[OpenFOAM.com] Install a new docker version of OpenFoam |
November 23, 2021, 12:01 |
Lei Dai
Rep Power: 6 |
I am currently using OpenFoam 8 docker version in a Manjaro system (Linux). I would like to install a new version, OpenFoam 9 docker version. How could I install 2 docker versions in the same PC? Do I need a new docker or just add a docker image? |
November 23, 2021, 12:09 |
#2 | |
Mark Olesen
Rep Power: 40 |
You will have one version of docker itself, but there is no particular limit on how many docker images you can use. The next part will depend on how you are actually starting the images. In the openfoam.com version there is a https://develop.openfoam.com/packagi...penfoam-docker wrapper script. With that one, you could simply specify "openfoam-docker -2012" or "openfoam-docker -2106" to use different versions. |
November 23, 2021, 12:14 |
#3 | |
Lei Dai
Rep Power: 6 |
Hi, Thank you a lot for your reply. So what I need to do is to add a docker image and install the new version (Openfoam 9) to that image. I can enter into different version of OpenFoam by different commands. Do I understand correctly? Kind Regards, Lei |
November 24, 2021, 04:34 |
#4 | |
Mark Olesen
Rep Power: 40 |
I'm sorry but I don't use or endorse the "openfoam.org" variant - also for reasons mentioned in my blog post: https://olesenm.github.io/2020/11/11...de-provenance/ The openfoam-docker command I mentioned is for the "openfoam.com" variant, with that one you simply specify the version and it will pull it (if available). |
November 24, 2021, 09:29 |
#5 | |
Lei Dai
Rep Power: 6 |
Thank you for your kindly reply. I have sorted out this problem. Cheers! |
docker, multiple version, openfoam 9 |
different results form openfoam 3.0.1 to 1912 | yuno | OpenFOAM Running, Solving & CFD | 0 | September 28, 2020 04:09 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
OpenFOAM-1.6 install cookbook | MadsR | OpenFOAM Installation | 372 | November 20, 2010 12:57 |
OpenFOAM 15 on AIX system does not support this version | besto | OpenFOAM Installation | 3 | October 29, 2008 05:23 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
