[OpenFOAM.com] Error when trying blockmesh on "flow around a cylinder"
Old   September 6, 2021, 08:06
Default Error when trying blockmesh on "flow around a cylinder"
Carlos Dos Santos
DonCarlos030 is on a distinguished road
Hello everyone,
Thank you in advance for reading my question and hopefully anyone can help me further.
So I installed openfoam on my windows computer (first using docker but then I uninstalled that to install it using Windows Subsystem for Linux (with ubuntu)). And this all works quite well for the cavity case (also paraview etc.) but then we I try to do the second tutorial, the flow around a cylinder, I get the following error and I do not have a clue how to solve this.
Can anyone help me with this? Thank you in advance.
screenshot to the error: https://imgur.com/a/1vmV15t
Logfile from blockMesh:
| \\ / O peration | Version: v2012 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _7bdb509494-20201222 OPENFOAM=2012
Arch : "LSB;label=32;scalar=64"
Exec : blockMesh
Date : Sep 06 2021
Time : 13:05:52
Host : Asus
PID : 11194
I/O : uncollated
Case : /mnt/c/Users/gebruiker/cylinder
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Creating block mesh from "system/blockMeshDict"
Using #codeStream at line 23 in file "/mnt/c/Users/gebruiker/cylinder/system/blockMeshDict"
Using #codeStream with "/mnt/c/Users/gebruiker/cylinder/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_49e41d753f2adb4c8dffc0259424b06af57d b063.so"
Invoking wmake libso /mnt/c/Users/gebruiker/cylinder/dynamicCode/_49e41d753f2adb4c8dffc0259424b06af57db063
DonCarlos030 is offline   Reply With Quote
Old   September 7, 2021, 12:36
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
This should have been solved in the debian pack (I thought). I assume that you have installed the openfoam2106-dev package?
In worst case, can install make, gcc manually as well. Not exactly elegant but should get you going.
BTW: in general it is better/faster/easier to use the #eval directive instead of #calc.
olesen is offline   Reply With Quote
[blockMesh] OpenFOAM blockMesh bus error BRH OpenFOAM Meshing & Mesh Conversion 0 April 12, 2021 12:02
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 09:37
Boundary condition "flow over a cylinder" ronaldo OpenFOAM 1 February 8, 2011 06:11
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 12:59
