[OpenFOAM.com] Installing superThermo with Allwmake command
Old   January 28, 2022, 06:32
Question Installing superThermo with Allwmake command
Afonso
Dekkers is on a distinguished road
Hello! I am trying to install some libraries from the superThermo project (https://github.com/arattner1/superThermo) using the ./Allwmake command and it is not working.
My OpenFOAM version is v2112 and this project was desgined with v1612, is this the problem?
Unfortunately the error is too long to post here, so I am adding only the last part, with the beginning of the error as a screenshot attached.
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/rhoThermo.H:89:5:   required from ‘Foam::rhoThermo::addfvMeshConstructorToTable<rhoThermoType>::addfvMeshConstructorToTable(const Foam::word&) [with rhoThermoType = Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::icoPolynomial<Foam::specie> >, Foam::sensibleEnthalpy> > > >]’
superThermos.C:136:1:   required from here
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/specie/lnInclude/thermoI.H:369:9: error: ‘Hs’ is not a member of ‘Foam::species::thermo<Foam::superH<Foam::icoPolynomial<Foam::specie> >, Foam::sensibleEnthalpy>’
  369 |         &thermo<Thermo, Type>::Hs,
In file included from /usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.H:354,
                 from /usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heRhoThermo.H:42,
                 from superThermos.C:46:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C: In instantiation of ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::heThermo<BasicThermo, MixtureType>::hc() const [with BasicThermo = Foam::rhoThermo; MixtureType = Foam::pureMixture<Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::icoPolynomial<Foam::specie> >, Foam::sensibleEnthalpy> > >]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:312:1:   required from here
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:339:51: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::icoPolynomial<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Hc’; did you mean ‘HE’?
  339 |         hcCells[celli] = this->cellMixture(celli).Hc();
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:350:64: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::icoPolynomial<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Hc’; did you mean ‘HE’?
  350 |             hcp[facei] = this->patchFaceMixture(patchi, facei).Hc();
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C: In instantiation of ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::heThermo<BasicThermo, MixtureType>::hc() const [with BasicThermo = Foam::psiThermo; MixtureType = Foam::pureMixture<Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGas<Foam::specie> >, Foam::sensibleEnthalpy> > >]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:339:51: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGas<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Hc’; did you mean ‘HE’?
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:350:64: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGas<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Hc’; did you mean ‘HE’?
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C: In instantiation of ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::heThermo<BasicThermo, MixtureType>::hc() const [with BasicThermo = Foam::rhoThermo; MixtureType = Foam::pureMixture<Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> > >]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:339:51: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Hc’; did you mean ‘HE’?
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:350:64: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Hc’; did you mean ‘HE’?
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C: In instantiation of ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::heThermo<BasicThermo, MixtureType>::Cp() const [with BasicThermo = Foam::rhoThermo; MixtureType = Foam::pureMixture<Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> > >]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:403:1:   required from here
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:430:38: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Cp’; did you mean ‘Cpv’?
  430 |             this->cellMixture(celli).Cp(this->p_[celli], this->T_[celli]);
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:444:55: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Cp’; did you mean ‘Cpv’?
  444 |                 this->patchFaceMixture(patchi, facei).Cp(pp[facei], pT[facei]);
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C: In instantiation of ‘Foam::tmp<Foam::Field<double> > Foam::heThermo<BasicThermo, MixtureType>::Cp(const scalarField&, const scalarField&, Foam::label) const [with BasicThermo = Foam::rhoThermo; MixtureType = Foam::pureMixture<Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> > >; Foam::scalarField = Foam::Field<double>; Foam::label = int]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:359:30:   required from here
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:372:51: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Cp’; did you mean ‘Cpv’?
  372 |             this->patchFaceMixture(patchi, facei).Cp(p[facei], T[facei]);
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C: In instantiation of ‘Foam::tmp<Foam::Field<double> > Foam::heThermo<BasicThermo, MixtureType>::Cp(const scalarField&, const scalarField&, const labelList&) const [with BasicThermo = Foam::rhoThermo; MixtureType = Foam::pureMixture<Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> > >; Foam::scalarField = Foam::Field<double>; Foam::labelList = Foam::List<int>]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:381:1:   required from here
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:394:42: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Cp’; did you mean ‘Cpv’?
  394 |         Cp[i] = this->cellMixture(celli).Cp(p[i], T[i]);
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C: In instantiation of ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::heThermo<BasicThermo, MixtureType>::Cv() const [with BasicThermo = Foam::rhoThermo; MixtureType = Foam::pureMixture<Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> > >]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:498:1:   required from here
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:525:38: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Cv’; did you mean ‘Cpv’?
  525 |             this->cellMixture(celli).Cv(this->p_[celli], this->T_[celli]);
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C: In instantiation of ‘Foam::tmp<Foam::Field<double> > Foam::heThermo<BasicThermo, MixtureType>::Cv(const scalarField&, const scalarField&, Foam::label) const [with BasicThermo = Foam::rhoThermo; MixtureType = Foam::pureMixture<Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> > >; Foam::scalarField = Foam::Field<double>; Foam::label = int]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:454:1:   required from here
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:467:51: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Cv’; did you mean ‘Cpv’?
