[OpenFOAM.com] Parallel mpirun doesn't work (perhaps because of clashes with intel compiler)
Old   October 8, 2021, 09:49
Exclamation Parallel mpirun doesn't work (perhaps because of clashes with intel compiler)
Tom Waits
TomWaits is on a distinguished road
Hi All,
I have compiled OpenFOAMv2006 on a Centos 8 machine and OpenFOAM errors on parallel runs. I think this is because I have an Intel fortran compiler installed which is clashing with openfoam as parallel simulations were working before. I have attempted a re-compile with the same error.
The error I get (on each processor) is (from any parallel run, for eg. the simpleFoam motorbike tutorial):
mca_base_component_repository_open: unable to open mca_btl_usnic: /opt/intel/compilers_and_libraries_2019.1.144/linux/mpi/intel64/libfabric/lib/libfabric.so.1: version `FABRIC_1.3' not found (required by /usr/lib64/openmpi/lib/openmpi/mca_btl_usnic.so) (ignored)
And then (again on each processor):
--> FOAM FATAL ERROR:
attempt to run parallel on 1 processor
       From static bool Foam::UPstream::init(int&, char**&, bool)
       in file UPstream.C at line 259.
FOAM aborting
and
 *** Process received signal ***
Signal: Aborted (6)
Signal code:  (-6)
 [ 0] /lib64/libpthread.so.0(+0x12b20)[0x7f0761e11b20]
[ 1] /lib64/libc.so.6(gsignal+0x10f)[0x7f0761a7137f]
[ 2] /lib64/libc.so.6(abort+0x127)[0x7f0761a5bdb5]
[ 3] /home/user/openfoam2/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam5error11exitOrAbortEib+0x252)[0x7f0762ed2052]
[ 4] /home/user/openfoam2/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPcb+0x3d9)[0x7f07618306b9]
[ 5]  at ??:?
Signal: Aborted (6)
Signal code:  (-6)
 at ??:?
Any help or direction would be much appreciated.
Many thanks in advance,
Tom Waits.
TomWaits is offline   Reply With Quote
Old   October 8, 2021, 22:31
Tom Waits
For anyone that has this (or similar) error - after a lot of bashing my head against the keyboard I have managed to get Openfoam re-compiled using the intel compiler/mpi (instead of the default OpenMPI) so that there are no clashes on my system. This has solved the problem.
Old   October 9, 2021, 04:38
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
For what it's worth, you can normally just change the mpi bits independently. Eg, assuming you compiled initially with system gcc and OpenMPI. If you change your prefs to specify IntelMPI and run the compilation again, you will see that it only rebuilds the Pstream library and the ptscotch interface. Takes less than a few minutes. You will still need to be careful to set the proper env variables so that the intel-mpi knows to use gcc instead of icc, but that is fairly standard.
To make things a bit easier we have Allwmake-mpi scrips in the relevant places so you can just run those directly.
olesen is offline   Reply With Quote
installation of openfoam, mpi, parallel
[ANSYS Meshing] Cant get parallel meshing to work in V18.2 jones007 ANSYS Meshing & Geometry 17 November 9, 2020 06:56
[OpenFOAM.com] Issue configuring ./makeParaView - Ubuntu 16.04 bjdarrer OpenFOAM Installation 2 April 20, 2020 14:50
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Intel Fortran debugger with mpirun agg Main CFD Forum 2 March 21, 2007 18:43
AMD X2 & INTEL core 2 are compatible for parallel? nikolas FLUENT 0 October 5, 2006 07:49
