[foam-extend.org] Problem installing third party codes with foam extend 4.1
Old   March 12, 2022, 09:41
Default Problem installing third party codes with foam extend 4.1
TWB
quarkz is on a distinguished road
I'm trying to install foam extend 4.1 nextRelease branch. However, I've similar problem with the org 4.1 too.
Some third party codes can't be installed. These include:
metis
scotch
parmetis
Mesquite
So I downloaded the third party codes and install myself. Installation was successful. However, when I run Allwmake.firstInstall, it complains that the include file is not found:
-extend-4.1_NR_updated/src/foam/lnInclude -I/home/users/nus/tsltaywb/woodstock/foam/foam-extend-4.1_NR_updated/src/OSspecific/POSIX/lnInclude   -fPIC -fuse-ld=bfd -c $SOURCE -o Make/linux64GccDPInt32Opt/metisDecomp.o
metisDecomp.C:34:22: fatal error: metis.h: No such file or directory
 #   include "metis.h"
It's the same for parmetis, scotch. For Mesquite, it complains:
/home/users/nus/tsltaywb/woodstock/lib/mesquite-2.3.0//lib/libmesquite.a: error adding symbols: Bad value
collect2: error: ld returned 1 exit status
However, I have already specified them in prefs.sh, such as:
# System installed Metis
export METIS_SYSTEM=1
export METIS_DIR=/home/users/nus/tsltaywb/woodstock/lib/metis-5.1.0
export METIS_BIN_DIR=$METIS_DIR/bin
export METIS_LIB_DIR=$METIS_DIR/lib
export METIS_INCLUDE_DIR=$METIS_DIR/include
May I know what's wrong? Btw, I'm using gcc 4.9.3 + openmpi 1.10.2.
quarkz is offline   Reply With Quote
Old   November 15, 2023, 18:02
Shenhui Ruan
fly_light is on a distinguished road
have you found the solution to the problem?
I have the same issue and I don't know how to solve it.
Please tell me if you found it.
best regards.
fly_light is offline   Reply With Quote
Old   December 15, 2023, 13:34
Default OpenFOAM Installation
ishaydjo
dhaysux is on a distinguished road
Hi, Thank you very much for the tutorial! btw, if i uncheck the virtual machine platform feature on 'turn windows features on or off' can I still operate openfoam & paraview normally? thanks in anticipation.
192.168.100.1 192.168.1.1
dhaysux is offline   Reply With Quote
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 23:07
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
problem about installing FOAM linux freshman Main CFD Forum 6 November 4, 2004 11:59
