFoam/laplacianFoam.o:laplacianFoam.C:function Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::evaluate(): error: undefined reference to 'Foam::UPstream::nRequests()'
/scratch/user/A/OpenFOAM/OpenFOAM-4.1/platforms/linux64Gcc83DPInt32Opt/applications/solvers/basic/laplacianFoam/laplacianFoam.o:laplacianFoam.C:function Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::evaluate(): error: undefined reference to 'Foam::UPstream::waitRequests(int)'
/scratch/user/A/OpenFOAM/OpenFOAM-4.1/platforms/linux64Gcc83DPInt32Opt/applications/solvers/basic/laplacianFoam/laplacianFoam.o:laplacianFoam.C:function void Foam::mapDistributeBase::distribute<double, Foam::noOp>(Foam::UPstream::commsTypes, Foam::List<Foam::Pair<int> > const&, int, Foam::List<Foam::List<int> > const&, bool, Foam::List<Foam::List<int> > const&, bool, Foam::List<double>&, Foam::noOp const&, int): error: undefined reference to 'Foam::UPstream::nRequests()'
Thank you for your comments on this error.
Best,
Salar
salar is offline   Reply With Quote
[OpenFOAM.com] Can gcc changed with source ing different openfoam version etc/bashrc caoxuxiang OpenFOAM Installation 2 December 16, 2021 03:41
OpenFoam in docker (gcc 6) vs. OpenFoam natively compiled (gcc 8.1.1) Anouk OpenFOAM Running, Solving & CFD 0 September 17, 2018 09:02
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
OpenFOAM 4.1 packaged for GNU Guix pg22 OpenFOAM Announcements from Other Sources 0 October 5, 2017 08:57
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