  467 |             this->patchFaceMixture(patchi, facei).Cv(p[facei], T[facei]);
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C: In instantiation of ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::heThermo<BasicThermo, MixtureType>::hc() const [with BasicThermo = Foam::rhoThermo; MixtureType = Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGas<Foam::specie> >, Foam::sensibleEnthalpy> > >]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:339:51: error: ‘const class Foam::sutherlandTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGas<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Hc’; did you mean ‘HE’?
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:350:64: error: ‘const class Foam::sutherlandTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGas<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Hc’; did you mean ‘HE’?
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C: In instantiation of ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::heThermo<BasicThermo, MixtureType>::hc() const [with BasicThermo = Foam::rhoThermo; MixtureType = Foam::pureMixture<Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGas<Foam::specie> >, Foam::sensibleEnthalpy> > >]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C: In instantiation of ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::heThermo<BasicThermo, MixtureType>::hc() const [with BasicThermo = Foam::rhoThermo; MixtureType = Foam::pureMixture<Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > >]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:339:51: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Hc’; did you mean ‘HE’?
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:350:64: error: ‘const class Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Hc’; did you mean ‘HE’?
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C: In instantiation of ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::heThermo<BasicThermo, MixtureType>::hc() const [with BasicThermo = Foam::rhoThermo; MixtureType = Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGas<Foam::specie> >, Foam::sensibleEnthalpy> > >]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:339:51: error: ‘const class Foam::constTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGas<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Hc’; did you mean ‘HE’?
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:350:64: error: ‘const class Foam::constTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGas<Foam::specie> >, Foam::sensibleEnthalpy> >’ has no member named ‘Hc’; did you mean ‘HE’?
In file included from /usr/lib/openfoam/openfoam2112/src/thermophysicalModels/specie/lnInclude/thermo.H:384,
                 from superThermos.C:34:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/specie/lnInclude/thermoI.H: In instantiation of ‘Foam::scalar Foam::species::thermo<Thermo, Type>::gamma(Foam::scalar, Foam::scalar) const [with Thermo = Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:593:22:   required from ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::heThermo<BasicThermo, MixtureType>::gamma() const [with BasicThermo = Foam::rhoThermo; MixtureType = Foam::pureMixture<Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> > >]’
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:567:1:   required from here
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/specie/lnInclude/thermoI.H:130:29: error: ‘const class Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy>’ has no member named ‘Cp’; did you mean ‘Cpv’?
  130 |     const scalar Cp = this->Cp(p, T);
      |                       Cpv
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/specie/lnInclude/thermoI.H:133:27: error: ‘const class Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy>’ has no member named ‘CpMCv’; did you mean ‘Cpv’?
  133 |     return Cp/(Cp - this->CpMCv(p, T));
      |                     Cpv
In file included from superThermos.C:33:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/specie/lnInclude/sensibleEnthalpy.H: In instantiation of ‘Foam::scalar Foam::sensibleEnthalpy<Thermo>::Cpv(const Thermo&, Foam::scalar, Foam::scalar) const [with Thermo = Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy>; Foam::scalar = double]’:
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/specie/lnInclude/thermoI.H:119:43:   required from ‘Foam::scalar Foam::species::thermo<Thermo, Type>::Cpv(Foam::scalar, Foam::scalar) const [with Thermo = Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double]’
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:668:20:   required from ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::heThermo<BasicThermo, MixtureType>::Cpv() const [with BasicThermo = Foam::rhoThermo; MixtureType = Foam::pureMixture<Foam::superTransport<Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy> > >]’
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/basic/lnInclude/heThermo.C:642:1:   required from here
/usr/lib/openfoam/openfoam2112/src/thermophysicalModels/specie/lnInclude/sensibleEnthalpy.H:91:31: error: ‘const class Foam::species::thermo<Foam::superH<Foam::PengRobinsonGasPConst<Foam::specie> >, Foam::sensibleEnthalpy>’ has no member named ‘Cp’; did you mean ‘Cpv’?
   91 |                 return thermo.Cp(p, T);
      |                        Cpv
make: *** [/usr/lib/openfoam/openfoam2112/wmake/rules/General/transform:35: Make/linux64GccDPInt32Opt/./superThermos.o] Error 1
The folder that I am trying to install is in this link: https://github.com/arattner1/superTh...hermo1612Final
Dekkers is offline   Reply With Quote
supercritical co2, superthermo
Two phase flow in porous medium Milaad OpenFOAM 7 July 1, 2024 06:08
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[OpenFOAM.org] -bash: fluentMeshToFoam: command not found, after installing OpenFoam 2.3.x on Mac jundong OpenFOAM Installation 1 July 1, 2015 14:31
Installing OpenFOAM 1.7.x on CAElinux without Internet Connection joel.lehikoinen OpenFOAM Installation 3 June 14, 2011 12:09
Installing OpenFOAM on SuSE Linux 91 Lars Edvardsen (Edvardsen) OpenFOAM Installation 2 January 10, 2005 03:26
