[OpenFOAM.com] Getting different error results on cluster, compared to workstation
Old   April 6, 2022, 06:24
Default Getting different error results on cluster, compared to workstation
TWB
quarkz is on a distinguished road
I'm running a simulation involving 3D 6DOF.
I tested the simulation on my workstation and it worked fine.
I then tranferred the same case to my cluster to run.
However, I found that my cluster's results is different and it suddenly gives very large forces when I activated my custom BC which changes the inlet velocity.
My workstation, and another cluster gave the same and correct results.
I compiled and tried the v2106 and 2212 but both gave the incorrect result. The OF is compiled using sys gcc v8.3.0 and openmpi3.
So why is this happening? Must I recompile using diff gcc or openmpi?
Thanks in advance.
quarkz is offline   Reply With Quote
Looking for a new workstation or small cluster, max 12k€ chriss85 Hardware 3 June 19, 2018 11:20
Replacing cluster server with a workstation KalleT Hardware 7 September 5, 2017 02:24
32 CPUs Workstation V.S. Cluster for Fluent Anna Tian FLUENT 40 July 17, 2014 01:10
Cluster v.s. very large workstation Anna Tian Hardware 3 February 16, 2014 19:50
Dual cpu workstation VS 2 node cluster single cpu workstation Verdi Hardware 18 September 2, 2013 04:09
