September 5, 2021, 13:42 |
Quick tip
CFD_Lovers
Rep Power: 11 |
Just wanted to make a very subtle tip for those want to install OF8 on Win 10: Do not upgrade you WSL to WSL2 and proceed with the WSL1 for ubuntu 18.0.1 or ubuntu 20 LTS. Using WSL2, OF just works fine, but you can't make the X server (Xming usually) work, and you will not be able to use the gedit and paraview either. Good luck |
[TurboGrid] Examine coordinate points of balde tip surface | Arknecro | ANSYS Meshing & Geometry | 0 | February 20, 2020 12:39 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 11:20 |
[ICEM] make tip gap surface, ICEM | Jonathan | ANSYS Meshing & Geometry | 2 | July 3, 2014 12:06 |
[ICEM] Unstructure Meshing at the Wing Tip Surface from Imported Plot3D Structured Mesh | yona | ANSYS Meshing & Geometry | 8 | January 21, 2014 11:06 |
Quick tip to obtain negative convection | paillou | FLUENT | 0 | June 30, 2011 11:33 |
